09-23-2016 13:01 - edited 03-04-2017 10:04
Firmware version 17.8.301.8 - Resolves a syncing issue with Apple iOS version 10.2
Workout mode missing? Not a problem! Just follow the steps for adding it back.
Hey everyone! ![]()
We're rolling out a new update for Blaze, release notes below:
This release also resolves the following issue:
Important to note: A sync is required after a manual shutdown or a battery drain in order to show the correct time on Blaze. This is especially important for your activity tracked by Blaze because you'll want to make sure it's associated with the current date and time.
10-09-2016 16:26
10-09-2016 16:26
I like the ability to turn my Blaze off, though I seldom use it but I understand why some would want to. My wife's Charge has many forum posts about inability to sync after letting the battery go dead even after charging and needing to be completely reset losing all data in order to get everything back in working order. Compared to this the Blaze is a boon. Easy fix ....don't let it go dead. Charge it early rather than letting it go so far down. No sync problems . ![]()
Best Answer10-09-2016 22:22 - edited 10-09-2016 22:24
Actually @mcrmama most can be turned off, but not all or easy. The zip can be turned off by pulling the battery, the one you do a restart, but don't press the button to turn it back on, the charge and charge HR you do a factory reset and say no to clearing the data, with the Flex do a restart procedure with it not plugged into power, I would be surprised if this didn't also work for the Alta, and Flex 2 but can not confirm. The Blaze and surge have a shutdown menu.
I could try some stuff with the Charge 2 but since I've not had any reason to restart it, I'm not going to.
Best Answer10-10-2016 03:20 - edited 10-10-2016 03:24
@blans thank you for your clarification of my post 🙂
@12HourWalker I think the 'easy fix' would be to revert back to the way it was pre update.
I never realised that turning off a device with an on/off switch would prove so controversial... I do it with lightswitches, ovens, phones and TV's; I suppose it's just carried over to my watch and not wanting to waste electricty (no matter how small) for the good of the planet. But whether I should or should not turn off my watch really isn't the point of my posts, nor the issue in hand.
There is seemingly no user rationale or benefit for this need to sync function. Quite the contrary, it is very user unfriendly and annoying, which suggests that it was either just too complicated for the software guys to bother trying to fix prior to release or there is some other, more 'evil' reason for Fitbit to do so involving my (and your) data and third parties.
As @ultrablazer mentioned, telling the correct time really is the most basic of functions that a watch should be able to deliver...
10-10-2016 10:03
10-10-2016 10:03
Best Answer10-10-2016 11:50 - edited 10-10-2016 12:05
It was a very smooth ,and pleasant update no proublems at all got it about two weeks ago .
10-10-2016 13:49
10-10-2016 13:49
10-12-2016 02:22
10-12-2016 02:22
Hello Fitbit Community,
Has anyone noticed quick battery drain after the new firmware update 17.8.301.7. I have been charging my fitbit and I am seeing a sudden drop in battery level (from 50 to 10). I am going to do a charge test by charging it 100% and with my previous config and see how long does the charge last.
Reply if anyone has similar issues.
Thanks
Best Answer10-12-2016 02:22
10-12-2016 02:22
Thanks
Best Answer10-12-2016 02:35
10-12-2016 02:35
Last time I charged my Blaze was Thursday. This morning after I got into work (I work 3rd shift), I got the low battery warning on the Dashboard (Phone) and e-mail, which is right around the time where it should be telling me it's got to be charged.
Since this is happening with my Blaze, I don't have the issue you are describing. After I get home, I'll be syncing to the Dashboard and getting the Alta ready to pick up where the Blaze left off. My Alta also doesn't have this issue.
Best Answer10-12-2016 02:37
10-12-2016 02:37
Mine took 30 minutes, about the time it takes me to get showered and dressed.
Best Answer10-12-2016 02:46 - edited 10-12-2016 02:47
@Driver8666 Thanks for your reply. I use Blaze 24/7.
Before the firmware update my battery would last long enough that i didnt feel the need to charge it for a 3-4 days, but after the update i started seeing this behavior. So, right now i dont know if it is the fitbit or the firmware update.
Best Answer10-12-2016 03:11
10-12-2016 03:11
I have all the extras turned off. Heart Rate Monitor is set to Auto. I did have one alarm, but I shut that off, and won't be using it unless I have to.
I use mine 24/7. My Alta I only use if the Blaze is in the charger.
As for the Fitbit or firmware update, I'm sure I'll get pounded on for this but the jury is out on this. Why? Not every single user experiences this.
Best Answer10-12-2016 08:18
10-12-2016 08:18
Is this Blaze update now available to all users?
I'm eager to get a Blaze but only if I can get this update.
Best Answer10-12-2016 08:39
10-12-2016 08:39
@Courtneyjsimon You have to re-add the "Workout" shortcut in your device settings. Remove it if it's already in the Exercise Shortcut list, sync, then add it back and sync.
@joerojas Yes, the update has been available to everyone since September 27th.
10-12-2016 12:49
10-12-2016 12:49
Thanks @AndrewFitbit
I just ordered my Blaze! Looking forward to it!
10-12-2016 20:37
10-12-2016 20:37
Trust me... you DON"T want it, and Fitbit needs to fix it! Ever since the update, my fitbit blaze will not sync, have to hit the sync button several times before it will.. It also no longer syncs with my phone GPS, just did a 3 mile walk today, got less than a half mile into it and it dropped the GPS. Restarted it, lasted another ¾ mile and dropped again!! I am VERY irritated!! I spent 200 dollars on a fitbit and was working great until this last update and hasn'r worked right since!! Called help desk and they tried to tell me that I needed to run the battery all the way down and charge it again.. Did that ans still work like crap!
Let's fix this!!
(my sisters charge HR is having the same issues with the latest update!)
Best Answer10-13-2016 05:20
10-13-2016 05:20
10-13-2016 10:51
10-13-2016 10:51
I have the Firmware Version: 17.8.301.7. It has not improved the connection performance of my Blaze with the LG G3. It still seems to disconnect on a regular basis(at least every other day). Sometimes it only requires a Blaze restart and a logout login on the fitbit app. Most every other time I have to do the following. (1) Shutdown and restart the Blaze (2) unpair the Blaze in the phone settings (3) Logoff, uninstall the Fitbit app. (4) Download and reinstall the Fitbit app inorder to reconnect the Blaze. It is getting a little old. I have the app set to constantly connected and the notifications set to help establish a firm connection as suggested by the Fitbit technician.
10-13-2016 21:27
10-13-2016 21:27
Yes! I am having the same issues! You have explained the issues better than I could.. This is SO frustrating. Spending over 200 dollars for it to do this they either need to fix it or refund my money!
Best Answer10-13-2016 21:41
10-13-2016 21:41
