05-11-2018 16:05 - last edited on 08-20-2020 18:17 by MatthewFitbit
Can you replace the battery for Alta Fitbit? Mine is only 2 years old. The battery says it is charged but after a day and a half dies. When you plug it in it says the battery is about 3/4 charged. Fitbit is saying it has to be replaced. I am not sure I want to continue using Fitbit if I have to shell out $130 or more every two years.
Moderator edit: Updated title for clarity
12-05-2018 12:52
12-05-2018 12:52
I purchased my fitbit alta in May 2017. My tracker won't last longer than 2 days with a full charge and now I can't even charge it. I'm hoping there is an easy fix, without that being to purchase a new fitbit tracker. Can you help?
12-05-2018 14:54
12-05-2018 14:54
12-06-2018 13:24
12-06-2018 13:24
12-13-2018 08:46
12-13-2018 08:46
Welcome to the Community Forums guys! 😄
@BSD38 @Lindssss If you're still under warranty (which varies depending on your location). For the locations where the warranty is of 2 years (the European Economic Area basically), you should still be in warranty. Please, let me know which is your situation and if you're still under warranty, I can escalate your case to have this taken care of. If you're out of warranty but still would like to know the available options, let me know!
@BSD38 I'm happy to hear that it seems to be working fine now though. If you get to experience any issue again, let me know so that I can help you out with this.
03-04-2019 18:18
03-04-2019 18:18
Heeeeelp!!!
04-12-2019 07:18
04-12-2019 07:18
Mine dies after about 5 hours and of course is out of warranty. I got offered a discount (which is less than I get through my company's wellness program), but really not sure I want to throw away $100+ every couple years. Ridiculous that the battery can't be changed if they know it doesn't last that long.
04-21-2019 09:04
04-21-2019 09:04
I've had my Fitbit Alta less than 6 weeks, initially battery stayed charged all day and was only 20-25% used when i plugged it in at nite to recharge. 3 days ago it died after about 3 hours, cleaned the prongs, recharged same thing last couple of days. Aargh, not what I expected. Going to turn off as much as I can, but don't understand what changed so drastically to go from several days of charge to mere hours!
05-13-2019 04:54
05-13-2019 04:54
Yeah mine is 2 years old and it will not decide what battery it is. I try to charge it, but if I take it off and don’t wear it, the next time I check it is out of batteries! It is so weird! Though I’m not surprised either, it is old.
05-14-2019 15:15
05-14-2019 15:15
I am out of warranty but would like to know what my other options are? Thank you!
05-14-2019 17:48
05-14-2019 17:48
Just bought my Alta March 27th and it’s already toast. Battery will no longer charge, now what?
05-20-2019 12:43
05-20-2019 12:43
Welcome to the forums @DragonsUnite17 and @Mlapointe ! It's nice to see you around @Susan19 and @Keithena ! I am sorry for the delayed response.
@Susan19 thanks so much for taking the time to troubleshoot the battery issue you're experiencing with your Fitbit Alta. I've gone ahead and escalated your case to our Support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
@DragonsUnite17 thank you for sharing your experience. Have you tried to restart your device? I recommend doing that several times. Please also check our tips for preventing battery drain at Can I improve my Fitbit device's battery life? since battery use is affected by various factors and settings.
@Keithena I understand your concern. I have created a case for you so our Support team can provide options based on your warranty. In the meantime, I'd like you to take a look at this page for more information about the warranty policy.
@Mlapointe thank you for sharing your experience. I could see that you got in touch with our Support team about this and that they were able to help you. I appreciate your time and efforts.
05-21-2019 12:20
05-21-2019 12:20
unfortunately that’s not true. their warranty period is 45 days! terrible. going 2 get a different brand of smart watch/tracker with better support
@KMC6714 wrote:
If it's been less then 2 years call them they'll replace it free of charge
05-22-2019 13:14
05-22-2019 13:14
Welcome to the Fitbit Community @monicajlevy .
Thank you for sharing your experience. I would like to clarify that Fitbit has a 45-day return policy, so anything purchased directly from Fitbit can be returned for a refund for any reason within 45 days of shipment.
Our limited warranty provides repair or replacement of Fitbit-branded products that have a defect while still in the warranty period. The warranty period depends on the location. You can take a look at this page for more information about the warranty policy.
Feel free to reach out if you have any other questions.
05-24-2019 16:44
05-24-2019 16:44
I am having the same problem. Mine is less than 6 months old. First the band kept falling apart, ok I fixed that but now the battery dies in hours. It seems to be charging and will say full but then it’s kaput not long after. Very irritating. No wonder my daughter went with a Garmin product. Ugh!
@Susan19 wrote:I've had my Fitbit Alta less than 6 weeks, initially battery stayed charged all day and was only 20-25% used when i plugged it in at nite to recharge. 3 days ago it died after about 3 hours, cleaned the prongs, recharged same thing last couple of days. Aargh, not what I expected. Going to turn off as much as I can, but don't understand what changed so drastically to go from several days of charge to mere hours!
05-26-2019 12:22
05-26-2019 12:22
Welcome to the Fitbit Community @SunsetRunner. I am sorry for the late response.
I'm sorry to hear about your experience with your Alta's band and battery and I am here to help you. I am glad to hear you fixed the issue with the band. I recommend to restart your device as described in this help article. This will refresh your device internally. Please review our tips for preventing battery drain at Can I improve my Fitbit device's battery life? as battery use is affected by various factors and settings.
Let me know how it goes!
05-26-2019 20:21 - last edited on 07-24-2021 06:10 by JuanJoFitbit
same trouble here. I just got it as a gift this Christmas. Even when fully charged, it dies after less than 2 days. Then when plugged in, it shows it is actually 3/4 charged. Very maddening.
Dear Ferdinand,
I am in exactly the same situation and very frustrated. I got this Alta as a Christmas gift along with a very nice extra band. It dies daily now. That means it is exactly 5 months old. My first Fitbit lasted more than 3 years!
Please tell me how I get it replaced. This is maddening.
Moderator edit: merged reply
05-27-2019 12:23
05-27-2019 12:23
Hi @yankeedoodlered, it's nice to see you again in our Community Forums!
Thank you for joining the conversation and sharing your experience with Fitbit Alta which you received as as a gift. I appreciate the information that your first Fitbit lasted more than 3 years. I totally understand how you are feeling and I am here to help you. Our Support team will be glad to review your options based on your warranty, however I would like to confirm first if you've tried to restart your tracker by following these steps: How do I restart my Fitbit device?
Keep me posted on the outcome!
05-27-2019 14:23
05-27-2019 14:23
Over the last couple of days I have reset my Fitbit multiple times. It will sync and indicate the battery is full. And then shut down less than 24 hours later. Sometimes it will only last 6 to 8 hours.
I have reviewed the documentation on extending battery life, and I don't have any draining activities enabled.
05-27-2019 14:46
05-27-2019 14:46
Hi @SunsetRunner, thank you for your reply.
I appreciate your troubleshooting efforts and the additional details. Since the issue persists, I've sent your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
If you have any questions, feel free to let me know.
05-27-2019 21:06
05-27-2019 21:06
My Alta wouldn’t do anything or charge. I believe the battery is dead. I’m disappointed because it lasts less than 2 years. The warranty is one year which expired. Are there any available options for me?
