09-14-2017 15:19 - edited 10-10-2017 11:45
Fitbit update 10/9/2017: This has been resolved in update 2.41.1. Please update your app if you continue to experience this issue. Thanks again for your reports and patience. As this issue is resolved, I'll be closing this thread for further comments.
I've merged a few posts together because we received several reports of battery draining for Zip users on iOS after the 2.39 update. Our team is currently investigating the root cause of this issue and will be hard at work to get a fix out as quickly as possible to get you all back on track. Once I receive an update from them I will update this thread and will make sure to keep you all in the loop.
Also note, we have had reports that turning off all-day-sync has helped as a workaround and worth a try until this issue is resolved.
Thanks for your help with reporting this and for your continued patience.
Actively managing your weight? Find accountability buddies on the Manage Weight board
09-06-2017 14:42
09-06-2017 14:42
09-06-2017 15:34
09-06-2017 15:34
09-06-2017 16:10
09-06-2017 16:10
@TomH63 and @Deberswhls
What applications did you turn off? I only have three showing.
-Fitbit Web Applicarion
-Fitbit for iPhone
-Vitality (an app for work to count my steps towards benefits)
09-06-2017 17:01
09-06-2017 17:01
Hi Everyone, We are currently looking into an issue that is causing a battery drain since the latest iOS update. This may be affecting some of you. I'll update this thread when I hear more, and you can also follow this thread. Thanks very much for your patience.
09-06-2017 17:03
09-06-2017 17:03
09-06-2017 17:42
09-06-2017 17:42
09-08-2017 08:25
09-08-2017 08:25
09-08-2017 09:41
09-08-2017 09:41
Yes I was offered the same a few days after I posted on here so very impressed with their customer service - I've stuck with the fit bit (and replacement here already) though I may live to regret this but hopefully not.
09-08-2017 16:17
09-08-2017 16:17
Having the same issue. I replaced my battery Sunday, today is Friday and the battery is done. I'm averaging 1 1/2 batteries a week. My first zip (which got broken) never had this issue. What the heck?!
09-08-2017 16:26
09-08-2017 16:26
09-08-2017 16:39
09-08-2017 16:39
09-08-2017 16:58
09-08-2017 16:58
I have an iPhone and am having the same issue with battery life.
09-08-2017 19:59
09-08-2017 19:59
I am having the same problem. When I got this Zip about 6 months ago the battery lasted about 4 months. I replaced that battery and within 2 months it was red. I replaced with a new battery 5 days ago and now l have a red bar. This was a new battery purchase that still has 5 years on life. What do I need to do?
09-09-2017 07:14
09-09-2017 07:14
Your not alone, Fitbit will try to help u
09-09-2017 09:27
09-09-2017 09:27
09-09-2017 10:22
09-09-2017 10:22
I sent an email to Fitbit support and they helped me fix it or if it doesn't work they will ask u several question to see if u qualify for a replacement and u/ them go from there. They are. Dry helpful
09-14-2017 16:42
09-14-2017 16:42
The general feeling here (primarily my experience) is that the 2032 battery performs better than the 2025. What experience have the other Zip users had with the 2032? Have you found it to provide longer life?
09-14-2017 16:52
09-14-2017 16:52
This has been happening to me as well after 2 days of battery use. This is so frustrating. It never happened before. I can't tell you how many batteries I've gone through. They replaced my last zip and two days later the new zip was dead. I believe they have a bad batch of Zip's.:(
09-14-2017 16:54
09-14-2017 16:54
Mine lasts 2 days as well:(
09-14-2017 19:25
09-14-2017 19:25
