05-02-2017 06:49 - last edited on 08-20-2020 20:08 by MatthewFitbit
I purchased the Alta HR and set it up on the dashboard with my iPad Air 2. Everything worked fine on April 30. Since then it will not sync. I have tried a hard start on both the tracker and iPad, tried to sync on my iPhone, and tried disconnecting everything and tried it again. I have not removed the tracker and reentered it on the app. Should I do that? Is this all a part of what Fitbit is working on? Thanks
02-07-2020 18:31
02-07-2020 18:31
Hi there, My Fitbit Syncing smartwatch to phone it's not work to call and text?
02-07-2020 21:33
02-07-2020 21:33
I had to reboot my Alta HR using the button on the charging cable. Now it syncs.
02-21-2020 04:19
02-21-2020 04:19
I have had the same issues with Mr Alta hr not syncing and getting the message tracker not found. I have deleted and repaired it so many times, as recently be as last night and this morning it will not pair again. This is something that Fitbit needs to fix. I will try to reset my device but does that mean I will loose the data on it?
02-21-2020 04:22
02-21-2020 04:22
