03-10-2016 10:23 - last edited on 08-20-2020 18:43 by MatthewFitbit
So you've got yourself an Alta and are wondering "where's the button?" Check out how to interact with Alta!
You have 2 options to view the time on your Alta.
To view your daily stats just use Quick View to bring up your clock and then single tap the Alta where the band and tracker meet (as seen in image below) to toggle between your steps, distance, calories burned and Active Minutes stats.
Alother way to do this is to double tap on the Alta to bring up the clock and then single tap the Alta where the band and tracker meet to toggle between stats.
With a bit of practice, you'll find the best way to tap on your Alta. We advise aiming toward the bottom of its display, and not tapping too hard or too softly. You shouldn't have to hit it with any significant pressure, but you should feel the tap lightly on your wrist.
Make sure to give your device time to react - you shouldn't ever be tapping more than once or twice per second, and may need to pause a moment after your tap before you see the device react. If you're having trouble, try slowing down your taps.
Video below:
11-07-2016 09:22
11-07-2016 09:22
Exactly! Tapping at the band worked for me on the first try after multiple tries of various taps, pressure, standing on my head. Barbara
11-07-2016 13:40 - edited 11-07-2016 13:40
@Bridget41 Tapping where the band meets the tracker, as shown here, is the ideal location when interacting with the Alta. I promise that standing on your head is not a requirement.
11-07-2016 13:52
11-07-2016 13:52
11-08-2016 11:36
11-08-2016 11:36
@Saaaypants21 If your Alta is unresponsive to taps or charging, I recommend getting in touch with our Support Team and letting them know of your experience. I am confident that our team will be able to help provide you with further options for getting you back on track.
11-29-2016 06:13
11-29-2016 06:13
11-30-2016 14:54
11-30-2016 14:54
@Pamaseeta Have you attempted to interact with the Alta with the recommended tips here? Let me know if the display lights back up.
12-01-2016 20:36
12-01-2016 20:36
Tyring to detup my Alta on my account that I created before to replace my flex. Where is the tracker button? Nothing I do seems to make it interact with the setup process.
12-06-2016 14:55
12-06-2016 14:55
@KaylaCTK The tracker button is at the top of the Fitbit app Dashboard. I recommend trying out the official setup instructions as well.
Check out my screenshot with the tracker tile outlined in red below. Hope that helps to clarify.
12-12-2016 14:09
12-12-2016 14:09
I have the exact same problem. Tap works fine when plugged in but no response when not. FRUSTRATED!!
12-13-2016 12:51
12-13-2016 12:51
@RoxanneK Let's try restarting the Alta and then giving the tap interactions as explained here another try. Let me know if that helps.
12-23-2016 19:34
12-23-2016 19:34
What do I do to set my alta up to recognize incoming texts and phone calls? It said to go into setting's in the app and I did with no luck.
12-26-2016 10:56
12-26-2016 10:56
my Alta fit bit only shows the time, nothing else. also it does not respond to taps, I only get the time when I turn my wrist.
is it me or is the fit bit not working correctly?
12-29-2016 15:14
12-29-2016 15:14
I ended up sending it back for a replacement. Never would work.
01-01-2017 17:08
01-01-2017 17:08
I feel the same way as this is the most frustrating item I have had in a long time. Does not seem worth the time and trouble. Good luck. I am ready to throw in the towel
01-02-2017 18:20
01-02-2017 18:37
01-02-2017 18:37
Ditto
it may as well be completely in a foreign language. Impossible to navigate and understand. Such a shame. Looks like a good product if it worked.
01-04-2017 14:28
01-04-2017 14:28
@Jenjen81 Check out the full instructions for setup of notifications for mobile devices here.
@TuckiesMom I recommend restarting the Alta with the instructions here. Once you've completed the restart process, I recommend attempting to tap and interact with the Alta again once you completed the restart. Let me know if that helps.
01-05-2017 08:48
01-05-2017 08:48
Tapping or turning my wrist just does not work. It displays nothing. I think I need to return this.
01-06-2017 09:38
01-06-2017 09:38
@Profit I recommend restarting the Alta and then giving it another try. Let me know if these tips help get you back on track.
01-06-2017 10:35
01-06-2017 10:35
