Zip won't sync or connect to Bluetooth.
Updated software for Samsung s9 and phone and zip will no longer sync it Bluetooth connection . Help .
75 REPLIES 75
I contacted Fitbit support, I'll probably get the run around because they probably have no idea what's going on or happening, I'm thinking about uninstalling the app and reinstalling it but I don't want to lose my progress from the last few years
Sent from Yahoo Mail on Android
No worries there, I reinstalled the app earlier this week after a break of 18 months & all info there.  But new phone & all these problems with syncing grrrr...Sent from my Samsung Galaxy smartphone.
I've done that too. I didnt lose progress but it didnt work
Tried this and it did not work
Has anyone one heard back? I'm getting frustrated with my device. I've tried everything and it isn't working.
- The only way I can sync is still with my PC via Fitbit Connect. Can't
sync with my S8.
Virus-free.
www.avg.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
@https://help.fitbit.com/articles/en_US/Help_article/2315@
Contacted Fitbit. Unless you are on the list, it's tough basically.
Look up the article to see if your phone is on there.
Yes phone is listed & thanks for advice, I'll contact Fitbit.Sent from my Samsung Galaxy smartphone.
Same here! It just happened yesterday.  Is there a fix to this
No not word yet!!! Time to switch pedometers!
I have contacted Samsung mobile support and I am waiting for a reply.
Thank you
Same here..did an update on my Driod earlier this week and since then it won't sync. I have uninstalled and reinstalled app, checked all setting and permissions and nothing. IF I take the battery out, wait about 10 seconds reinstall battery it will sync HOWEVER I have to do this every time I need it to sync.
I uninstalled Fit bit app and reinstalled, then removed battery in Fitbit and put back in and now I can sync.
I turned off my bluetooth and took my battery out of my zip and waited a minute, I put the battery back in and turned on bluetooth and it synced
I turned off bluetooth and took the battery out and waited a minute and put the battery back in and turned on bluetooth and it synced
I took my battery out and turned off my bluetooth, waited for a minute and put battery back in and turned on bluetooth and it synced
This did not work for me. I'm still not syncing and am jumping this synki
ng ship.
Yes, I posted earlier that this worked for me but am now also back to not syncing.
Fitbit said they rolled out an update too on 4/1/19 but android users are
only getting 10% of it and they don't know why.
