10-25-2017 17:50 - edited 03-21-2018 10:22
I've been notified that there are reports of Zip battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Turn off All-Day Sync:
Actively managing your weight? Find accountability buddies on the Manage Weight board
11-02-2017 10:30
11-02-2017 10:30
I am also having the same problem. I have turned off the all day sync feature last week and my batteries are still only lasting 2-3 days. I'm also tired of the "hang on, we're cleaning things up a bit for you" erasing my step count multiple times a week. What is going on with that?
11-02-2017 11:10
11-02-2017 11:10
Is the battery draining because of the iOS update (I’ve been through one a week), or I need a new Fitbit
11-02-2017 11:57 - last edited on 02-22-2018 14:42 by LucyAP
A new Fitbit is not going to help. I thought the same thing so I bought one
and still having battery issues.
Sharon Jones
Moderator edit: personal information displayed and format
11-02-2017 13:46
11-02-2017 13:46
11-02-2017 15:53
11-02-2017 15:53
I just opened my Fitbit app & it said I had an update. I updated it so I guess I’ll see if it helps. Although the battery I put in a few days ago is on already on medium.
11-03-2017 05:33
11-03-2017 05:33
have you got any advice on the battery drain. I have replaced battery three times in the month I have had it. I am going to return my fitbit zip
Sincerely
Tammy Martin
11-03-2017 05:43
11-03-2017 05:43
11-03-2017 12:07
11-03-2017 12:07
I also notice that the bluetooth sync doesn't want to work anymore too. In addition to the fast battery drain, etc. etc.
11-03-2017 13:23
11-03-2017 13:23
I received a notice yesterday from FitBit that there was an update to be downloaded. I was happy to think that this was a fix for the battery issue. I downloaded the update as instructed and that took 8 minutes. Immediately after the download it drained the battery to empty! I put in a new battery last night and this morning it stated my battery was low. This was not the fix I was expecting. I have now replaced 6 batteries in 7 weeks! I cannot believe that FitBit Corporate has not put out a communication to its customer base explaining what is going on and when a fix to this issue can be expected.
11-03-2017 14:56
11-03-2017 14:56
11-03-2017 14:59
11-03-2017 14:59
11-04-2017 07:50
11-04-2017 07:50
Well I just spent time with "Joel" on the FitBit chat board and I have decided to return my brand new zip because of the issue. I can not afford to replace a battery every few days. I am very disappointed. I do have a FitBit Blaze that I love I was just looking for a discreet device that I could wear and still wear other jewelry and watches.
Very disappointed in the Zip
Hey FitBit you should come up with product or some way to wear existing devices discreetly.
Ann
11-04-2017 07:54
11-04-2017 07:54
This Should be combined with the posts about battery drain 3.9 hasn’t been right since 3.9
11-04-2017 19:24
11-04-2017 19:24
11-05-2017 00:46
11-05-2017 00:46
Yes only two weeks. Will try not putting it next to the phone at night.
11-05-2017 11:09
11-05-2017 11:09
I'm glad to read that so many other users are having the battery problem. Mine are lasting just 2 weeks and they are expensive! Quick resolution please
11-05-2017 16:11
11-05-2017 16:11
I don't use "all day sync" and my battery lasted less than 2 days. Batteries are $6 a piece so that's a hefty price to pay for a step tracker.
11-06-2017 02:42
11-06-2017 02:42
Same problem short battery life, the Zip is junk don't waste your money!
11-06-2017 06:59 - last edited on 02-22-2018 14:40 by LucyAP
I am on my third zip and never had any problems with battery drain until the last month or so. I picked it because of the small size and I love it. (My problem is washing them )
I agree with previous posts regarding the FitBit Corp. This is not their finest hour. I am willing to wait a bit longer for them to resolve this issue because I like this product.
Moderator edit: format
11-06-2017 08:29
11-06-2017 08:29
Do you want my?
