06-14-2017 11:19 - edited 07-09-2017 09:29
Fitbit Update: 7/6/17
Yesterday, there was a fix released that resolved this issue. Now that I have confirmation that this was resolved, I'm going to close this thread. If this pops up again in the future, please create a new post to report the issue.
Thanks everyone for your patience! It is always appreciated. ![]()
Fitbit Update: 6/29/17
Thanks everyone for your patience while this was being investigated. Our team was able to identify the problem, however, I don't have a timeline for when the fix will be released. Once the fix is released I will update this thread again.
Fitbit Update: 6/14/17
Some Blaze users have reported that their run exercises initiated on the tracker are not syncing over to the Fitbit app or web dashboard.
Our team is aware of this issue and currently investigating the root cause. Thanks to all who have reported this. I will post any updates on this thread when there is more information available.
06-18-2017 17:51
06-18-2017 17:51
Best Answer06-19-2017 02:03
06-19-2017 02:03
as many others I am having this issue on windows 10 mobile app, since the June update. If I go for a run and then sync all calories and steps get logged. Tile says 1 out of 5 for the start of the week but no run data is there when you go into tile for further details.
if I do weights in the gym, this is logged ok, if I do a walk its detected and syncs fine
this morning I did a run, after 10 seconds I stopped it to go back in to get some water. Started fresh again and went for run.
this time the 10 second run synced but the proper run did not?
Best Answer06-19-2017 02:20
06-19-2017 02:20
The best anyone can say is to keep an eye on the top post of this thread.
Unfortunately knowing that a problem exists is not enough ghost to fix it. The cause needs to be identified, a solution found, solution needs to be tested, troubleshoot, and made sure that it doesn't add more problems.
Best Answer06-19-2017 04:39
06-19-2017 04:39
06-19-2017 04:39
Best Answer06-19-2017 05:10
06-19-2017 05:10
@AlessFitbit Would you be able to have your response post moved to the top of the topic queue, its currently sitting on page 12 today of the Topic. This link will be outdated tomorrow but it's closer
Thanks again.
@AlessFitbit wrote:Fitbit Update: 6/14/17
Best Answer06-19-2017 05:33
06-19-2017 05:33
Thanks for working on the problem. My blaze runs on the droid platform. It initially shows the map on my phone with my splits, and mile markers etc. However, when I go back to the dashboard, I lose the map and splits information. Sometimes it logs it as a run and sometimes I have to manually enter the information, which doesn't give me accurate split information. This has happened 4 or 5 times since June 1. The first time it happened I thought I hit the delete button. Now I know that is now what I did. This morning it was connected to the internet when it happened. Pam Jarvis
Best Answer06-19-2017 06:30
06-19-2017 06:30
Best Answer06-19-2017 10:04
06-19-2017 10:04
I have the same issues -- run will not sync -- it records and provides summary at the end of run but will not update for viewing from the app -- problem over the last 2-3 weeks
06-19-2017 10:05
06-19-2017 10:05
Thanks , will give it a go . My run before did not register. I've given up on a fix . I did pop into Currys / PC world today and explained the fault . They will be happy to refund me apparently . Shame really . I have benefited since I purchased a blaze and enjoyed it up until the past few weeks .
Best Answer06-19-2017 10:26
06-19-2017 10:26
I've spend a lot of time contacting customer service over the last 10 days, and have been told a) do a reset of the device (didn't make a difference), b) I need to make sure I'm moving my arms enough for the run to register (give me a break), c) I need to run longer than 15 minutes for SmartTrack to work (I'm running 45 minutes AND manually starting the run), d) I may need to return device per warranty (had to keep explaining that the device works fine, it's the syncing to app/dashboard that doesn't work). Finally they understood & said they'd forward problem to tech, but "don't expect the fix to happen immediately, it takes some time."
Well, they need to pay some people overtime to get this software problem fixed ASAP or they're going to have a boatload of Blazes returned, and that can't be good for the company. We paid WAY too much for these devices to simply have steps counted on our dashboards.
06-19-2017 11:51
06-19-2017 11:51
Best Answer06-19-2017 12:14
06-19-2017 12:14
My Blaze is also not recording my runs. Just over the past couple of days. It tracks the miles and minutes fine while I am running, but nothing is showing up later on my exercise tile in the dashboard. The steps are accounted for but none of the stats of my run. Please fix this problem and advise us what to do!!
06-19-2017 12:16
06-19-2017 12:16
Incredible! Had the same conversation with me and talked a load of nonsense. I have tried to escalate this . However nobody at fitbit will take responsibility.
06-19-2017 12:42
06-19-2017 12:42
06-19-2017 14:41
06-19-2017 14:41
I can't believe this isn't fixed yet, I keep checking daily!
06-19-2017 15:03
06-19-2017 15:03
Fitbit support wants me to take a run, then take a picture of my fitbit screen showing the results, then sync and take a screenshot of my app showing it doesn't register. I am curious to see if it will record it if I just go on a run and let it autorecognize my run (and just use the timer on the blaze) if it will record it correctly with stats (since it does for every other type of workout I do - walking/sport/etc when I don't manually start the exercise).
Best Answer06-19-2017 16:38
06-19-2017 16:38
I've been having this issue as well. All of my exercises that are auto-tracked sync just fine, but when I initiate the tracking on my phone or on my Blaze it doesn't sync with the app on my phone or laptop. Very frustrating since I'm training for a half marathon right now. Ongoing since 05/31 - this is the last date that my logged exercise has synced.
06-19-2017 17:11
06-19-2017 17:11
I had the same issue, hope that this problem can be solve very soon
06-19-2017 23:26
06-19-2017 23:26
So I take it that after 6 days there is still no update on this problem?
