05-01-2016 21:04
05-01-2016 21:04
03-02-2017 03:43
03-02-2017 03:43
@Arifyusof wrote:Regarding this issue I think it's a phone compatibility problem with blaze. I was using a Xiaomi note 3 (Qualcomm) and had no issues with the blaze, 100% tracked. Last two days I started using a Samsung j7 phone and I'm having your issues where the workout is getting cut off. So far I'm 2/2 failure officially.
Seems plausible, but some people are getting in on iPhone as well as android so I'm not sure its clear-cut.
Maybe Bluetooth LE is just a bit susceptible to interference and drop-outs. Connected GPS may be more stable if it used Bluetooth classic, but that isn't an option.
Support are replacing my Blaze for a new model, but I dont believe that will make any difference.
Best Answer03-02-2017 03:48
03-02-2017 03:48
Best Answer03-02-2017 04:20
03-02-2017 04:20
As I have mentioned previously, I am starting think that my "Tile" key finder app is at least contributing to this issue. Its certainly not clear-cut, so I cant be sure, but I do know that on the default settings, the tile app will use Bluetooth in the background to try and locate your tile keyfob, and also any other tiles from other tile users. This constant polling for devices may be contributing to the issue, but I'm not sure.
I have set the tile app to not look for tiles when the app isn't running, and it seems to be much better. I have also set location services (Android / Google Nexus 5x) to stop using Bluetooth and WiFi to provide location. I have set it to "Device only" which is GPS only. No Wifi, cellular or Bluetooth is used. It complains that this isnt the most accurate setting, but I always find this annoying, as surely outdoors, pure GPS is the best possible way of getting location accurate? I understand that indoors with poor or no GPS lock, it is required to gain at least an approximate location.
All these services trying to use the Bluetooth stack on the phone cannot be ideal. I think its all a limitation of Bluetooth LE. Im sure bluetooth classic would be more robust.
I just mention all this in case anybody else has any of the "smart" key finders, or any other apps using the Bluetooth service unnecessarily
Best Answer03-02-2017 04:31 - edited 03-02-2017 04:32
Agreed. However we may want to see why it works flawlessly with the xiaomi. Is there some connectivity software that is optimized better?
With the xiaomi the blaze can show disconnected but the tracking is still spot on when you ends the workout. I only do cycling and apart from commuting, I do mountain biking in the forests with no issues.
With the Samsung however riding to work in wide open areas and highways gets cut off. My office is not in the city centre with a lot of tall buildings.
I'll try again but my off-road rides will definitely use my surge until I get the blaze to work. I'll consider checking with Samsung too.
Best Answer03-02-2017 04:35
03-02-2017 04:35
@mvan231There are many issues being posted and I'm one of the lucky ones because I have a Mobile 4GX tower in "line of sight", 170 m (185 yds) as per Google Earth from my front door and most of my walking is in a 1 km (1,100 yds) radius and no tall buildings..
Maybe not lucky, if the scientists come out in generations to come and say that the "signals" have affected us.
I have used my Blaze, MapMyRun and Polar Beat, all using phone connected GPS and have no plotting issues. In saying that, MapMyRun last night, as I started walk, the plot jumped over next doors house, over the next and then back again. about 100m.. Otherwise taking that into account the walk was perfect.
I use my Surge with Integrated GPS to check against the other devices and I'm happy with its accuracy..
But, I have only had success in plotting the route since I upgraded my Android Phone to the Sony Xperia XP Android V7.0 (not on the compatibility list). My earlier phone, the Sony Xperia Z1 (on the list), with Android V4 and V5 was like Superman...and jump over high buildings and swimming pools. Also I had every syncing issue reported by users early last year. All is now working re the App...
I won't enter into the Blaze distance issues, and I will post comments when Fitbit release the expected firmware update if that doesn't corrects some issues. Of course if those "bugs" are released.
Best Answer03-02-2017 04:53 - edited 03-02-2017 16:40
@GarethDPhillipsJust got your post... and I will take your suggestion on because I was thinking of purchasing the key finder, mainly for for my wife to find the Panasonic phones in our house...
I used to have those issues with my earlier Sony phone and since upgrading the phone I walk with two x Bluetooth hearing aids, and the other night I used my HRV Elite with a Polar H7 strap plotting my Variable Heart Rate (HRV), while the Blaze was using Connected GPS. no issues with the Blaze plotting a symmetrical plot and no dropouts. Also have my Fitbit One.
Late last year I lost one of my hearing aids in the garden.. Fortunately it had a new battery and I used the Bluetooth Finder App on the phone to find it. It homed in on about a 7ft (2m) radius and I found it, phew $4,500 worth but insured..
I'm a very Senior Senior..
So in summing up there are 5 Bluetooth devices while I'm walking and the Fitbit One syncs through our house from about 50 ft..
So the more we can input in the forums the better ours and Fitbit's outcomes will be..
Best Answer03-02-2017 05:42
03-02-2017 05:42
Best Answer03-04-2017 13:20
03-04-2017 13:20
Maybe a grace from the Fitbit gods.
Not sure if this will address issues with connected GPS though. We will see.
https://community.fitbit.com/t5/iOS-App/iOS-App-Version-2-33-is-now-available-3-3-17/td-p/1444784
Best Answer03-07-2017 05:17
03-07-2017 05:17
How is everybody getting on?
I have managed to track 3 or 4 runs with 100% reliability since I stopped my "Tile" key-finder app from looking for tiles constantly in the background. This is really positive.
I have been using wired headphones whilst trying to troubleshoot this problem, so I am now tempted to go back to Bluetooth to see if I can sill track runs reliably. I am happy with the current reliability, but if I can use Bluetooth headphones rather than wired, that would be even better.
One of the many things I also tried in my troubleshooting was to turn OFF all day sync and always connected in the Fit bit app, so at some stage I need to turn that back on and see if it makes a difference. My rationale was that if the Blaze syncs periodically during a run, that extra load on the Bluetooth connection cannot be helpful.
I'm increasingly sure that my issue was the Tile app, but it will be interesting to hear if anybody has any success in stopping the Blaze from auto syncing whilst running.
Best Answer03-07-2017 05:52
03-07-2017 05:52
Best Answer03-08-2017 16:18
03-08-2017 16:18
Yet another disconnected run today
Best Answer03-09-2017 10:46
03-09-2017 10:46
here is the latest response from fitbit support:
"Hi Mark,
Thank you for checking in with us in regard to your ConnectedGPS logged runs. We apologize for the delay in our response.
While reviewing your case, we noticed that you may be using both the Fitbit app and Strava at the same time.
As you know, other software can interpret GPS data differently which can cause the calculations to be slightly different than what’s shown on Fitbit. For the most consistent experience and to ensure that there is no interference between the apps, its best to use only one of the applications for keeping track of your GPS data. At this time, we kindly ask that you log a ConnectedGPS run with only the Fitbit app running to see your experience improves.
We hope this helps. Let us know if you have additional questions.
Sincerely,
Danny L and the Fitbit Team"
Best Answer03-09-2017 18:33
03-09-2017 18:33
I'm on a xiaomi redmi note 4 now. All issues are gone.
Best Answer03-09-2017 19:54
03-09-2017 19:54
Best Answer03-11-2017 21:06
03-11-2017 21:06
I ran again today and had disconnection issues again. I'm hoping the replacement yields some good results.
Best Answer03-14-2017 18:02
03-14-2017 18:02
I got the replacement pebble today and still having issues with disconnection. Clear skies tonight too
Best Answer03-14-2017 19:03
03-14-2017 19:03
@mvan231I'm a person who goes back to 1st principles when we have these issues. I realise it is basic but that's the way I problem solve technological issues.
With Connected GPS I break the problem intro separate test cases.
1. The first is to use MapMyRun, which eliminates the Bluetooth and the Blaze on street tracking which makes it easier to compare the Google pedometer. No hiking etc.
2. Then use Google http://www.mappedometer.com/ and compare.
3. If those results are acceptable it shows me that I'm getting a decent link to the mobile phone system, then to GPS
4. Then I reintroduce the Connected GPS Blaze Fitbit and examine those results
But before I do all of that, the obvious, ensure all of my firmware is up to date.
I also use Polar Beat with the Bluetooth chest strap and Connected GPS as my third party Bluetooth Connected GPS..
Last year, before I upgraded my phone with the latest Sony Android, (
the contract was due for renewal from my Telco provider). I had every issue that Fitbit users were reporting and I blamed it on my environment.. I have had the Blaze for just over 12 months. Every Fitbit I had, had some issues, mainly syncing. The tracking on the Blaze was like Superman.. jumping over high buildings etc.
I received the new phone in October..and of course parallel to that, Fitbit release firmware and App upgrades, but I haven't looked back.. Perfect results for 5 months and have never missed a sync. Probably a combination of all of that.
My environment hasn't changed, I'm in the same house with all of the electronic gear and here is the other nights Connected GPS.. A big but.... That walk is close to a mobile phone tower.
To check the mobile phone option I set the Blaze going from start to finish, while driving in the car to my local mall, a distance of about 3+ miles (5-km) and it tracked perfectly. The only distance recorded was my walking to the car and from the car after parking. This also tested that the only distance picked up after I set the exercise GPS was my walking to the car and from the car until I stopped the GPS. Perfect tracking again..
All of these methods will help you establish where the errors appear and can help you with Fitbit Support.
Best Answer03-15-2017 03:03
03-15-2017 03:03
Best Answer03-15-2017 03:19 - edited 03-15-2017 03:23
Yes you are correct, the Fitbit support staff (no disrespect, they are
trying to be helpful) will give totally different opinions to different
customers, they are only human. You should be able to run as many
applications using GPS services as you want on your phone, and any other
apps you try will work 100%, it is only ever fitibit connected GPS which is suffering
this problem as you say, if the fitbit
app tracks the activity that is fine, as are all other apps on the phone. The issue is definitely specific to connected GPS, and the data being sent from the phone to the blaze.
I agree that this isnt, in most cases, a GPS signal lock issue. I believe
it is the bluetooth LE connection being interrupted between the tracker and
the phone. Its clearly got a weakness, whether it is in the Blaze or in the
mobile device bluetooth stack I do not know.
I found that having my phone bluetooth services used by my tile keyfinder
app contributed to this problem significantly. Now I have stopped the app
trying to locate my keys it has improved things a lot, but I still get
occasional drops in the connection, and these are not GPS signal loss, as
other apps can track my run fine. I could literally track it in 5 apps
flawlessly.
The whole connected GPS piece is the problem here, and only a Fitbit
developer or somebody in that specific area can really comment, they are
clearly not passing anything down to the frot line support people. Swapping
out units for new ones isnt going to help.
Best Answer03-15-2017 03:31
03-15-2017 03:31
