07-21-2017
09:33
20:08
07-21-2017
09:33
20:08
I have tried restarting my Alta HR several times (plugging into charger in computer, hitting button three times within 8 seconds with slight pause in between; the face goes black, then I unhook it and the charging display comes back on. Any ideas what to try next?
07-22-2017 06:30
07-22-2017 06:30
Hello @colnana08 and @WendyB, Nice to see you again in the Community! I'm wondering if you are experiencing any issue in particular that require to restart your tracker @colnana08? Is it not syncing or your tracker is not responding?
Let me know more details, I'll would be happy to give you a hand with this!
07-21-2017 21:08
07-21-2017 21:08
Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
07-22-2017 06:30
07-22-2017 06:30
07-24-2017 05:59
07-24-2017 05:59
My Alta HR and MFP are not syncing (even though I have them linked) and my Alta HR will not restart even after following directions (depress charger button 3 times within 8 seconds, resting slightly between each press). It goes to a blank screen then when I detach from charger, the charging sign comes back on.
07-26-2017 11:32
07-26-2017 11:32
My Alta HR has been having trouble syncing. Says, "Tracker not found." I restarted a couple days ago and it was fine. This morning same issue but now it won't restart. Thanks for helping in advance.
07-26-2017 23:48
07-26-2017 23:48
Hi, I am having the same problem my app isn't able to find my alta HR, do it hasn't been syncing.. Please help.. I have tried to restart the device.. Nothing has worked
07-27-2017 04:33
07-27-2017 04:33
07-27-2017 08:41
07-27-2017 08:41
Mine still won't either.
07-30-2017 17:47
07-30-2017 17:47
@colnana08 thanks for joining us in this thread. If your MFP and Fitbit accounts are having issues syncing I recommend checking out this post with helpful info about linking those two accounts. Hope this helps. Keep me posted!
@FranCC thanks for letting us know that our Support Team took care of your concerns. They are very helpful indeed and in this case scenario it was a good idea to get in contact with them.
@colnana08 I suggest re-pairing your tracker to your account once again by doing the following using your Fitbit app:
Give it a try and let me know how it goes!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
10-08-2017 03:43
10-08-2017 03:43
Have tried restart but still no response, screen not turning on
10-08-2017 06:57
10-08-2017 18:04
10-08-2017 18:04
@Lynx79 if multiple restarts dont help then contact support
Helen | Western Australia
10-09-2017 00:15
10-09-2017 00:15
10-25-2017 16:40
10-25-2017 16:40
Thanks for your input @NellyG!
@Lynx79 it's nice to hear back from you. Contacting Our Support Team was definitely a good option. What was their resolution? Do let me know!
Please confirm to me if your Alta HR is now responding as it should. Looking forward to your new comments!
07-09-2018 01:14
07-09-2018 01:14
Hello. My Alta HR is not counting Floors. I have tried to restart via the cord connected to the computer but I don't think it's working. I followed the instructions but the display only shows the charging icon.
Thanks.
07-09-2018 01:49
07-09-2018 01:49
@mptch Your Alta HR is not counting floor because it doent have the necessary parts to count floors. Because the Alta series are made small some things were not included. An altimeter being one of them.
On the restarting - if you follow the directions exactly the display should flicker and turn off, the the fitbit logo comes up and then goes back to the usual charging display. However that is not going to get your Alta HR counting floors as I said above.
07-09-2018 06:00
07-09-2018 06:00
07-10-2018 00:03
07-10-2018 00:03
Mystery solved!
When I purchased my Alta HR, I gave my old Charge to my daughter. The Fitbit App is tracking a crazy hybrid of my data and her's. That is why I have been randomly seeing flights on my dashboard. Time to get her own account 🙂
Thank you!
07-10-2018 00:31
07-10-2018 00:31
🤣🤣 that is so funny! Im glad you got it sorted!
01-05-2019 03:33
01-05-2019 03:33
Hi I also can’t get my Fitbit to restart?
