09-23-2016 13:01 - edited 03-04-2017 10:04
Firmware version 17.8.301.8 - Resolves a syncing issue with Apple iOS version 10.2
Workout mode missing? Not a problem! Just follow the steps for adding it back.
Hey everyone!
We're rolling out a new update for Blaze, release notes below:
This release also resolves the following issue:
Important to note: A sync is required after a manual shutdown or a battery drain in order to show the correct time on Blaze. This is especially important for your activity tracked by Blaze because you'll want to make sure it's associated with the current date and time.
09-29-2016 07:03
09-29-2016 07:03
I received the update Tuesday night. Luckily it only took the 10 minutes that it said it would. I was so anxious that I kept touching the screen on my phone to make sure it didn't time out.
I really like the "Moment" and "Argyle" watch faces as what I've wanted all along was to see digital time and my step count.
I love the reminders to move! I didn't know how it would work....yesterday I had only 1 hr where I didn't move and I received the vibration that told me I had to walk 111 more steps. I wasn't expecting it to tell me how many more steps I needed so I was really impressed! I got up from my desk at work and walked the steps. It then vibrates again to tell you that you've reached your goal.
The only thing I've come across in the 2 days was I noticed when I was at the gym yesterday that the "workout" option was missing from my exercises. I could clearly see it on my app so I tried rebooting my Blaze and resyncing. When that didn't help I just reordered "workout" on my app and resynched. Problem fixed. Hope this helps someone else!
Thank you Fitbit for a great update! I was more anxious for the watch faces but now I'm actually more thrilled about the reminder to move.
09-29-2016 08:36
09-29-2016 08:36
FYI, it took over 90 minutes to update mine. The progress bar advanced at a very slow rate and was not the same on the watch and the phone. Still, when it ended, everything worked fine!
09-29-2016 08:49
09-29-2016 08:49
09-29-2016 08:51
09-29-2016 08:51
It turned out that my Blaze got the firmware update. When I tried to change the watchface it read an internal error with FB website. Is anybody else facing the same problem just now?
09-29-2016 09:56
09-29-2016 09:56
Yes I too got the update on Tuesday night, I was very excited when I saw the update bar. It took about 3 tries for it to complete in about 20 mins. I think this was because I was using my mobile data and the connection wasn't great.
I only got the app notifications working yesterday because when my screen goes off if disables all notifications, so I had to make some adjustments.
But it all started working as it should this morning.
09-29-2016 09:58
09-29-2016 09:58
The new Tracker software wont update, i am running on 17.8.200.3
Ive tried all the things suggested, the Blaze syncs ok.
Any help would be appreciated.
W
09-29-2016 10:08
09-29-2016 10:08
I received the update yesterday morning and love it! I want to say thank you to everyone at fitbit for all their hard work!!
09-29-2016 10:08 - edited 09-29-2016 10:09
To Wiganbloke
Try to update FitBit Connect. I did not have a red flag but when I updated FB Connect to v. 2.0.1.6742 it was updating for 19 minutes and then I had the firmware updated. It worked for me.
09-29-2016
10:42
15:21
AndrewFitbit
09-29-2016
10:42
15:21
AndrewFitbit
I have noticed that I turned off notifications for my iPhone email yet I still keep getting them. How do I stop them?
09-29-2016 10:46
09-29-2016 10:46
how did you know the update was available for you?
09-29-2016 10:51
09-29-2016 10:51
09-29-2016 10:51
09-29-2016 10:51
Andrew if the update is available to everyone how do I access it?
09-29-2016 10:52
09-29-2016 10:52
09-29-2016 11:58
09-29-2016 11:58
"how did you know the update was available for you?"
There was no update in my Settings and no red flag but FB Connect did the update firmware.
09-29-2016 12:28
09-29-2016 12:28
09-29-2016 13:25
09-29-2016 13:25
09-29-2016 13:26
09-29-2016 13:26
look at message 601 from Tracy. She had same issue and explained how she fixed it
09-29-2016 13:28
09-29-2016 13:28
@scoob1963 You will have to go in and re-add the workout shourtcut. What I did was move it to number 1, synched, and then moved it to where I wanted it. Don't know why it is doing that, but all is well now.
09-29-2016 13:43
09-29-2016 13:43
I got the upgrade. I had to update my connect app to see it. You need to resync each time the clock face is changed.
09-29-2016 14:22 - edited 09-29-2016 14:57
After the update I can see the distance covered in meters on the main screen. I'd rather see the amount of steps instead. How shall I do it?
