08-08-2017
20:06
14:53
08-08-2017
20:06
14:53
Have had this scale for two years and loved it. All of a sudden today I change the batteries and start getting a step off, sensing, error message over and over again. Contacted customer service and all they can tell me to do is throw it away. For a scale that costs so much money it's unacceptable that it stops working so soon. Have been a loyal customer for over three years and now I'll have to look elsewhere for a quality product
03-11-2018 08:09
03-11-2018 08:09
I have had my Aria for exactly one year, I got as a gift from my kids last year on my birthday late February. Last week I got an ERR message and I have set up my fit bit over and over in hopes that it will reset, but it won't I even changed the batteries again. What can I do. This ARIA is way too expensive for it to go out just like that? I called Fit bit and they said there is no fix. Is this true? I have loved fit bit and have had their trackers since they came out and have upgraded, but this is very discouraging, Any suggestions?
03-11-2018 08:54
03-11-2018 08:54
03-11-2018 09:01
03-11-2018 09:01
03-11-2018 14:00
03-11-2018 14:00
03-11-2018 14:05
03-11-2018 14:05
03-24-2018 09:53
03-24-2018 09:53
Hi everyone! I would like to follow up on this and would like you to make sure that your routers run the protocol 802.11b, the bandwidth is 2.4GHz and your WiFi's password is alphanumerical. Also, please let me know if you get any error message, this will help me to assist you accordingly.
@prncssgeek Thanks a lot for your help and contribution my friend!
See you later guys!
03-24-2018 12:44
03-24-2018 12:44
So I get an email from FitBit stating my batteries need to be changed for my Aria... so I do. Now I get the step on.... thinking ... ERE... this is obviously a common problem. Time for Fitbit to step up and fix the issue and or replace the Arias at Fitbits cost. I have spent the last 4 hrs trying to get it to work and nothing fixes the issue. Help your customers!
03-25-2018 09:31
03-25-2018 09:31
Hi JuanJo.
Please don't tell me you're an idiot like FitBit.
If FitBit can install an update to my scale and to all the other people on this thread, then they can install a fix in the same way.
You should take this comment to your contact at FitBit who still refuses to seriously address this issue and tell them that checking router details don't mean anything. It's just a way to play for time while trying to sell Aria 2. Pathetic.
Everyone on this forum can see that no one at FitBit cares about fixing a scale that they broke with an update. That's why I bought a new scale from another company.
03-25-2018 09:37
03-25-2018 09:37
03-27-2018 17:31
03-27-2018 17:31
I am having this error. Removed batteries numerous times. WiFi and password fit your description.
03-30-2018 21:43
03-30-2018 21:43
Hi, I read your msg and it is exactly the same problem i had with my Aria just over a year old. Numerous exchange with fitbit customers only provide standard reply and no solution. The worst thing is there is no service support in the country I lived.
Nevertheless, I decided to take things on my own since it is not working anyway. Going through youtube to see how to tear down and start looking at it.The reason why it keep asking you to "step off" is due to the electronic is not receiving a signal from one of four sensors at the 4 corners. If you are able to open up the cover and disassemble the sensors simply with a screw driver, you will see a grey o rings or rubber gasket that is probably very compressed or off position thus is not 'bouncing' the supporting legs back to its original position to show there is no weight on it. Therefore it keep thinking there is weigh on it and keep asking you to 'step off'. Next time you have such a problem, either you can do the same as above or slightly lift up the scale(most probably the lower 2) a little to give the legs a little room to bounce back, you might over come this error. It works for my Aria and I can't say it will work for the rest. Good luck!
04-01-2018 01:54
04-01-2018 01:54
Out of curiosity why does the wifi password have to contain alpha and numbers in order for the problem to be fixed?
04-01-2018 05:45
04-01-2018 05:45
04-01-2018 16:44
04-01-2018 16:44
I've had my Aria scale 2 years this past February and loved it! Worked yesterday and ERR today. Batteries weren't dead, no router or wifi changes. Went through all troubleshooting with fitbit just to be told its defective and out of warranty. I've had $30 scales last longer than this. Disappointing for sure!
04-01-2018 18:24
04-01-2018 18:24
04-01-2018 21:29
04-01-2018 21:29
Thank you! I will look into those.
04-02-2018 07:46
04-02-2018 07:46
06-02-2018 15:01
06-02-2018 15:01
I had the same problem. Got this scale a few years ago, it worked great for a few months, then all of a sudden it started giving us a WiFi err. Customer service said it was our WiFi even though I made their suggested changes and it still didn’t work, they were not any help. So I used this thing manually (just read my weight off the screen) for the past few years. I recently decided to try and set it up and somehow it worked. But now I’m getting this step off - thinking - err error. So frustrating. I really regret investing a hefty amount of money in a scale that does not do what it’s advertised to do.
06-02-2018 16:42
06-02-2018 16:42
06-27-2018 07:56
06-27-2018 07:56
Hi everyone! I'm sorry to hear that your Aria scales are still experiencing the "Sensing Thinking ERR" issue. Please make sure that your Aria scales are placed on an even or flat surface and you are stepping on them barefoot.
Finally, if you haven't done so, restart your scales one more time by taking out the batteries and weigh yourselves 5 times in a row in order to re-calibrate your scales and see if the issue gets fixed.
On an aside note, please take a look at this page for more information about the warranty policies.
Catch you all later!
