03-12-2016
12:49
17:04
AndreaFitbit
03-12-2016
12:49
17:04
AndreaFitbit
My Blaze hasn't synced since yesterday morning. I have restarted it and still won't sync.
Moderator Edit: Clarified subject.
Best AnswerThank you for your tips. I will see how they go today. So far my Blaze still hasn't synced. Today I will download the app to my laptop and see if that works. Many thanks.
Get Outlook for Android
Best AnswerOkay, I fixed my problem after installing the Fitbit app onto laptop. There was a part "Use as primary device" that needed to be set to "On" after I clicked on the Blaze logo etc. No idea how it ever changed but must have reset itself after an update, and I didn't see that part on my mobile app. Hopefully now it's all systems go!
Fit bit won't sync it says error trying again but does the Bluetooth need to be near, it last synced last night
Best AnswerI am having the same issue. Hasn’t synced since 10-28-2017 and have reinstalled app, restarted Blaze and phone (Droid Turbo). Really frustrated.
Best AnswerMy first fitbit wouldn't hold a charge, my replacement won't sync. So...I can't even use it as a watch! Blaze number 3 is supposed to arrive tomorrow. Got my fingers crossed but not terribly optimistic.
Best AnswerHow long have you owned it? I took mine back to the store where it was purchased and they gave me a brand new one...unfortunately it didn't work either, but number 3 is supposed to arrive today. My recommendation to you would be to take it back (or send it back if you purchased it online) if you've owned it for less than a year.
Best AnswerExcellent!
