03-10-2016
10:23
18:43
03-10-2016
10:23
18:43
So you've got yourself an Alta and are wondering "where's the button?" Check out how to interact with Alta!
You have 2 options to view the time on your Alta.
To view your daily stats just use Quick View to bring up your clock and then single tap the Alta where the band and tracker meet (as seen in image below) to toggle between your steps, distance, calories burned and Active Minutes stats.
Alother way to do this is to double tap on the Alta to bring up the clock and then single tap the Alta where the band and tracker meet to toggle between stats.
With a bit of practice, you'll find the best way to tap on your Alta. We advise aiming toward the bottom of its display, and not tapping too hard or too softly. You shouldn't have to hit it with any significant pressure, but you should feel the tap lightly on your wrist.
Make sure to give your device time to react - you shouldn't ever be tapping more than once or twice per second, and may need to pause a moment after your tap before you see the device react. If you're having trouble, try slowing down your taps.
Video below:
08-10-2016
06:30
13:11
ErickFitbit
08-10-2016
06:30
13:11
ErickFitbit
You are a good person!
Moderator edit: removed personal info
08-18-2016 17:50
08-18-2016 17:50
08-19-2016 01:53
08-19-2016 01:53
08-19-2016 13:14
08-19-2016 13:14
@DaniDobek As @Julia_G mentioned above, that is currently not a supported feature, but I do recommend voting for this existing idea in our Feature Request board if you'd like that to be made into an option.
08-22-2016 18:31
08-22-2016 18:31
08-23-2016 12:49
08-23-2016 12:49
08-26-2016
09:10
12:36
08-26-2016
09:10
12:36
@GYMNSTXNUT Welcome to the community!
QuickView takes a bit of practice at first but I believe in you! Check out some tips that I shared here, which you may find helpful in improving your QuickView response. Let me know if that helps.
@Slevy8301 Thanks for sharing your update, I appreciate that. Glad to hear everything is back to normal. Happy Friday!
08-29-2016 22:13
08-29-2016 22:13
I just got the Alta and no matter what I do, I can not get the quick view function to work. Frustrating!
08-30-2016
12:21
12:36
08-30-2016
12:21
12:36
@suzlituchy, have you got this sorted yet? If not, first off, make sure quick view is actually turned on. You need to do this in your settings, but make sure you then sync your Alta, because changes in the settings won't be communicated to your Alta until you have synced.
Once you are sure it is turned on, just practice different wrist movements until you get the hang of it. I do find that on my Fitbits QuickView doesn't always work. You need to do a slightly exaggerated lift and twist movement to trigger it.
08-30-2016 14:14
08-30-2016 14:14
Thanks so much for your response, Julia! I turned the fitbit around on my wrist and now quick view works a good amount of the time. The tapping is still hit or miss for me, even if I tap it where the band meets the display. I don't know why they didn't just put a button on it!
08-30-2016 14:22
08-30-2016 14:22
@suzlituchy, glad it is mostly working for you!
10-09-2016 11:50
10-09-2016 11:50
10-10-2016
17:03
12:36
10-10-2016
17:03
12:36
@msg7b Welcome to the Community!
If you feel that your Alta isn't responding to the tips and tricks shared here, I recommend getting in touch with our Support Team. I am confident our team will be able to provide you with further options for getting back on track.
10-19-2016 22:32
10-19-2016 22:32
I've had my fitbit alta for months and love it. Unfortunately, I had trouble syncing it. Once I solved that problem (by restarting it), the only thing that my wristband will display is a battery with an "!" in it. It is fully charged. Help!
10-24-2016 12:58
10-24-2016 12:58
@mccolin Thank you for trying out the tracker restart troubleshoot. If you're still experiencing the issue where the "!" is displayed on the tracker, I recommend getting in contact with our Support Team. I am confident that our team will be able to further assist you and help get you back on track. Keep me updated.
10-30-2016 13:57
10-30-2016 13:57
10-30-2016 14:29
10-30-2016 14:29
@mccolin, restarting will not normally have any effect on your battery. However, the original issue could easily drain your battey -- a restart will stop any background processes that are causing battery drain.
10-31-2016 13:02
10-31-2016 13:02
@mccolin Thanks for confirming that restarting the Alta was able to resolve the issue you experienced. As @Julia_G said, the restart should not drastically affect the battery level of your Alta.
11-01-2016 10:06
11-01-2016 10:06
11-02-2016 12:10
11-02-2016 12:10
@Saaaypants21 Thanks for trying to restart the Alta. If it's not responsive to charging or the restart process, I recommend getting in touch with our Support Team and letting them know the details of your troubleshooting efforts and experience. I am confident that our team will be able to help provide you with suitable options for getting back on track.
