06-10-2015
18:32
04:13
JuanJoFitbit
06-10-2015
18:32
04:13
JuanJoFitbit
I recently had to change out my wifi router. It is the exact same type as my previous router that was connected to the scale but for some reason this scale will not connect to the new router. Oh it was a nightmare connecting the scale to the first wifi as well, but I am over it. !!!!! I have been trying for three days. Shame on you fitbit for putting out such subpar material. some one needs to tell me how to fit this setup or I want my money back. My scale is saying that it has detected the networks but my network does not appear to connect to it. I should have bought a Withings scale. uggh.
Moderator Edit: Title change for clarity
11-27-2017 05:28
11-27-2017 05:28
11-27-2017 06:44
11-27-2017 06:44
11-27-2017 06:52
11-27-2017 06:52
11-27-2017 08:55 - last edited on 03-02-2020 16:49 by LiliyaFitbit
Thank you for taking the time to reply. I also waited 30 seconds the 6th time and it finally started working Ha! I lost stress weight so that is the good outcome.
Thank you again
11-27-2017 09:04 - last edited on 03-02-2020 16:50 by LiliyaFitbit
It’s working now, thanks.
11-27-2017 09:05 - last edited on 03-02-2020 16:48 by LiliyaFitbit
Working👌
11-27-2017 09:09
11-27-2017 09:09
I think that taking one of the batteries out simply powers the Aria down and when you put the battery back it restarts. When a Wi-Fi device restarts it will try to connect to the network - the Aria will show the name that it's connecting to - and then, when it finds the network it will connect using the password. So the network name and the password have to be correct to get this far.
Once it connects, it will issue a DHCP request for a network address and network information that it needs to communicate and will try to get the updated information from the network - this is why you need to restart everything if you make any changes to the network. If you don't restart the device it will keep on trying to use the old (outdated) information.
11-27-2017 10:24
11-27-2017 10:24
11-27-2017 10:26 - last edited on 03-02-2020 16:48 by LiliyaFitbit
Ha! There is a solution. I waited 30 seconds instead of the recommended 10-15 and on the 6th try it worked! I lost stress weight so perhaps this is a new diet fad - WiFi DiFi!
11-27-2017 11:06
11-27-2017 11:06
I suspect that the problem here is that the Access Point will prefer the high bandwidth N mode if anything is connected in N mode, and doesn't switch to the B mode unless the B device is very close - this would explain way I was always able to connect the scale in the kitchen next to the AP and never in the bathroom at the other end of the house. Realistically, N mode (and 5GHz) is overkill for a device like the scale that only occasionally transfers small amounts of data.
12-05-2017 05:19
12-05-2017 05:19
12-05-2017 05:42
12-05-2017 05:42
If you walk through the scale reset procedure then you can reset the scale to use a new SSID - I think that the instructions say to tap the scale during the setup to reset it but I found that you need to give it a good hard bang.
Now that I've connected to a router that is set to the older "B" mode, I'm find that the scale connects very reliably at about 50 feet through two outside walls. I suspect that the issue is that the scale was designed to use the B mode and that newer routers simply don't want to use B - they say that they "support B" but they will tend to ignore it when they see a brief connection attempt from the scale.
12-26-2017 01:57
12-26-2017 01:57
Setting up this piece of equipment is ridiculous...I have tried for two days..all I get is it cant connect to the network. Really...is this the best that fitbit can do. Its pure garbage..
12-26-2017 01:59
12-26-2017 01:59
Agreed.. The worst setup....ever... In this day and age of plug and play and Fitbit come up with this junk..
12-26-2017 12:42
12-26-2017 12:42
To connect to the network make sure that the network that you are connecting to is 2.4Ghz (not 5GHz) and running in "B" mode. Many routers say that they support different modes but their support is not that good. Once you are connected to a B mode router it's very reliable.
12-26-2017 13:01
12-26-2017 13:01
Now I’m struggling the same. So frustrated. I can’t sync to my new WiFi and it’s have my new WiFi’s name to connect to it.
01-06-2018 06:20
01-06-2018 06:20
The software for this stuff is 1st class **ahem**. Not a single aspect of Fitbit is intuitive, especially and including the scale setup. I'm trying to change my WiFi network because I moved (as if the reason matters). There's no option even presented to do so, even though the old network doesn't even exist.
I'm thinking of making a satisfying video of smashing FitBit products into tiny pieces. I'm pretty sure I'd establish a record of some sort for likes.
01-06-2018 07:16
01-06-2018 07:16
Just take one of the batteries out of the Aria for about 10 seconds, then put it back in and it will restart and briefly prompt you to go through the setup procedure again - it will say "tap to setup" but realistically you need to give it a good wallop to get it to go into the setup menu to chose the new AP name and password.
There are videos on YouTube that will walk you through the setup.
01-06-2018 09:22
01-06-2018 09:22
01-07-2018 14:02
01-07-2018 14:02
