09-14-2017 15:19 - edited 10-10-2017 11:45
Fitbit update 10/9/2017: This has been resolved in update 2.41.1. Please update your app if you continue to experience this issue. Thanks again for your reports and patience. As this issue is resolved, I'll be closing this thread for further comments.
I've merged a few posts together because we received several reports of battery draining for Zip users on iOS after the 2.39 update. Our team is currently investigating the root cause of this issue and will be hard at work to get a fix out as quickly as possible to get you all back on track. Once I receive an update from them I will update this thread and will make sure to keep you all in the loop.
Also note, we have had reports that turning off all-day-sync has helped as a workaround and worth a try until this issue is resolved.
Thanks for your help with reporting this and for your continued patience.
Actively managing your weight? Find accountability buddies on the Manage Weight board
09-03-2017 10:13
09-03-2017 10:13
I have this problem all the time. This is my 3rd zip and I can't tell you how many batteries. I have even changed brands of batteries thinking maybe it's the battery. I love the zip because it's small but not very happy with the full, medium, low battery constantly. Right now I have a brand new Duracell battery in it and it says empty!!!!
Best Answer09-03-2017 10:29
09-03-2017 10:29
Best Answer09-03-2017 10:31
09-03-2017 10:31
09-03-2017 10:32
09-03-2017 10:32
Best Answer09-03-2017 10:40
09-03-2017 10:40
Sorry to be unclear. I have a Samsung Android cell phone with ATT service. When Samsung did some upgrade in early August 2017, the fitbit went crazy. That is the trouble. Others have commented on the battery issue and it has become part of the discussion. I have a similar issue with batteries but not as bad as some. Just hoping that Fitbit can communicate with phone manufacturers to resolve/patch the problem. I really like the fitbit and hope I can continue to use it.
Best Answer09-03-2017 11:07
09-03-2017 11:07
Best Answer09-03-2017 20:00
09-03-2017 20:00
Best Answer09-03-2017 23:38
09-03-2017 23:38
Hi Susan307, I am also having problems with short battery life on my Fitbit zip. The first message I received only hours after purchasing my zip pedometer was that the battery was low. I ignored the message and my zip continued to operate for almost 3 months before it went dead. I have just replaced the battery with the CR2025 button battery as recommended and two days later I get the low battery message. I wonder if there is a faulty batch of Fitbit zip pedometers being sold?
Walkalittle
Best Answer09-04-2017 05:14
09-04-2017 05:14
09-04-2017 12:59
09-04-2017 12:59
Best Answer09-04-2017 14:35
09-04-2017 14:35
Best Answer09-04-2017 17:16
09-04-2017 17:16
I'm suddenly getting just a day or two out of my batteries. I went through an entire package of older discount batteries, two days at a time, and thought OK, they are old and low-quality. Then I bought a pair of brand-new Duracells and have had the identical problem.
I'm a great fan of the Fitbit Zip, and would never wear a bracelet all day. I'll be watching for a solution and checking out other manufacturers in case I have to make a change.
09-05-2017 14:03
09-05-2017 14:03
I agree with everyone, the batteries are not lasting. This is my fourth one and it only lasted two days. I have not changed the settings, but I turned off the sync now mode and still no luck. The reason I got this is because I cannot wear the watch at work.
Best Answer09-05-2017 14:27
09-05-2017 14:27
Best Answer09-05-2017 15:51
09-05-2017 15:51
Best Answer09-05-2017 17:22
09-05-2017 17:22
Best Answer09-05-2017 19:07
09-05-2017 19:07
I am also having issues similar to those described here. I just bought my fit bit zip in May. It worked perfectly until August when it said the battery was running low. I purchased new batteries CR 2025 and replace the battery. Within three days it was telling me the battery was nearly dead. I inserted another new battery, and within three days the same thing happened. I went to a completely different store, purchased a different brand of CR 2025 batteries, and again within three days it says the battery is nearly dead. I love how unobtrusive the tiny zip is. Please fix this problem for me! I don't want toga either to tell people I wasted my money on a fit bit!
Best Answer09-06-2017 07:56
09-06-2017 07:56
Could you help me with mine also? I purchased mine less than a year ago. The battery that came with it only last a month and I purchased a new one with no issues until the most recent battery change. 2 weeks ago my FitBit was showing low battery so I purchased a new one. Within 3 days it was showing low battery again. I went through all the steps that were listed in these forums before trying another new battery. Last Tuesday I purchased a new battery, yes I'm purchasing the proper battery, and today it's showing low again. Could there be an actual problem with the Zip? I shouldn't have gone through 2 batteries in 2 weeks,
09-06-2017 09:26
09-06-2017 09:26
Best Answer09-06-2017 14:28
09-06-2017 14:28
