05-02-2017
06:49
20:08
05-02-2017
06:49
20:08
I purchased the Alta HR and set it up on the dashboard with my iPad Air 2. Everything worked fine on April 30. Since then it will not sync. I have tried a hard start on both the tracker and iPad, tried to sync on my iPhone, and tried disconnecting everything and tried it again. I have not removed the tracker and reentered it on the app. Should I do that? Is this all a part of what Fitbit is working on? Thanks
12-21-2017 18:19
12-21-2017 18:19
12-21-2017 20:25
12-21-2017 20:25
12-22-2017 03:34
12-22-2017 03:34
12-26-2017 12:06
12-26-2017 12:06
I'm happy to read that you guys are back on track @Bbrie & @Turtlesalute! Thanks for sharing this with the rest of the community too. This is what the Community is all about: sharing solutions and Fitbit knowledge. Keep it up!
@CaroleS2 please note that your mobile device needs to be listed as compatible on fitbit.com/devices for it to be properly linked to your Alta HR and to receive notifications. If your mobile device is compatible, then I recommend checking out these articles:
I really hope this helps. Keep me posted!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
12-27-2017 12:08
12-27-2017 12:08
12-28-2017 15:22
12-28-2017 15:22
@CaroleS2 please note that Call & Text Notifications only work if you have your Alta HR linked to a compatible mobile device, not a computer.
Are you referring to Call & Text Notifications or Reminders to Move? Do clarify this info for me.
I'll be looking forward to your new comments!
12-29-2017 05:23
12-29-2017 05:23
01-01-2018 13:20
01-01-2018 13:20
Sorry about the misunderstanding, I though you were referring to Notifications because you mentioned it here in this post @CaroleS2.
I'll go ahead and create a case on your behalf for our Support Team so they can further troubleshoot this with you. Keep an eye on your inbox!
Just as a friendly reminder that the syncing issues with our PC might be caused due to the fact that if you receive call, text, or calendar notifications on your Fitbit Alta HR, your Fitbit has a Bluetooth "bond" with the phone that sends the notifications. This bond prevents the Fitbit Alta HR from syncing with another phone, tablet, or computer.
To quickly and temporarily disable the bond, turn off Bluetooth on your phone or tablet. You can turn it back on later to resume syncing.
01-02-2018 03:48
01-02-2018 03:48
@"MariamFitbit wrote:This bond prevents the Fitbit Alta HR from syncing with another phone, tablet, or computer.
To quickly and temporarily disable the bond, turn off Bluetooth on your phone or tablet. You can turn it back on later to resume syncing."
I am also stuck in sync hell with my new Alta HR.
Rather than having to turn off phone Bluetooth, why can't it use the same internal logic as my old Surge which seemed very happy to synch to a multiplicity of devices. Notifications etc worked fine on that too, unlike the Alta, and it also managed to reliably detect outdoor biking.
02-07-2018 17:50
02-07-2018 17:50
Mine isn’t working as well. I have tried restarting my device and turning Bluetooth off and on but it says it’s dead and syncing won’t work.
thanks
04-18-2018 10:28
04-18-2018 10:28
@MariamV wrote:Hello guys! I've seen that some of you have been having issues trying to sync your Alta HR trackers. I'll leave here some troubleshooting steps, I hope you find these steps helpful!
First, let's start with a restart; then I suggest taking a look at this post and attempt the troubleshooting shared in there. Hope this helps, keep me posted!
I have tried all of the above troubleshooting steps and downloading the software again. Hi
I got a Fitbit Alta HR for Christmas and it won’t sync I have tried turning it off and resetting the software, I have tried to reinstall the app and I have also tried turning on:off the data:Bluetooth to see if this would resolve the problem but it just keeps saying looking for Fitbit.
Can someone please help with this. Thanks
04-18-2018 10:30
04-18-2018 10:30
05-09-2018 14:01
05-09-2018 14:01
I've tried deleting the app and logging back in my Fitbit will still not sync it worked last week
06-21-2018 05:35
06-21-2018 05:35
I purchased the Alta HR and installed the Fitbit app on my Windows phone. It worked the first week with the sync and all, but I noticed the bluetooth connection started to reboot or something, making my fitbit app not syncing correctly or losing its recently synced data. After a week it stopped being able to sync completely.
I solved this by syncing using bluetooth to the fitbit app on my computer, and the phone synced from that data over wifi.
It may be a fault in the windows OS for windows phone of older models. My phone is a Lumia 1520. I can see heartbeat and immediate data on the phone as I am out walking and I can interact with the fitbit Alta HR, but not reliably and with several seconds delay at starting the app or just checking my fitbit app fast. The complete daily syncing using bluetooth between my Alta HR and the phone no longer works it seems and if I do not use the computer as intermediary, there will never be any sync.
12-04-2019 14:08
12-04-2019 14:08
I've bought many fitbit devices (at least five) and at first I loved the Alta HR...until it quit syncing. I do everything the menus say to do, have the phone set for continuous everything, but getting the device to sync is like begging, pleading, nagging and mostly being ignored. Usually what it says is "device not found" but often it appears to sync, yet changes none of the data. What's the point of wearing it? Epic fail, fitbit. Yes, I've tried all that you suggest in the help section, including updating, uninstalling/reinstalling, etc. Nothing works consistently. It's especially useless when I am away from my home computer.
12-04-2019 14:25
12-04-2019 14:25
12-05-2019 05:22
12-05-2019 05:22
12-05-2019 07:08
12-05-2019 07:08
I tried "unpairing" it from my computer but that did not help. I removed the dongle so I know it couldn't be communicating directly with the computer. This didn't help, though. My last sync was yesterday afternoon and even when I hold the phone in my hand and hit "sync" in the app, the wheel turns for a minute and I get a red exclamation point. No clue from the device why it won't sync.
12-05-2019 07:12
12-05-2019 07:12
12-05-2019 07:15
12-05-2019 07:15
I try both (holding phone and/or computer less than two inchs from the fitbit) and it still won't work. I couldn't add up the cumulative amount of time I've spent trying to get it to sync. Technology of any kind seems to have compatibility issues built into the updates. I'm starting to think this may be intentional since various tech support people I've contacted over the years for different products always encourage me to buy a new device/computer/app etc. Manufacturers want to keep us buying. The fact that this has gotten much, much worse over time (the Fitbit is almost three years old) and that support for older devices is all but nonexistent seems to reinforce the idea that we can't expect anything to last very far beyond the next new product or update.
