Update 7/19/2018: This issue is now resolved, please ensure your app is updated if you still experiencing this issue. We appreciate everyone's patience and cooperation as we worked on a fix. I'll be closing this for further reports. If you are experiencing any new issues with food logging, please start a new thread.
Update 7/18/2018: Thanks again everyone for your reports. Glad to hear the update has corrected food logging issues for many.
If you are still experiencing this issue, we would love to investigate further. The following would help our team review:
We appreciate the additional details.
Fitbit Update 07/16/2018: Hey everyone -- We have just released an update to the Fitbit app for iOS, version 2.53.1 which we believe resolves the issues with food logging that have been reported in this thread. Please update to 2.53.1 and let me know of the results so I can quickly communicate that to our iOS team.
Again, thank you for your continued patience as we worked to get this resolved ASAP.
Update 7/15/2018:
Thanks everyone for your patience on this. We sincerely apologize to anyone who has been affected by this issue and have been working hard to find a fix. We are preparing to roll out an update tomorrow, July 16th to solve the problem. In the meantime, customers can use the food logging feature in the web dashboard: https://www.fitbit.com/foods/log.
Update 7/14/2018: We do realize this is a critical issue and our team continues to work on the cause and a fix. We don't provide timelines, in case something occurs and it can't be met, but we hope to have a resolution soon. Thank you again for your patience, reports, and cooperation.
Update 7/13/2018: Hi Everyone - we definitely do hear your reports and frustration on missing and strange food logs. Our engineers are still investigating and I hope to have a resolution shortly.
While not ideal, you can log on Fitbit.com food log and it will populate on iOS correctly once you sync. You can log it here. We appreciate your cooperation. I'll continue to update this thread as I hear more.
Update 7/12/2018: Hi Everyone - thanks again for your reports. We are actively reviewing this issue and I'll continue to update the thread as I hear further. As a workaround you may want to log your food through https://www.fitbit.com/foods/log. As mentioned in @sreid64's post, it will populate the iOS app correctly. Thanks again for your patience and reports.
Update 7/11/2018: Hi Everyone - I've merged a few posts together. We are currently investigating issues with food logging on iOS version 2.53. Please continue to monitor this thread for updates. If this is severely affecting your food logging, you may want to log through Fitbit.com. Thank you very much for your reports and patience as we review.
Actively managing your weight? Find accountability buddies on the Manage Weight board
Having the same issue since latest update. Both disappearing entries and entries changing from those selected. Also tried reset without success.
Best AnswerAlso having both of the issues described by other Fitbit users. I’ll go to log foods and they either won’t appear at all after hitting save, or they will appear for a second and immediately disappear. And sometimes I’ll try to log something like “Peppered Turkey Beast” and, depending on the brand I select, it will change to “Italian Turkey Slices” or “Spinach and Artichoke Dip”. Super frustrating because it’s throwing off all my Macros!
Best AnswerAs a work around I set up MyFittnessPal. I think this turned out a good thing, MFP seems better all the way around. The interface is much cleaner and the calories count down instead of up which is easier to read. All pertinent info sync's so no reason to use the FitBit app just because of the name
Best AnswerMine just started this too!
Best AnswerExactly!
Salso was saved as Ketchup and Kirkland Organic White Corn Tortilla Chips was Cherries. WTF is going on! I just updated a hour ago😩
All of you please see @JohnnyRow post above yours. There is as link to follow as this is a known issue
Wendy | CA | Moto G6 Android
Trying to enter food and keep getting bad data. Entered 3 slices of Butterball turkey and it came up as Uncle Howies Pizza. Entered green grapes and nothing came up.
