04-03-2018
23:28
12:16
LucyAP
04-03-2018
23:28
12:16
LucyAP
I cannot get my Zip to sync with my Windows 10 laptop, nor with my Android phone. It used to sync fine with my laptop until Sunday, but I have not been able to get it to sync with my phone, a Moto G4, for months.
I have tried un/reinstalling the app on both devices. Repeatedly. My internet connection is fine, so that's not it either. It's also the only Fitbit in the house at the moment. I even tried setting up my current device as a new one, & even that didn't work.
I've been through all the help section, & still can't get my device to sync.
I have been a long time user of Fitbit products, but it would be really nice if I didn't have to contact support so frequently.
I would also like to point out that at least 50% of FitBit's negative reviews left on the Google Play store on 4/3/18 were complaints about syncing issues after a recent update, & the most popular question on the help page is "Why won't my Fitbit sync?", so clearly it's not just me.
Best Answer04-04-2018 23:17
04-04-2018 23:17
Same here. Stopped synching yesterday afternoon. I’m in a challenge too so that’s now showing me as a couch potato!
Best Answer04-06-2018 04:50
04-06-2018 04:50
I have been unable to sync my Zip to my laptop using Fitbit Connect since installing the latest update on 4/4/18. It has occasionally synced (like once per day if I'm lucky, though I'm with my laptop most of the time), but if I try to do it manually using Connect (which has always worked in the past), it fails. I un- and re-installed, turned Bluetooth off/on, disabled/re-enabled Bluetooth, restarted laptop, and any other solution I found posted, but syncing isn't happening like it used to, and Connect won't connect, even when no other device is in the house.
Best Answer04-07-2018 06:47
04-07-2018 06:47
Having the same problem here. Mine quit syncing with either windows 10 or 7 some time ago and now has major trouble syncing with my andriod phone. I'm about ready to throw this thing out of the window.
Best Answer04-07-2018 07:33
04-07-2018 07:33
Solo2, mine syncs now. I went to the Help page from my dashboard, then to the Get Support page, and started a chat. the agent said there was a firmware update I didn't appear to have; installed it; and voila, now my device syncs every 20 min. when I'm near my laptop. Maybe your sync problem could be solved as simply... Good luck!
Best Answer04-07-2018 07:42
04-07-2018 07:42
I'll give that a try, thanks.
Best Answer04-07-2018 12:14 - edited 04-07-2018 12:15
Hi everyone and welcome to the Forums! Awesome help @LaurelO! @solo2, @FaithBlack, and @Hantszn Thanks for sharing your experience with your Zip tracker. If you are still experiencing a difficulty syncing your tracker, please restart it. Also, you can try the suggested troubleshooting at the help article Why won't my Fitbit device sync?
I hope this helps, keep me posted! 😉
