02-22-2016 09:42 - edited 02-22-2016 10:26
Hey all!
I've been seeing a ton of great conversation about Connected GPS- the technology that will allow you to see your maps, as well as pace/distance using your phone's GPS. Ahead of launch of the device, I'd like to provide a bit more information about Connected GPS in comparison to our built-in GPS technology (found in Surge) or our existing GPS functionality in relation to other devices! The following is an in-depth look at Connected GPS, and and opening of the floor for questions! Are you ready? Let's do it!
Connected GPS is a new part of the Fitbit ecosystem! Using Connected GPS, Blaze connects with your phone's native GPS capabilities to plot routes and activity stats screen as the pace and duration.
The necessary components for initiating a Connected GPS exercise are:
To initiate a Connected GPS exercise, open the appropriate exercise (exercises that offer GPS connectivity on the Blaze will have a gear icon on the tile). Once you select the exercise type, you'll see that your Blaze will begin to look for your phone's GPS services. Once the device establishes a connection, you'll be notified that you're ready to go. You can always bypass the connection if you'd like, much like on Surge.
GPS is built-in on the Fitbit Surge, meaning that you could initiate a GPS activity without your phone in proximity. The MobileRun process works a bit differently; you'll have to open the Fitbit app and select Track Exercise > Stopwatch Icon > Start.
Phone Not Found: Users may see the following error state if their tracker is unable to connect to their phone. If this happens, please ensure the following: phone is within range, your app is open, phone is charged up, Bluetooth enabled and bonded, and Internet connection is present.
Check Fitbit App: If you come across this error, there may be a bit of action required. Please ensure that your app is open, you are logged into your account, and that location services are enabled.
Location services are required for Connected GPS to function properly. Please ensure that location services are enables, and set to "Always" if applicable.
Permissions are requested upon setup of the tracker. Users who intend to use the Connected GPS feature should accept the permission requests. If you switch phones during the life of your Blaze, you'll be prompted to run through all of these permission requests again before being able to successfully use Connected GPS.
02-21-2017 02:24
02-21-2017 02:24
Yes, it seems to be changed by connected GPS. So it must work somehow. Other way the field would be empty or my old stride length would be there.
Best Answer02-21-2017 02:42
02-21-2017 02:42
@The_LionThanks for the quick response. I didn't mention that Fitbit advise us that "we must run at a comfortable pace for at least 10 minutes to achieve the auto run stride change".
Best Answer02-21-2017 02:47
02-21-2017 02:47
I don't know why it changed from a fix stride length to auto. Obviously because I use GPS. And yes, my runs are longer than 10 minutes. Pace between 6 and 6.30 min/km.
Best Answer02-21-2017 03:19
02-21-2017 03:19
@The_LionThanks for the pace.. That is a starter for me and for others, the average pace equates to 9.6 kmh or 6 mph.
On the Internet most coaches say that you must run at least at 6 mph (9.6 kmh) for it to be considered running. So at my age I will never achieve that, so back to manual setting stride.
On my other Fitbits (non Connected GPS), including the Surge, the auto setting has adjusted my strides to
Walk 71.4cm which is 0.415 x my height for males
Run 77.2cm " " " 0.448 x " " " " "
The walking factor is a globally recognized average for the male population, 0.413 for females. Running has too many variables, and there appears to be no average.factor
@The_Lion wrote:I don't know why it changed from a fix stride length to auto. Obviously because I use GPS. And yes, my runs are longer than 10 minutes. Pace between 6 and 6.30 min/km.
02-23-2017 21:25
02-23-2017 21:25
@Xlqr, check to see if all day sync is turned on. If so turn it off. This should help with your battery life.
Best Answer02-23-2017 21:54
02-23-2017 21:54
The running stride is only determined when using the connected GPS in the Running mode.
With walking the stride still needs to be set, since GPS is not used for distance while walking.
02-23-2017 23:48
02-23-2017 23:48
Actually I had a walk but cheated the Fitbit as running session and the distance was way off as opposed to my previous real run when the Fitbit distance was spot on (with Run cues off)
Best Answer02-24-2017 05:18
02-24-2017 05:18
Maybe all pop a "Me Too" in this topic if you don't mind, I think it may be useful to have a consolidated list of people with this problem ?
Best Answer02-26-2017 21:25
02-26-2017 21:25
Where did you download Fitbit app that has Blaze in windows connectivity?
My app does not have that!
Best Answer03-03-2017 13:17
03-03-2017 13:17
@Xlqr, check your heart rate monitor. It may be turned on. If so set it to auto. When it is turned on it will run your battery down, I have not tested to see how long the battery will last after a full charge. With it being on 24x7 I would guess you could get a few days before having to recharge.
Best Answer03-22-2017 13:46
03-22-2017 13:46
If I did not except the location permissions when the fitbit tracker was set up, how can I go back in and turn on location services? I have searched thru all menu items so I need some help finding this item.
03-22-2017 13:52
03-22-2017 13:52
03-28-2017 20:01
03-28-2017 20:01
If we don't except all of those permissions when it is first setup, can you go back in and turn it on another way? Also when exercises show "GPS will not be turned on" what does that mean?
Best Answer03-28-2017 21:57
03-28-2017 21:57
@wxchick as @GarethDPhillips asked, please let us know if your phone is an Android, Windows, or IOS.
Thos will help us a lot in telling you how to check your phones permissions settings.
Yes there is no problem in giving permissions now.
As for you GPS question, it means that GPS will not be used. Please either let us know what screen your looking at or post a screen shot?
Best Answer03-29-2017 01:50
03-29-2017 01:50
@wxchick, you will see the phrase "GPS will not be used" when you go to edit the settings for your automatically recognized activities using SmartTrack. This is to remind you that GPS cannot be turned on/ used in conjunction with automatically detected exercises, and also that distance will not be calculated.
Best Answer03-30-2017 19:34 - edited 03-30-2017 19:38
So can it be turned off or turned on? And why does it say this? But isn't that the whole purpose of having this tracker? Okay another scenario if I go into exercises, select walk, wait for it connect to my phone it should not say unable to find phone. Phone is paired, connected because I can control music.
Best Answer03-30-2017 19:42
03-30-2017 19:42
It is android os and a Kyocera.
Best Answer03-30-2017 19:59 - edited 03-31-2017 17:23
@Julia_G I cannot advise users because I never have any problems with connection. Even on the 29th March I concurrently ran MobileRun and Connected GPS with the Blaze. No connection issues that I could see. I was doing tests for this topic.
All I can do is advise what my settings are on my Sony Android V7.0.. and I don't have "All-day Sync" set. But I do have Location Mode set as High Accuracy. That was the default.
So no dropouts or jumping over high buildings. During this test I had other Bluetooth devices straying around.. The Fitbit One, the Surge and my Bluetooth hearing aids ![]()
The "Both concurrent maps are there" was because it initial didn't save but about 20 minutes later it was in my activity log. As you can see 2 x maps with only 1 minute in starting time difference.
@Julia_GKeep up to great flow of help for the users..
Best Answer03-31-2017 07:46
03-31-2017 07:46
@Colinm39 wrote:Even on the 29th March I concurrently ran MobileRun and Connected GPS with the Blaze. No issues at all.
@Colinm39 you had an issue if those were concurrent - approximately 20% difference in distance and a pace error (12:29 vs 11:55).
03-31-2017 17:56
03-31-2017 17:56
@wxchick I'm not sure where your seeing the "will not be used error", but let's look at permissions first.
Go to your phones settings, Swipe down on your home screen.
Now Apps - Application Manager - Fitbit - Permissions and accept the ones you want or just accept all.
As for turning the GPS off or on this is done right on your Blaze. After selecting Walk you will notice a settings gear in the lower left corner of the trackers screen. Tap this the decide if you want GPS or not.
