03-10-2016 10:22 - last edited on 08-20-2020 18:43 by MatthewFitbit
Alta comes with the ability to set up and receive call, text, and calendar notifications on iOS and Android.
This post will provide instructions on how to setup your alerts so that you can see who's texting you, the content of the messages, who's calling, and what your calendar has on deck for you. For a detailed overview of alerts for Alta, please see this help page.
You can view your notifications when they come in by using Quick View or by double-tapping the Alta where the band and tracker meet.
Notes:
09-02-2016 11:12
09-02-2016 11:12
@Rizzle2008 The Samsung Galaxy S7 Edge has all the hardware requirements (awesome looking phone) to be a supported device but is currently not on our list of supported devices. This means that our Android team has not yet tested it for compatibility and added it to the list. If the device supports BLE (AKA Bluetooth 4.0), I recommend giving the setup flow a try.
If that does not work, I suggest setting up and syncing via a device listed as supported or using a computer. Our team is always working to test and add more Android devices to the supported devices list, so keep an eye open for updates!
03-12-2016 11:19
03-12-2016 11:19
03-13-2016 07:31
03-13-2016 07:31
When I receive a text msg it vibrates but does not display anything. I can see 3 notifications in the app. When I receive a call it does display the caller.
03-14-2016 10:14
03-14-2016 10:14
When I get a text message it does vibrate, I tap twice and it shows who the message is from & that I have 1 message. But there is no content of the message. Is the message itself suppose to show up as well?
03-14-2016 11:31
03-14-2016 11:31
03-14-2016 12:54
03-14-2016 12:54
@Mackendzei @Trish26 What model phone are you using? And can you confirm that you've enabled Text Notifications in the Fitbit app, selecting the desired notification source?
@MarusiaC @Krogerman Receiving a notification will not automatically illuminate the screen. When you feel the vibration, you can use Quick View or a double-tap to activate your Alta and view the content of the notification itself.
03-14-2016 17:23
03-14-2016 17:23
@MatthewFitbit wrote:@Mackendzei @Trish26 What model phone are you using? And can you confirm that you've enabled Text Notifications in the Fitbit app, selecting the desired notification source?
I have a Motorola Droid Turbo. Yes, I went through the steps that Erick listed above and everything is selected to enable.
03-14-2016 17:44
03-14-2016 17:44
03-14-2016 17:51 - edited 03-14-2016 18:57
I have a Motorola Droid Turbo, Android Ver. 5.0 . I also use Message+. And yes I have enabled notifications.
03-14-2016 20:13
03-14-2016 20:13
I just received my Alta today and have not been able to get the notifications to work. It's the main reason I purchased the unit. Moto-X with Android 5.XX. Really frustrating as all settings are set correctly in the fitbit app. Tried everything suggested by the site. Any ideas on what I should do?
03-15-2016 06:51
03-15-2016 06:51
I am not sure if the Alta is the same, but I do know that with the Blaze, you have to use Message not Message+ for the text to come through.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
03-15-2016 09:48
03-15-2016 09:48
I'm wondering the same thing. I get notification that I have a text but the actual message does not scroll through. I tried searching for answers but unable to get an answer if only the notification is available on this device or if the full message is suppose to display. I'm using the Samsung S6 Edge+ phone.
03-15-2016 09:51
03-15-2016 09:51
03-15-2016 10:04
03-15-2016 10:04
Thank you!! I'll give that a shot 🙂
03-15-2016 11:45
03-15-2016 11:45
@Trish26@sandyh121 Thanks for trying out the set up steps that I provided. I have a workaround for you here as this issue is related to Message+ not playing well with our app. Let me know if that helps.
@Mackendzei Thanks for the update! Glad to hear that switching to the stock Android messaging app resolved the issue for you!
@SShannon Have you tried restarting your Alta with these steps? If not, give that a try and then attempt to send yourself a text from another phone to see if you receive the notification.
If that doesn't work, which text messaging app are you using as the default?
03-15-2016 12:41
03-15-2016 12:41
Thanks Erick for your help! Appreciate it! I had already read another posters remedy by changing setting to "Messenger" instead of "Messenger+ . Seems to be ok now!
03-15-2016 13:52
03-15-2016 13:52
03-15-2016 14:23
03-15-2016 14:23
03-15-2016 14:24
03-15-2016 14:24
I'm having the same problem with my Samsung S6. 😞 It's on "Messages" not Message+ or Hangouts. Messages is enabled. I didn't require encryption. I don't know what I'm doing wrong.
03-15-2016 16:42 - edited 03-15-2016 16:42
@Trish26 Perfect! Glad to know you were able to find another users response helpful!
@L_Rich Check out my previous post on this same topic here. That should direct you to the instructions to help get you up and running.
@SShannon Did you see my response here? That should help get you up and running.
@msteinheb I recommend confirming that you have granted access to the Fitbit Notification Service as shown here. If you've already granted access, toggle it off and on and then attempt set up again.
