11-18-2024 02:20
11-18-2024 02:20
Since latest update when I enter my weight it will not accept stones. From setting changed to kg that works. Set back to stones only option to input is pounds when entering new weight. Same on both android devices i use tried logging out and in, reset all devices too no change
01-06-2025 02:58
01-06-2025 02:58
01-06-2025 02:58
01-06-2025 02:58
01-06-2025 04:51
01-06-2025 04:51
Best Answer01-09-2025 03:30
01-09-2025 03:30
Having this same issue!
Fitbit why have you changed this?!?
Also struggling to see weight history???
Best Answer01-10-2025 23:11
01-10-2025 23:11
No point buying a new fitbit at this point. The brand has become absolutely useless.
Best Answer01-10-2025 23:30
01-10-2025 23:30
01-12-2025
01:37
07:22
EstuardoFitbit
01-12-2025
01:37
07:22
EstuardoFitbit
This is the main reason I purchased this watch. To log my weight I was doing it ok until last month or so.
Please fix it ASAP It's really annoying. Go back to logging weight the way the customer has chosen. NOT JUST IN POUNDS .
Best Answer01-14-2025 07:48
01-14-2025 07:48
I still have this issue.
Best Answer01-14-2025 08:48
01-14-2025 08:48
Still same problem fitbit not interested
Best Answer01-14-2025 08:52
01-14-2025 08:52
Lizzy is this issue being reviewed or not it's been well over a month now ? Seems that you have just brushed it away and we have all invested in Fitbits product that's NOT fit for the purchase we purchased it for
Best Answer01-14-2025 09:22
01-14-2025 09:22
I just do what someone else suggested works. Press on the app icon on your phone/tablet until a list comes up. Press on 'Log Weight' and enter in stones and lbs. It works.
01-14-2025 09:26
01-14-2025 09:26
That does work. Thanks. Would like to do it through the app. See what they come back with.
01-14-2025 09:38
01-14-2025 09:38
I do that as a workaround, but the facility to do it in the app should be restored. At least 1 other thing was broken at the same time as the 'update' - inputting as pounds gives a conversion to stones and pounds that is widely out.
01-14-2025 09:45
01-14-2025 09:45
Thanks. A good workaround for now. Will try it next weigh-in
Best Answer01-14-2025 10:46
01-14-2025 10:46
Yeah i do use this but should be a loh in app and it's also the progress option of your weight loss feature which has gone. This has been raised as an issue since the start of December and no further forward so it's more the point of getting a resolution and not being stuck with a work round.
Best Answer01-14-2025 14:24
01-14-2025 14:24
Is this every going to be fixed? Not everyone lives in USA and uses pounds, many of us want to enter stones and pounds.
This is a real pain and taking this long to fix shows a lack of interest in international customers!
Best Answer01-14-2025 14:51
01-14-2025 14:51
Best Answer01-15-2025 01:14
01-15-2025 01:14
Hello!
Can I ask, did the issue ever get fixed with logging weight in stone?
I am still only able to do lb!
I have been on to fitbit support with no luck in changing from lb to stone!
Thanks!
Best Answer01-15-2025 01:20
01-15-2025 01:20
Only by using the suggested workaround someone posted. You hold down the Fitbit icon on your mobile/laptop main screen ( don't open it), a drop-down menu appears and you click log weight. The stone and lbs option is there. It's not ideal and you can no longer see your overall weight loss to date but it's something.
Best Answer01-15-2025 01:22
01-15-2025 01:22
No
Still the same. If you look back on the thread there is a work a round of hold down on the app and from there click on log weight.
