09-14-2017 15:19 - edited 10-10-2017 11:45
Fitbit update 10/9/2017: This has been resolved in update 2.41.1. Please update your app if you continue to experience this issue. Thanks again for your reports and patience. As this issue is resolved, I'll be closing this thread for further comments.
I've merged a few posts together because we received several reports of battery draining for Zip users on iOS after the 2.39 update. Our team is currently investigating the root cause of this issue and will be hard at work to get a fix out as quickly as possible to get you all back on track. Once I receive an update from them I will update this thread and will make sure to keep you all in the loop.
Also note, we have had reports that turning off all-day-sync has helped as a workaround and worth a try until this issue is resolved.
Thanks for your help with reporting this and for your continued patience.
Actively managing your weight? Find accountability buddies on the Manage Weight board
09-15-2017 09:48
09-15-2017 09:48
So is the battery actually draining or is it just the display on the zip and app showing it's low battery, when the battery is actually fine? Do I need to replace the battery, as it is now flashing to show very low battery on my unit? I don't understand how an app update would cause the battery to drain in a week. It is expensive if I have to keep replacing the battery until the app update is fixed. In one day it went from 70% to 30% according to the Fitbit diagnostics,
09-15-2017 09:55
09-15-2017 09:55
To answer my own question, my zip just died 😞 I don't understand how a software issue is causing the battery to physically drain so quickly?
09-16-2017 19:05
09-16-2017 19:05
Where do I go to turn off these apps?
09-16-2017 19:07
09-16-2017 19:07
Ty. As I have been trying a new battery every day. Very frustrating but nice to know I. Good company. Meanwhile what are current zip fit bit users supposed to do. Is there an exchange policy or notification of software update ?
Ty. Missing the Fitbit challenge
09-17-2017 02:42
09-17-2017 02:42
09-17-2017 13:26
09-17-2017 13:26
I was having the same problem. I would replace the new battery and in two days I was getting a low battery message. I contacted the Fitbit help desk and they had no solution. Then a friend gave me the solution. Go into your Dashboard. Click on the flashing battery. Deactivate the All-Day Sync. When I did this my Fitbit Zip immediately showed a full battery again and it still does after two weeks. Unfortunately I had already ordered a new Fitbit One before I learned this trip. However, I did receive a 25% discount from the customer service desk.
09-17-2017 13:30
09-17-2017 13:30
09-17-2017 16:40
09-17-2017 16:40
I don't have mine on the all day sync, but don't know what the flashing battery is.
09-17-2017 18:44
09-17-2017 18:44
09-18-2017 06:23
09-18-2017 06:23
Same here. Battery lasting no time at all.
09-18-2017 06:38
09-18-2017 06:38
Agree my battery last less than a week and it's got worse since the latest update
09-18-2017 11:29
09-18-2017 11:29
I use the same battery and lucky if they last one week ..... really frustrating!!!!
they previously lasted 6 months 👿👿
@LucyAP wrote:Thanks for visiting the Community @Nam71429! Please double check if you are using 3V coin battery, CR2025. It can be found wherever batteries are sold.
Keep me posted, I'd love to help you get back on track! 🙂
09-18-2017 15:24
09-18-2017 15:24
Turning off All Day Sync helps a lot. I've been able to use batteries that previously showed as dead, getting about one additional week per battery.
09-19-2017 04:11
09-19-2017 04:11
I've had my Zip for several years and have always found the battery life to be inconsistent but one to two days is ridiculous. They claim it is a result of the latest iOS software update. This has been going on for a while now and I personally can not keep buying batteries with this frequency. Something needs to be done, and fast. Fitbit also needs to stand behind their product, and accept responsibility. It is virtually useless this way. Anyone familiar with other trackers similar to the Zip?
09-19-2017 11:14
09-19-2017 11:14
Big Jake. I'm using the CR 2025 but I'll get the one u say and see if it works. Fitbit sent me a new Fitbit and I immediately put a new battery and the next day was almost dead , I'm afraid to move the clip from the back of batt cause the first time I tried to fix it I broke the smallest clip But I'm happy Fitbit helped me I'll just try with this batt ur suggesting. Hopefully works for months. Thank you
09-20-2017 12:04
09-20-2017 12:04
HI Nam,
The 3023 battery takes care of having to fiddle with the battery contact in the back of the case, The thicker 2032 battery does that for you. Let me know how the 2032 battery works for you.
Jake
09-20-2017 13:54
09-20-2017 13:54
09-20-2017 15:47
09-20-2017 15:47
09-20-2017 16:03
09-20-2017 16:03
I noted I referred to the battery as 2023 in my first sentence. That is not correct, It is a 2032. Sorry, bad fingers.
09-21-2017 12:37
09-21-2017 12:37
How about we get back to having the Zip battery issue resolved so that we can all get back to using your product as it used to be!
