08-01-2019
07:44
20:08
08-01-2019
07:44
20:08
My device is recording my heart rate as usual but it is no longer showing my average bpm and time in each heart rate zone associated with logged exercise. I am syncing with my iPhone SE.
03-07-2020 13:54 - edited 03-09-2020 22:01
DMe too. All they have to do is look at any account and see that we all were able to track HR snd calories burned when we logged exercise data manually up until this latest update. Now it does not work. It says “null” or “Not enough data available” and yet if you click on HR it shows exactly what your HR did during the exercise you are trying to log in so the data is there. It’s just not pulling over. When you manually log in an activity I noticed it also says “0 steps” yet the Alta has been recording steps throughout the exercise and the total step count reflects those steps. This is a major issue and Fitbit is trivializing it or downright lying about it, saying we never could track these things on manual logging when we know we could until the latest update
03-10-2020 17:31 - edited 03-10-2020 17:32
Dddonna and Colqueen, the problem started end of July 2019. Fitbit admits it's a known software problem and constantly states they "are working to solve it". They aren't or it would have been fixed after seven months.
It has nothing to do with Leap Year.
03-11-2020 06:36
05-03-2020 15:10
05-03-2020 15:10
I am new to Fitbit. I specifically got the HR so I could track and record my heart rate and now I'm finding that when I go running it does not record it. Only distance, pace etc. Did I buy the wrong thing? Surely this is something it should do? It reads my heart rate and tells me my resting HR when I sleep (which I don't care about at all) but doesn't record it during the day or when I'm exercising.
Am I doing something wrong? I've used it now so I don't think I can return it.
Best Answer05-03-2020 15:24
05-03-2020 15:24
Best Answer05-03-2020 15:58
05-03-2020 15:58
Best Answer05-04-2020 00:13
05-04-2020 00:13
Best Answer05-04-2020 09:44
05-04-2020 09:44
Hi, Colqueen. Where do you check to see if your app is up-to-date? I received notification about three weeks ago that the app updated, but my heartrate tracking still isn't working unless I use autodetect excercise. But of course with autodetect, no GPS.
Just want to make sure I'm looking in the right place before contacting support. Thanks!
Best Answer05-04-2020 11:38
05-04-2020 11:38
Best Answer05-05-2020 13:33
05-05-2020 13:33
Thank you, Colqueen! You may be tech illiterate, but you certainly knew more than I did. I did have the Fitbit app on my phone ready with an update from April 28. I've downloaded it and will use GPS on a walk this evening and see what happens. Fingers crossed!
Best Answer05-05-2020 19:17
05-05-2020 19:17
Best Answer05-14-2020 19:32
05-14-2020 19:32
So I updated the app and have used the GPS tracker. The good news is that there is now a bar on the completed map that shows "Default", "Heart Zones", and "Pace". The bad news is that I'm consistantly getting a message "Not enough heart rate data available". So while we supposedly have heart rate information available with GPS again, it doesn't work.
05-14-2020 19:43
05-14-2020 19:43
07-04-2020 17:12
07-04-2020 17:12
Yesterday I discovered that there IS heart rate information available with GPS for the Alta HR. When you go to your dashboard, click "Excercise" and swipte left four times on the upper portion of the screen. There is a verticle bar graph with your stats.
Not as easily accessable as it was previously and a little hard to read in my opinion, but there it is.
Best Answer07-04-2020 17:44
07-04-2020 17:44
No. Not on my app. Just shows not enough heart rate data available. Just best to give Fitbit a miss these days as the app doesn't support the tracker in a meaningful way and they clearly have no intention of fixing it.
07-04-2020 17:48
07-04-2020 17:48
Return it. It is falsely advertised. Fitbit app has not recorded heart rate data in gpsbtrecked exercise since last July
07-05-2020 12:37
07-05-2020 12:37
"No. Not on my app. Just shows not enough heart rate data available. Just best to give Fitbit a miss these days as the app doesn't support the tracker in a meaningful way and they clearly have no intention of fixing it."
jellyjud, I get the same message when I click on:"HEART ZONES: on:the map with the options of "DEFAULT", "HEART ZONES", and "PACE".
Don't click on the map,click on the upper area just above the map that shows "_ of _days" for the week, the area that will close the circle around the running man when you've completed the week. Swipe left 4 times to get to "Excercise in Heart Rate Zones (minutes)." You'll find your vertical graph there.
It would be so much more helpful to have it come up on the map but I believe this is as far as Fitbit is going to go in restoring our capabilites from the July 29, 2019 update that removed this feature.
Best Answer07-05-2020 14:33
07-05-2020 14:33
No. That is not useful. I want the heart rate data for my run. Not for the whole day, I have always been able to access the whole days data
07-06-2020 07:41
07-06-2020 07:41
Agreed; I have always been able to see this worthless bar graph also. I want to see the breakdown by exercise, as we could before July 2019 change. And today my manually started GPS walk didn't even track the route/miles (stuck on .03)...it's getting **ahem**tier & **ahem**tier...lol. Just waiting until this tracker finally quits and will move elsewhere. Unhappy with fitbit. I can do an hour of Camp Gladiator workout and follow it with an hour walking my dogs. It recognizes and gives me Active minutes, but won't call it an Exercise. So after two hours of work, I get no credit for an exercise for the day and end up missing my 5-a-week goal. SO, that why I manually start my exercises, but get no HR data. Not very motivating at all, just frustration.
11-24-2020 14:59 - edited 11-24-2020 15:01
I also noticed that the exercise zone breakdowns disappeared for my older fitbits. I'm talking about the single horizontal bar representing an exercise session that is broken into various zones (below zones in blue, fat burn in yellow, caridio in orange, peak in red, etc). I've always used multiple trackers (I use a Charge 2, a Blaze, an Alta HR and a Versa), and I would get this exercise summary regardless of which one I used. But now I get the breakdown only when I use the Versa, but not on my older models. No matter how hard I get pumping, when I'm wearing an older tracker the horizontal bar is solid blue telling me I've been below zone. Request that Fitbit restore this please!
