Hi,
Has anyone received and managed to set up an Aria Air yet?
Got my Air today, but it's not listed in the Fitbit app as a device (on Android). Following setup for the Aria or Aria 2 doesn't work (not surprising).
I can get the scale to flash an "ota" message (presumably over the air) but my phone won't connect to it via Bluetooth (can see the Aria Air but won't pair) and the scale does not have an Aria network I can connect to.
Thoughts anyone?
My guess is that the software has not been released yet. Maybe they got sent before the software. If this is the case, I would just keep checking back, and expect it within a few days.
Best AnswerThat was my guess too, but disappointing. Nothing worse than new tech that you can't use!!!!
Will report back on this thread if I get anywhere.
I think for now you should still be able to use as a regular scale - just not auto-connected to Fitbit, though I realize that's not what you want.
06:23
06:08
JuanJoFitbit
10-17-2019
06:23
06:08
JuanJoFitbit
I am dissapointed.
The aria air scales can be ste up now. Got to connect a new device.
Moderator edit: merged reply
Best AnswerPlz help me with set up secrets! Keep getting same error messages. Pairing denied or redo set up device. Again and again....
Sending an invite to add an additional user worked for me. What threw me initially is that the invite is sent to your fitbit-registered email address, rather than as a Fitbit app notification.
I have two users added fine, both able to take independent weight measurements.
Best AnswerBut how did u sync to start. I keep getting "pairing denied" and that resync device error message.
Once I had updated the App setting up the new device was straightforward so not sure why you are getting a problem.
Best AnswerYup, I have the exact same issue. I was able to get the scale connected, and invite another user. But I keep getting the same message as you when I try and use it. And if I select Now, and try and run through the setup, it finds the scale and then reports that it's not working and instructs me to restart bluetooth and/or my phone.
Very frustrating.
I was able to delete it, but then when you try and re-add it, you're told it is already connected to another account (really? it's the same user ID!) So, I had to reset the scale, for which the instructions are crap. But I did manage to get through that and then successfully re-add the scale. I got 1 successful weight recorded. Came back later, and same problem all over again. The app is telling me the scale is not setup correctly.
