03-29-2014
14:33
09:40
HelenaFitbit
03-29-2014
14:33
09:40
HelenaFitbit
My fitbit zip battery back will not open. I have used the tool that comes with the Fitbit zip and a quarter to try to open it. It will not open. I have enlisted the help of my daughter and son in law, fitbit owners as well, who say it is unusually tight, and they can't open it either. The only person who has ever been able to open it, are the employees of RadioShack (where I purchased my new battery from).
Has anyone else encountered this? Any ideas to get it to work?
04-26-2014 02:29
04-26-2014 02:29
yes, it is very, very difficult and after four months, the little pieces are broken from the cover as I tried to put it back - even using the tool. I have now selotaped the cover and put it back into the case, it still works, but that's not the point.
I have now written to Fitbit and asked for a replacement back to be sent as I am in training for a marathon and need to be able to use it with confidence again.
Not a good design at all for the cover, hopefully they will improve it for the next version - they will if enough people complain!!
04-26-2014 05:51
04-26-2014 05:51
Do you mean the battery cover? Not sure how else it could be screwed on securely to be water tight. Do you have a heart rate monitor? A much better investment for a serious marathoner and just try to change the battery in one of those!
Fitbit Zip
If you find your answer, be sure to mark it as a solution!
03-23-2015 12:42 - edited 03-23-2015 12:47
can not get the battery cover off
I have waited so long to get this i am beyond upset.
Only one hand and i must hire someone to come iunsert a BATTERY
AH OFF NOW DO I REMOVE THE PAPER IN THERE?
03-23-2015 20:52
03-23-2015 20:52
I had the Zip and lost the battery cover. I contacted customer service about purchasing a new cover. they said that they don't sell them and that maybe if they could find an extra one, they would send it. Really!! I bought a new Flex. Still haven't gotten a battery cover. How hard can that be???
03-24-2015 03:37
03-24-2015 03:37
11-01-2015 07:51
11-01-2015 07:51
Just wondering if you ever got your Fitbit cover off. I purchased mine in May 2015 & at the end of Oct had to replace the battery. I bought the battery at Radio Shack and the employee couldn't open the back with a nickel (wow! that's really tight, he said). At home, I've tried to open it with the Fitbit tool -- still no luck. Don't know what to do.
11-02-2015 07:20
11-02-2015 07:20
It's great to see you here in the Community @Sandwich, welcome here!
Really weird let me say, but thanks for letting me know you've tried with other things . My best suggestion would be to contact Support directly. They'll be more than glad to give you a hand on this, when contacting them don't forget to mention what you tried in order to open the door of your Zip.
Good luck darling!
11-07-2015 21:31
11-07-2015 21:31
11-08-2015 08:10
11-08-2015 08:10
11-09-2015 04:42
11-09-2015 04:42
Thanks for stopping by @rcpeaches @ronh51 , hope you're doing really great today!
Did Support send you the clips? I mean, going back to your original post I was seeing that the main issue was the battery door, wasn't it?
Great news @rcpeaches , I'm glad to hear that everything is working fine for you darling! Hope you two have a nice start of the week!
03-14-2016
08:28
04:00
03-14-2016
08:28
04:00
Don't bother calling support! I just wasted 30 minutes talking to "Jose" and him speaking with his manager only to be told...
1) you may need someone to help you (which is sexist)
2) we've never heard of this issue before
3) I have one in my hand now and am able to open it no problem
4) that's not under warranty
5) It only cost $59.99 so you can get another one.
WTH? I am so very upset about these responses. I hope someone contacts me from their company so I can get some answers.
Moderator edit: personal information
03-15-2016 04:01
03-15-2016 04:01
Hey @Twilkison, welcome to the Fitbit Community ! I'm very sorry to hear the inconveniences you've been having. I've reached you via private message, catch you there!
07-28-2016 09:34
07-28-2016 09:34
07-29-2016 03:57
07-29-2016 03:57
have you tried a 20p coin
07-29-2016 04:32
07-29-2016 04:32
Have you tried what @scotsbabe2016 suggested?
I'm sorry about the problems you experience with the design of the battery door on your Fitbit Zip. The best place to make your voice heard is the Ideas board on our community which our product development teams consult regularly to ensure we're delivering on what our customers need and want. Please take a moment to visit and give us your feedback.
I've found the request "Battery compartment door - design change" created by another user. If you think that this is similar of what you want, yYIf you find that a similar suggestion has already been made by another member of the community, you can vote for their idea and add your comments. Our product team looks forward to reading and incorporating your suggestions into future versions of Fitbit trackers and apps.
Anything else, I'm here to help @cmb0305 !
12-28-2016 22:29
12-28-2016 22:29
On the principle of using hot water to open jars, I heated my new Fitbit with a hairdryer for about 30 seconds to enable insertion of its first battery. The back unlocked fine. Before replacing, I thoroughly cleaned the edges of the body and battery door with rubbing alcohol and allowed it to dry completely. Guess I'll see if that worked when I need to replace the battery in future.
01-05-2017 20:26
01-05-2017 20:26
I too could not open the battery door so i ran it under hot water then used a sharp knife and cleaned around the door the ut came off no problem.
02-08-2017 06:47
02-08-2017 06:47
With or without the tool the door will not open. I am now going to throw out 2 Zips, Fitbit is no help. Why buy another one of their products. They sure do not care for their customers. There are others out there.
04-24-2017 11:09
04-24-2017 11:09
My fit bit cover will not open either and I'm fed up with having this issue every time I change the battery! I've had to change the battery several times since I've had the zip, which in itself is not an issue, but I've had issues with the back cover being so difficult to remove every time and each time it's more difficult. I've cleaned around the cover to be its clean when putting it back and here we are again at this annoying crossroads. This time is even more difficult. I'll try the hot water trick first and think twice before purchasing yet another battery, but I WILL NOT buy another fit bit - ever. I'm going back to the little cheapies - from what I'm reading "service" is of no service. How can I say it best? sayonara, adios, au revoir, addio ... goodbye fit bit. Take a walk!
