12-08-2019
15:57
20:01
12-08-2019
15:57
20:01
My Alta HR appears completely dead. It doesn’t appear to even be charging. I ordered a new charger just to be certain but it’s made no difference. I’ve also tried the restart/reboot to no avail. Can anyone help?
I’m having a similar issue. It worked perfectly yesterday. I charged it overnight. It shows that it is fully charged, but my Fitbit display shows absolutely nothing. It seems like it is dead, but it shows that it is up to date and fully charged in my Fitbit app.
Hello @Nickie449
First and foremost I apologize for the late response. I understand you have tried restarting your Fitbit Alta HR but that has not resolved your issue. I would suggest trying to clean your gold colored contacts on both your Fitbit Alta HR as well as on the charger itself. Look here to see the proper way tho cleanse those contacts: https://help.fitbit.com/articles/en_US/Help_article/2005/?q=Clean&l=en_US&fs=Search&pn=1 After cleaning your contacts then try recharging your Fitbit again. If you still are experiencing issues then try again restarting your Alta HR. You may have to try this several times in a row. Many individuals either forget to press the button on the charger doing this or have difficulty finding the button. I’ll provide the correct restarting procedure here:
Here’s how:
😃 please let me know if this resolves the issue. Keep me posted
I’ve tried everything but it doesn’t work. Really like the Alta HR too. 😢
I followed the instructions on restarting my Fitbit, and it's back to life. Cleaning the contacts did nothing but pressing the button on the charging cable resolved the issue (3 quick presses with only very brief pauses between each press). Thank you!
This video solved my issues. My Fitbit was completely dead, in and out of the charger. The solution involves tapping in places where there are not obvious buttons. I was skeptical but it worked. https://www.youtube.com/watch?v=DSqr5YZ1n08
Best AnswerMy fitbit Alta is responding when I tap on it, but that is only when it is connected to the charger. Also, I keep on getting the battery with exclamation sign in it. Does it mean there is an issue with the battery of my tracker? How to get this fixed?
I am having the same issue. My Alta only works when plugged in.
Does the battery need to be replaced?
Best AnswerThis may need to happen if you are way beyond cleaning the contacts, pressing the button on the charging cable and waiting about an hour - replace the battery. Only do this if you have patience and grace, and a soldering iron.
there’s a video on YouTube that shows how to replace the battery (even for the plain Alta as well)
Best AnswerNot being funny but this is such a ridiculous answer. You’d have to be stupid not to have tried this before even posting to ask for help with the issue. Please don’t insult my intelligence.
Best AnswerI wasn’t being funny or shady here. I just shared what I knew from experience. I don’t have anything to gain by being condescending to another person in need.
