05-02-2017
06:49
20:08
05-02-2017
06:49
20:08
I purchased the Alta HR and set it up on the dashboard with my iPad Air 2. Everything worked fine on April 30. Since then it will not sync. I have tried a hard start on both the tracker and iPad, tried to sync on my iPhone, and tried disconnecting everything and tried it again. I have not removed the tracker and reentered it on the app. Should I do that? Is this all a part of what Fitbit is working on? Thanks
10-10-2017 23:44
10-10-2017 23:44
Thanks CaroleS2. After the first try on my Mac, it didn’t work when I tried again later. I gave up trying after that until a short while ago. Seems like they’ve finally fixed the problem and I just managed to sync my iPhone.
10-11-2017 08:59
10-11-2017 08:59
10-16-2017 18:30
10-16-2017 18:30
Thank you! It's been driving me mad having to shut down phone and iPad! Have just reinstalled the App and the update started immediately!
10-30-2017 18:28 - edited 11-30-2017 16:44
Hi everyone!
@JP-SG @CaroleS2 @MaG22 thanks for your reports, I'm glad to see that your trackers are now properly syncing. If you were to encounter any other issues, feel free to post back.
On a different note, I'd like to invite you guys to our Lifestyle Discussion Forums. There are lots of interesting topics; my favorite is "Eat Well" since I love food!
Hope to see you around more often!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
11-02-2017 19:22
11-02-2017 19:22
I have the Alta Fitbit and have created the account, downloaded the app but cannot get it to sync
11-02-2017 19:35
11-02-2017 19:35
I have exactly the same problem with a 2 week old Alta HR. This has to be a software problem with Fitbit. I don't know whether or not they are solving it, but they won't admit it is a problem
11-02-2017 23:21
11-02-2017 23:21
Have you tried pressing the button 3 times on the lead? Also I have to deactivate my other blue tooth device to allow syncing... and I did delete the app and reinstalled, it worked but wasn’t recommended by FB. Hope these experiences help!
11-03-2017 04:57
11-03-2017 04:57
11-03-2017 06:30
11-03-2017 06:30
11-12-2017 05:25
11-12-2017 05:25
I tried that - to no avail.
When I shut off bluetooth on the phone and then turn it back on, it claims "no devices found"... so it isn't detecting the alta.
11-12-2017 08:49
11-12-2017 08:49
This solution doesn't work for me. What else can we try?
11-12-2017 08:56
11-12-2017 08:56
Sorry to hear that... what I did was to disable Bluetooth on my laptop, did the syncing (watch to phone) then when that was complete, turned the Bluetooth on the laptop back on again. It appears to get confused with sharing Bluetooth. Other than that, you could email them...
Sent from my iPhone
11-12-2017 09:00
11-12-2017 09:00
11-30-2017 16:58 - edited 11-30-2017 16:59
Hello guys! I've seen that some of you have been having issues trying to sync your Alta HR trackers. I'll leave here some troubleshooting steps, I hope you find these steps helpful!
First, let's start with a restart; then I suggest taking a look at this post and attempt the troubleshooting shared in there. Hope this helps, keep me posted!
12-16-2017 15:49
12-16-2017 15:49
My Alta hr stopped syncing with my iPhone today. I've had it about a week. Tried turning Bluetooth on and off. I don't want to lose all my data by reinstalling the app because I have 2.5 years of data from my original Alta. What can I do?
12-16-2017 15:57
12-16-2017 15:57
12-16-2017 23:25
12-16-2017 23:25
12-19-2017 16:36
12-19-2017 16:36
Thanks for your inputs guys @Topaz99 & @MaG22!
Welcome aboard @Turtlesalute! Hey, give a try to these troubleshooting steps before deleting your Fitbit app. Those steps are specifically for iOs devices. Good luck and keep me posted!
12-20-2017 06:02
12-20-2017 06:02
Syncs with my iPad but not with my phone. Can’t find the Bluetooth. (My iPad has no trouble finding it, and the phone then syncs through the cloud.). This started when I updated to iOS 11.something.
12-21-2017 17:54
12-21-2017 17:54
@Bbrie thanks for joining us in this thread! That definitely doesn't sound like normal behavior. Please make sure that your app is running its latest version. Also, if your Fitbit device won't sync to another device or computer, it could be because of the Bluetooth bond.
If you receive call, text, or calendar notifications on your Fitbit device, your device has a Bluetooth "bond" with the phone or tablet that sends the notifications. This bond prevents the Fitbit device from syncing with another phone, tablet, or computer.
To quickly and temporarily disable the bond, turn off Bluetooth on your phone or tablet. You can turn it back on later to resume syncing.
If that doesn't do it, then I suggest giving the set up process a try by doing the following:
If you've done this to no avail, please check this article for further troubleshooting: Why won't my Fitbit device sync?
