10-02-2016
04:20
18:17
10-02-2016
04:20
18:17
My Alta suddenly stopped working and now just has a battery symbol with an exclamation mark in the middle. Can anyone help?
12-31-2017 07:35
12-31-2017 07:35
I'm having the same issue. My Alta has worked beautifully for several years, and I've been very happy with every fitbit product I've had. That said, mine is still "working" on my app, just not the Alta itself. I've tried the restart, is there something else I can try? What does the symbol mean?
Best Answer12-31-2017 08:08
12-31-2017 08:08
Best Answer12-31-2017 12:03
12-31-2017 12:03
I charged last night and my phone app shows it completely charged. I'll have to contact customer service. Thanks for the reply!
Best Answer02-23-2018 07:49
02-23-2018 07:49
What does this mean?
Best Answer02-25-2018 04:15
02-25-2018 04:15
The exclamation symbol just means the battery has gone too low, you can try resetting it by plugging it in and pressing the reset button, however this does not always work first time and can be very frustrating.
I would recommend just putting the alta fitbit on to charge and leaving it for around 30-45 minutes after which time you should see that the alta fitbit is now charging. This happens to me regularly as I forget to check the battery status. Really hope this helps as I know from experience how annoying it is and feeling utterly defeated ![]()
Best Answer06-26-2018 02:15
06-26-2018 02:15
Thanks this worked for me
Best Answer06-26-2018 02:46
06-26-2018 02:46
10:00
- last edited
yesterday
06-28-2018
10:00
- last edited
yesterday
Welcome @Treebee74! Thanks for letting know that you are back on track. I'd like to kindly advise you to vote for @Tikki7’s post if it was of help.
Votes contribute to a positive reputation in the community. Earning votes and giving votes also factors into the Community Rank and the possibility to land a spot on the Most Helpful Authors list, located at the bottom right of every discussion category page.
Catch you later! 🙂
07-02-2018 11:04
07-02-2018 11:04
I have read the messages about fit bit Alta showing a battery with an exclamation mark. I tried resetting and it didn't work. Now I only get black screen (a couple days later). Is there anything else I can try or is it just done?
Best Answer07-02-2018 11:13
07-02-2018 11:13
07-02-2018 16:49
07-02-2018 16:49
07-02-2018 21:36
07-02-2018 21:36
10:30
- last edited
yesterday
07-03-2018
10:30
- last edited
yesterday
I appreciate your help @Treebee74, @indiarose, and @Tikki7! Welcome to the Forums @Renemc! Thanks for sharing your experience with your Alta.
Since your Alta is not lighting up the best is to ensure if the battery is charging. To do so, please make sure to follow these tips:
Keep me posted! 🙂
07-09-2018 11:20
07-09-2018 11:20
I am having the same problem. I have done all instructions in this post for a few times. The app says that the Alta is fully charged and Synced! But the new Device number doesn't appear when I try to set it as a new one. No matter what I do and how often I am doing it. Please, help!
Best Answer07-09-2018 21:10
07-09-2018 21:10
Best Answer07-28-2018 03:04 - edited 07-28-2018 03:05
This happened to me a while ago. I tried a few different things and it turned out to be that the charger wasn’t clipping in properly because the Fitbit was dangling and not laid flat whilst it was charging.
Best Answer08-17-2018 14:02
08-17-2018 14:02
Maybe I’m crazy but for the life of me I can’t find a button on the charger.
Best Answer08-17-2018 23:22
08-17-2018 23:22
08-18-2018 00:10
08-18-2018 00:10
@Cherielynn422 As @Tikki7 says it is on the plastic housing on the USB end of the cable rather than the clip end. Let us know if younstill cant find it.
Helen | Western Australia
08-20-2018 17:49
08-20-2018 17:49
I had this problem starting immediately after my 1-year warranty expired. Fitbit refused to troubleshoot beyond the basic instructions included in this post, or to replace my device. When I said that it was ridiculous that the device stopped working after a year, and, conveniently, right after the warranty expired, a manager told me that they "make no guarantees" about the lifetime of their products. Keep that in mind before spending $100 on another Alta! Very disappointed in this company and product.
