05-01-2016 21:04
05-01-2016 21:04
05-03-2016 00:17
05-03-2016 00:17
This is also exactly what support told me.
Loose connection the watch stops recording the activity. I kinda had to force this answer out of them backed up by using a garmin edge 810 at the same time as the new blaze. The garmin worked, blaze failed misserably.
So I thought well, maybe its not great at biking so I'll go on a walk. It did ok at that until the last ten minutes where it disconnected again.
I don't really see a use for this watch, it'll go back and I'l get a refund until something else comes along that fits the bill.
Shame really.
05-03-2016 20:15
05-03-2016 20:15
05-04-2016 00:05
05-04-2016 00:05
05-07-2016 14:18
05-07-2016 14:18
@hawkyou @LightChase @jwebb72 Have you tried using MobileRun in the Fitbit app while wearing Blaze to see how it compares?
05-07-2016 14:25
05-07-2016 14:25
05-07-2016 14:51
05-07-2016 14:51
@jwebb72 It does seem weird, I'll have to look into it a bit more. In the meantime, perhaps using MobileRun would be a good option.
05-07-2016 15:08
05-07-2016 15:08
05-08-2016 00:42
05-08-2016 00:42
@AndrewFitbitMines gone back chap. Was utterly useless as a fitness tracker and once fitbit acknowledged the blaze works like this it was game over for me. The bottom line is these devices should just work. Stopping exercises randonly because of a 3rd party system is a terribly poor design decision so I'm out and 150 quid back in my pocket.
05-08-2016 08:44 - edited 05-08-2016 08:45
05-08-2016 09:01
05-08-2016 09:01
Here is one of my first test walks.
Amd this one is after the firmware update.
I noticed while the lines are straight it has my walk shifted.
Wroth both the phones GPS was set to hough accuracy.
02-22-2017 10:02
02-22-2017 10:02
I'm having this issue as well and it is very frustrating that fitbit won't do anything about it. Sometimes the entire run gets tracked and sometimes it'll cut corners and the map clearly shows where there is an issue
02-23-2017 03:03
02-23-2017 03:03
I'd like to add to this post, as I am one of the many having this issue. It is now happening on 100% of my runs, at seemingly random intervals. Often I find that 50% of the run is missing as the Blaze disconnected at that point (mobile icon on my Blaze screen showing a red strike through).
I too am trying with support, but I am actually annoyed (very annoyed) that they aren't acknowledging this as a known issue, it isnt even listed as something they are aware of.
I am tracking the run on my phone using another app, which is 100% perfect, so I know this isnt GPS related. What is the phone disconnected icon actually telling us? There seems to be contradictory pieces of information;
Is it informing us that the bluetooth connection to the phone is lost, or is it telling us that the phone has no GPS signal?
I dont think either is true, as my other run tracker is able to track the run with 100% accuracy, and whilst the Blaze is showing the disconnected icon, I can see that if I open the Fitbit app, my steps update! Even though the connected GPS is still disconnected. Makes zero sense.
One thing I am going to try is to stop the Fitbit app from syncing by turning off all day sync. I may also turn off always connnected. I wonder if the app polling the tracker whilst the tracker is trying to use connected GPS may be an issue?
I notice on Android that location services now use WiFi and Bluetooth scanning to improve the accuracy of Location. I will also try turning off that Bluetooth scanning (and possibly also WiFi) as that cant be a good thing.
Other than that, I'm runnign out of ideas. I wear the phone on my arm, so its very close the watch.
Could a loss of mobile data / cellular service cause this? We need some more quality information from Fitbit support , or sadly my Blaze is also going back.
02-23-2017 05:00
02-23-2017 05:00
Im actually able to replicate this just sat at my desk at work, my phone is right next to my wrist.
No other bluetooth devices are connected to the phone.
an app called GPS information shows a good "3D fix"
its been running a 50 min run and has disconnected twice (which is better than I usually experience as it often dies <5 mins in)
02-23-2017 06:34
02-23-2017 06:34
@GarethDPhillips wrote:Im actually able to replicate this just sat at my desk at work, my phone is right next to my wrist.
I did the same thing and I have tried again last night while walking and it worked great. I ran it in airplane mode on my iPhone 7 and everything was good. I also ran it again going back from my end point to my home and it worked great with airplane mode off again.
The only other thing I did was reset network settings at the request of the Apple support person I chatted with yesterday.
I am going to try a run again tonight and see.
To give further information, it seems that yes a loss of LTE / data connection can cause a loss in location information because it is used in conjunction with the GPS chip in the phone itself. I had quite a discussion with Fitbit support yesterday.
02-23-2017 06:59
02-23-2017 06:59
When starting a run, does the Charte 2 show that it is connected to the GPS?
As for indoors, usually this will not guve a good signal, sinc the GPS is a line of sight.
I also find that if tye phones memory is to full, then i have GPS problems on my Galaxy S5.
02-23-2017 10:36
02-23-2017 10:36
Same thing has been happening to me rather consistently. I found that connecting my Blaze to my phone using bluetooth classic seems to help. I am also able to start a run on my phone in the Fitbit app and on my watch at the same time, if the Blaze messes up the phone accurately records it so I just delete the Blaze workout and go with the one tracked with the phone. This proves that the problem is actually with the Blaze and not with the phone's on-board GPS signal.
02-23-2017 10:46
02-23-2017 10:46
02-23-2017 22:30
02-23-2017 22:30
I am facing the exactly same problem...and now it has become quite often...expecting a fix soon from Fitbit...and also thinking of shifting to GARMIN if it does not get resolved.
02-24-2017 05:11 - edited 02-24-2017 05:19
All,
Maybe pop a "Me Too" in this topic if you don't mind, I think it may be useful to have a consolidated list of people with this problem ?
02-24-2017 05:23
02-24-2017 05:23
I thought about doing the same but I'm not sure how much of the Garmin data will sync with Fitbit.
