02-01-2018
15:45
14:53
02-01-2018
15:45
14:53
A while back I got a new modem and my Aria will not connect to it. I read through the troubleshooting on here, and made the necessary changes. My password is alphanumeric with no special characters and is set up as 802.11 b,g,n and STILL won’t connect. I haven’t had this scale for even a year and it’s a major hassle. Any other ideas on getting this to work? I’ve already had to get a replacement Charge 2 after 13 months and I’m really not wanting to spend money on the new Aria. It’s really awful that this is being sold knowing how difficult it is to connect to WiFi.
I emailed customer support and got a solution that actually worked! Here’s what they said to do:
We've received an update from our engineers and they've created a work around that might fix the inconvenience that our customers are experiencing with the Aria scale and Comcast/Xfinity routers.
In order to do so, we'd like you to follow the instructions below:
Log into Comcast/Xfinity account
Once logged in, visit https://internet.xfinity.com/more
Edit WiFi settings under "Additional Settings"
Click on 2.4 frequency edit button.
Select g/n, hit save.
When the screen refreshes, click edit again, select b/g/n and hit save.
Stand on scale
We hope this gets you back on track with your Aria. Please let us know if you still need assistance setting up your Aria.
Sincerely,
Alex B. and the Fitbit Team
@Erin5550 @reamer Thanks for joining our Fitbit Community and it's great to see you in the Community also @lindas93!
Thanks a lot @Erin5550 for sharing the workaround that advised our Support team and I'm glad to hear that it worked for you. I recommend following those workarounds @lindas93 @reamer since those troubleshooting steps are specifically for Comcast and X/finity routers.
I'll be around if more assistance is needed my friends! ![]()
@reamer Thanks for getting back! Regarding your question, I want to follow up and would like to know if you have tried the troubleshooting steps that recommended @Erin5550 and @lindas93. If the issue persists, don't hesitate to get back and I'll be happy to assist you accordingly.
@lindas93 I'm so glad to hear that you were able to set up your Aria scale! Thanks for sharing the workaround that you tried.
See you guys later! ![]()
@Erin5550 I'm sorry to hear that your Aria has stopped working. I know how frustrating this is for you. However, I want to turn that bad experience into a good one. Please let me know the following: Did your Aria stop syncing your data? Did it stop turning its display on? Is it providing wrong readings? This info will help me to provide a concrete solution.
Looking forward to your response my friend! ![]()
Best AnswerThis absolutely worked after changing this setting several times. Thanks
@Erin5550 Thanks for getting back! Since you mentioned that your scale stopped syncing your data, I'll forward your case to our Support team so they can investigate further and provide a solution for you. Please keep an eye on your email account since they'll reach you via email.
@lindas93 @Sunnydaydreams I'm so glad to hear that your Aria scales are working properly now! Thanks for posting the update here.
See you all later my friends! ![]()
Best Answerafter about three hours of frustration. This simple fixed worked.... turn it off and back on again
I wish I could say this was a permanent fix, but the scale wontwsyc once again. No effort to reconnect has been made yet. This is getting really frustrating. I'll try something soon, but a definitive fix from Fitbit & Xfinity would be preferable.
Hi! I've done this over and over and it still won't sync. I've spent hours on this and honestly, I'm fed up and done with this product. I was online with a fitbit rep for over an hour and we got disconnected in our chat. Please, fitbit. contact me to help.
I did this same exact thing and it did NOT work for me. Please contact me, fitbit. I am beyond frustrated and I'm just about done with you and this product!!
@Cashgrinder I noticed that you joined our Fitbit Community recently. Welcome aboard! I'm so glad to hear that your Aria connected with your network properly. Thank you for posting the update here.
@Sunnydaydreams Please try the workaround that share @prncssgeek in her post. That's a great troubleshooting step that is very helpful. If the issue persists, let me know the make and model of your router.
@campbek I was able to get in touch with our Support team and the'll reach you via email. Please keep an eye on your email inbox and the'll be glad to follow up.
I'll be around if you have doubts my friends! ![]()
