10-25-2017 17:50 - edited 03-21-2018 10:22
I've been notified that there are reports of Zip battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Turn off All-Day Sync:
Actively managing your weight? Find accountability buddies on the Manage Weight board
07-13-2018 12:11
07-13-2018 12:11
07-13-2018 12:25
07-13-2018 12:25
07-13-2018 12:30
07-13-2018 12:30
07-14-2018 06:48
07-14-2018 06:48
Just replaced my battery 2 days ago and it's already showing low battery. Has this problem been fixed or any suggestions? Having to replace batteries every month or so...except this time ...2 days,
07-14-2018 10:38
07-14-2018 10:38
07-14-2018 14:17
07-14-2018 14:17
07-15-2018 09:17
07-15-2018 09:17
Hi everybody! Thanks for keep adding your responses in this thread and for all the steps that you've done to try to solve this issue with your Zip.
If you've already done all troubleshooting steps given in this article, it's best to follow up with our support team so they can further investigate what is happening with your Fitbit. Some of your might have already a case open with our them, so just reply back to the last email that you received with all the details of the steps that you've tried so far. If you still don't have a case with them, let me know so I can give you a hand with that.
I'll be around.
07-15-2018 18:16
07-15-2018 18:16
07-15-2018 21:06
07-15-2018 21:06
07-16-2018
02:41
05:23
YojanaFitbit
07-16-2018
02:41
05:23
YojanaFitbit
Hello,
I have tried the suggestions, but I am still experiencing the rapid battery
drain. I am lucky if a battery lasts a month. It also shows "false
readings" as it sometimes goes from a full battery and when I manually sync
it the next time, it shows a completely depleted battery. If I close the
Fitbit app and/or remove the battery from the fitbit and replace it, I can
get the fully charged battery message stored. However, when I start
getting these intermittent half drained, completely drained battery
messages, I know the battery is on its last legs.
I don't want to wear something on my wrist to count my steps; I like the
Zip because I can put it an in inconspicuous place. But I'm tired of
having to buy the batteries and always keep one with me so I can replace it
when it dies out of the blue and I am unable to bring it back to life.
Deb J.
Moderator edit: Removed personal information.
07-19-2018 05:55 - edited 07-19-2018 05:56
Hi @tammyjo46, @debleo and @cassie14 thanks for getting back and for trying all those steps. Sorry for the inconvenience that you're having with your Zip.
@tammyjo46 Thanks for the details on your post, I'll do my best to help you out with this. For the issues with your steps and battery drain please confirm that your Zip is getting an appropriate battery contact you can see the picture in this post with some tips. Have you tried so?
@cassie14 I really appreciate the time you took in order to help your little buddy, in this case I've requested a ticket for you, our team will be contacting you via email shortly as they have special tools that might be giving a better idea of what is happening with your Zip. Hope this gets resolve.
@debleo You've done all the correct steps for the issues that you're having and I agree with you as it is not fun to be buying batteries all the time, when it should be lasting at least a couple of months. Did you check the contacts on Zip? Maybe it is what is causing this erratic behavior.
Please keep me posted.
07-19-2018 06:47
07-19-2018 06:47
07-19-2018 06:49
07-19-2018 06:49
Thanks for these responses, however, not a one says the status of the 'fix' for the problem we are having. It is now exactly a year since I originally posted regarding this problem and not ONE thing has been done to improve or fix the problem as far as I can tell.
Fitbit could you please update us with a status instead of beating around the bush?
07-19-2018 07:45
07-19-2018 07:45
07-19-2018 08:03
07-19-2018 08:03
07-19-2018 09:47
07-19-2018 09:47
07-20-2018 13:54
07-20-2018 13:54
Hi everybody!
Currently, we don't have updates for the rapid battery drain issue, although at this point the new version shouldn't be causing syncing issues to our Zip users. Our team is still investigating, so we'll pass along the feedback. But I don't currently have a time frame for a fix. As mentioned before, along with turning off all day sync, we do suggest syncing to a computer or Android device if possible.
We truly appreciate your patience while it's being resolved.
07-20-2018 20:24
07-20-2018 20:24
After a week of use my Zip died: no syncing and nothing on the screen. I changed the batteries, and restarted it. Nothing. I'm sending it back to Amazon and ordering a new one from Fitbit in the hope that since the Zip is backordered the new stock will be of better quality. Also, am I right in thinking that I can just sync to my iMac and not to my iPhone app? I've already deleted it from my phone and don't plan to download it again. Frankly I'd just use my old Omron ped but it doesn't record my activity on my recumbent bike. I slide the clip onto my laces and it records my 'steps'.
07-20-2018 23:47
07-20-2018 23:47
07-21-2018 13:17
07-21-2018 13:17
Apparently the observations through this entire thread are indications of Fitbit's overall approach to customer service. For many months they have been unable to provide a fix for the Zip battery drain.
In addition to the Zip battery drain issue I had a sudden failure of a 13 month old Alta HR and Fitbit's response was that "as a global company we must strictly adhere to the 12 month terms of our warranty". Then they basically told me to buy a new one, as a customer concession they even offered to sell me a new one directly at the same price as what I could get it at Best Buy.
Eventually Fitbit will learn the painful lesson that abandoning their customers in their competitive industry is a sure path to company failure.
