05-11-2018
16:05
18:17
05-11-2018
16:05
18:17
Can you replace the battery for Alta Fitbit? Mine is only 2 years old. The battery says it is charged but after a day and a half dies. When you plug it in it says the battery is about 3/4 charged. Fitbit is saying it has to be replaced. I am not sure I want to continue using Fitbit if I have to shell out $130 or more every two years.
Moderator edit: Updated title for clarity
No, the batteries are not replaceable. Im afraid that a couple of years is about the life for lithium ion batteries. There is some interesting information on them HERE at Battery University. But all devices that use these batteries, unless they are replaceable, are the same. The battery fails so the product dies. That is life today, and not a failing of Fitbit. Try another brand if you like - but they are all much the same as far as batteries go.
Helen | Western Australia
05-12-2018
15:18
10:22
FerdinandFitbit
05-12-2018
15:18
10:22
FerdinandFitbit
Your lucky mine died today and it was only 1 year 2 months old ugh
There on sale at target for 99.00 this week btw
Moderator edit: Merged replies
There are some 3rd party repair places to replace batteries or fix other issues, here is one example: https://www.joesge.com/pages/repair-services
You'd want to consider repair vs. replacement costs.
Best AnswerI’m having the same problem after only a couple of years. Very disappointing to spend so much money only to find out you can’t replace the battery but instead have to buy a whole new activity tracker.. This is a very expensive “throw away”!
I am in the same situation. My Fitbit Alta is less than 2 years old, but the battery only holds its charge for about 12 hours.
I am appalled by how wasteful it is to have to throw away a perfectly good Fitbit simply because it needs a new battery.
It's bad product design.
Whoever heard of a watch where you can't change the battery???
My Alta that is about 2 years old won’t even change. In the beginning I got about 5 days out of it and then after about a year I was lucky to get 2.5 days and for the last 6 months or so maybe a day and now it won’t hold a charge. I called Fitbit about purchasing a replacement battery but was told the battery isn’t replaceable. They did offer me a discount if I wanted to buy another Fitbit. No way am I going to buy this product again, even with their courtesy discount.
10:54
11:14
10-23-2018
10:54
11:14
Hi everyone! Good to see you all in the Fitbit Community Forums! 🙂
I'm sorry to hear you're having problems with the battery on your Fitbit Alta not lasting as it should 😕 I'd like to help you guys out.
If you're still under warranty and your battery isn't lasting at least 5 days with a regular usage, let me know and I'll be happy to escalate your case to our Support Team for them to get you back on track.
If you're outside the warranty (check the warranty terms and conditions here) and you'd like to see what are the available options at this point, let me knos and I'll be happy to help you out.
Anything else you guys may need, I'm here to help!
Whether they get replaced under warranty or not, these fitbits will never last more than a couple of years which means we are getting terrible value for money whatever happens.
This is a no win situation.
We unknowingly bought a product that has a very short life, and we will do our best to learn from that mistake.
If you want to help, FerdinandFitbit, please persuade the design team to make batteries replaceable in future models. That is the only thing that would make me consider buying another.
10-29-2018
12:58
11:09
10-29-2018
12:58
11:09
Good to see you around @Riatsala and thanks a lot for that suggestion which I think is great!
I can recommend checking this feature suggestion for having a replaceable battery on future Fitbit products. Feel free to add your vote and any comments you might have on the suggestion. Anything else you may need, I'm always around!
I bought my Fitbit Alta in the USA in May 2017. The battery is lasting only a few hours. Can it be replaced free of charge?
