12-21-2016 18:57
12-21-2016 18:57
I just got a Fitbit Zip today and I'm wondering how I can reset the steps I already tried removing the battery but that didn't work
Best Answer12-21-2016 23:48
12-21-2016 23:48
You can't reset the steps manually but they automatically reset at midnight each day.
Best Answer07-06-2017 08:21
07-06-2017 08:21
My Fitbit Zip isn't resetting to zero by each morning. The 24-hour cycle appears to be off. Ideas?
Best Answer07-07-2017 19:58
07-07-2017 19:58
Awesome help @SteveH! 🙂 Thanks for stopping by @suzannehadley! This sounds odd.
Please check if you followed these steps to restart your tracker. Also, to make sure that your tracker is communicating correctly with Fitbit and displaying the correct data try setting your tracker up as a replacement device.
Keep me posted with the outcome!
