06-01-2017 13:27
06-01-2017 13:27
Temp sensor will not go away, comes up every time i push a button. want charge or sync to computer.
06-01-2017 13:31
06-01-2017 13:31
Hello and welcome to the forums @bvfdchief
You can learn more about your Blaze here - click
There is no temp sensor, that is your heart rate monitor.
Check out the articles at that link to learn how to charge or sync.
Let us know how things go for you.
06-01-2017 13:32
06-01-2017 13:32
What is the temp sensor telling you, to cold or to hot? Does the unit feel like it is correct?
06-01-2017 13:42
06-01-2017 13:42
Its orange and looks like a temp gauge overlaying a triangle. the pic option apparently does not work in this reply
06-01-2017 13:44
06-01-2017 13:44
Its orange and looks like a temp gauge overlaying a triangle. the pic option apparently does not work in this reply. I pretty familiar with my fitbit and know what the hear rate is as I have done BETA testing and pretty knowledgeable beyond basics.
06-04-2017 04:25
06-04-2017 04:25
Welcome to the Community @bvfdchief, @Odyssey13 and @Rich_Laue thanks for stopping by.
Can you please provide me with a picture of your tracker's display? Is the temperature in the room you are fine? It's too hot outside or inside of where you are? Since I recommend keeping in the tracker in a normal temperature, also you can restart it.
Hope to hear from you soon.
06-04-2017 06:43
06-04-2017 06:43
Want go away, want restart and it's not in any hazardous temp areas.
06-05-2017 04:39
06-05-2017 04:39
Thanks for the information and the attachment @bvfdchief. At this point, I recommend keeping an eye on your inbox for further instructions.
See you around.
08-02-2017 08:34
08-02-2017 08:34
I have the same issue (same icon) @AlejandraFitbit. Could you help me too?
08-03-2017 04:06
08-03-2017 04:06
Hey @tr1staN it's great to welcome you!
Have you tried any type of troubleshoot? If you have, can you tell me the steps you have already tried? In the meantime, if you haven't tried the restart process, I recommend restarting your Blaze.
08-03-2017 04:38
08-03-2017 04:38
08-03-2017 04:44
08-04-2017 10:25
08-04-2017 10:25
I have the same issue with my blaze
08-06-2017 05:08
08-06-2017 05:08
It's great to welcome you @Naadee1. Have you take a look at previous posts? If you haven't, I recommend restarting your Blaze.
I hope this helps, let me know the outcome.
08-06-2017 10:59
08-06-2017 10:59
08-07-2017 04:29 - edited 08-07-2017 04:30
Thanks for the information @Naadee1. I just would like to know if you have already get in touch with our support team? Have you received a solution for this?
See you around.
09-06-2017 08:45
09-06-2017 08:45
What is the solution for this? It seems many have this same issue Temp sensor icon stuck. Cannot restart. Clearly Blaze item is controlled temp indoor environmemt. Please post solution instead of sending it privately so we all can learn.
09-07-2017 12:21
09-07-2017 12:21
@SunsetRunner by giving instructions on how to contact Fitbit @AlejandraFitbit gave you the solution.
10-09-2017 07:08
10-09-2017 07:08
@AlejandraFitbit...like the others, I am having the same issue. Can't restart, can't sync. Could you please send me instructions on how to resolve this?
10-11-2017 04:08
10-11-2017 04:08
Hey there @RVAPanthersFan, great to see new faces, welcome!
Thanks for troubleshooting this by yourself, since the troubleshoot you tried didn't work, I recommend keeping an eye on your inbox for further assistance.
See you around.
