03-14-2016 13:19 - edited 08-20-2020 18:43
One of the trickiest parts of getting started with a brand-new wristband tracker is simply learning how to get it clasped properly. The following post can help you with that!
How do I clasp my Alta wristband more easily?
We're confident that you'll be able to get your alta clasped with just a little practice. Don't be discouraged if it's difficult at first - it definitely gets easier over time!
How do I change my Alta wristband?
Fitbit Alta's wristband is detachable from the top and bottom of the tracker, so that you can replace it with accessory bands of different color or material. For help with detaching your Alta's wristband, check the steps in this help article, or watch the video below.
05-08-2016 13:21
05-08-2016 13:21
@Nurseanne wrote:
I personally wouldn't like a buckle. My hubby has a HR and I sometimes wear it. I don't like this... I love my ALTA!!!!!
Me too!!! I wouldn't want a buckle either. A buckle would only give the Alta a larger profile, and I like the less bulky look. The Alta has been redesigned to make it secure, based on customer suggestions. It does take some work to get it "broken in" for the first few times it's snapped on, but after that, you just have to make sure the prongs are "popped in" securely. The band doesn't have as much overlap as previous bands, so it doesn't catch on things very easily. I'd have a hard time having my Alta come off unexpectantly.
05-10-2016 15:07
05-10-2016 15:07
@erikal2119 Thank you for the feedback and for sharing what you did to get the clasp on. We're always working on improving our products and features and greatly appreciate your input!
@GabinkaP Were you able to get the setup process? If not, I suggest restarting the Alta and then giving the setup process another try. Let me know how everything goes.
05-11-2016 05:07
05-11-2016 05:07
05-11-2016 05:45
05-11-2016 05:45
I have the same problem.
05-11-2016 09:31
05-11-2016 09:31
05-11-2016 20:02
05-11-2016 20:02
05-12-2016 08:00
05-12-2016 08:00
05-12-2016 16:22
05-12-2016 16:22
@SunsetRunner @Catmusicat @OneEmi Have you checked out the tips for getting the clasp on here, yet? Also, check out the tips for "Interacting with Alta." That will explain how to tap the Alta or use other features to view the display.
@OneEmi Thanks for the feedback and suggestion, it is greatly appreciated!
@tvman11 If you experience issues with the Alta coming undone, feel free to reach out to our Support Team and share pictures of what's happened to the band with as much detail as possible. I am fully confident that our team will be able to provide you with some further options to help get you back on track.
05-14-2016 13:16
05-14-2016 13:16
THANK YOU !!! Great tip with the olive oil.....I was gettting so frustrated that I almost sutfed itback in the box and returned it. Now that I got it on, lets see how this thing works!!
05-14-2016 14:50
05-14-2016 14:50
I made the mistake of opening & setting up my Alta at 8PM two nights ago. Very excited because it would sync with the app already on my android. Then I discovered I couldn't put it on my wrist. WTW?! Obviously, you should not do this when you're at the end of a stressful day.
After texting my daughter-in-law next day, who has a bigger version, but is very smart, I tried her suggestion of softening the band with hot water. Worked like a charm--until I took it off the next morning.
Of course I'm not going to give it the water treatment again & again.
I stopped fussing with it and turned my attention to 'how to remove the fitbit'; this produced unexpected results. A little experimentation and I discovered that all I had to do was Take the Fitbit Off (one side only). Then I could attach the little buttons with ease at whatever size appropriate for my wrist; next step: hold the Fitbit in place and simply reattach it to the wristband. Snap!
I anticipate feedback as to the inappropriate use of the wristband-Fitbit closures...however, my answer is that it will not be any more abusive than taking off the Fitbit to change bands for a party. Plus I think the holes on the band will eventually be easier to snap in place, so I may go back to the original instructions.
For now, I'm enjoying my "end run" around what seems to be an endemic problem.
05-14-2016 17:32
05-14-2016 17:32
05-15-2016 15:47 - edited 05-15-2016 15:51
I too found it near impossible to secure the Alta on my wrist using the recommended "pinching" procedure, but I found a way to do it that has worked like a charm every time. I wrap the band around my wrist and line up the pegs with the corresponding holes, but I make sure the alignment is such that the spot I have to press is directly over the inside bone of my wrist. I simply press down with my thumb, using the bone in my wrist to press against, and the pegs pop through the holes every time easily and without having to squeeze the band ends together with my thumb and forefinger. It doesn't hurt at all to clasp it this way, and I've had no issues with it not being totally secured.
05-15-2016 16:23
05-15-2016 16:23
05-16-2016 16:29
05-16-2016 16:29
@sarich Happy to hear that the oil tip helped out. Thanks for the update.
@nams @NAL1575 Thanks for the feedback! It should get easier with time as others have said. Hope you're enjoying your Alta now!
@TinaArora Thanks for the feedback, sorry to hear that you were unable to put it on. Have you given the tips here a try yet? That should help get it on.
05-16-2016 19:46
05-16-2016 19:46
05-17-2016 01:13
05-17-2016 01:13
05-17-2016 05:53
05-17-2016 05:53
05-17-2016 08:02
05-17-2016 08:02
I just bought a new band in Amazon. It has a buckle! I will let you know how it goes...
05-17-2016 09:17
05-17-2016 09:17
05-17-2016 09:56
05-17-2016 09:56
