02-26-2016 20:19 - last edited on 02-27-2016 10:52 by SunsetRunner
I just got my Blaze. The set up was fine until I started charging it. The battery icon never showed on the screen. I also have a Charge and it charged using the same computer an hour before. Anyone have a problem charging the Blaze?
Moderator edit: title for clarity.
03-09-2016 22:11
03-09-2016 22:11
03-10-2016 06:19
03-10-2016 06:19
03-10-2016 08:16
03-10-2016 08:16
Mine didn't work with just syncing, try rebooting from the screen if the sync alone doesn't work. Good luck!
03-10-2016 09:39
03-10-2016 09:39
Thanks for the advice but i spent 2 hours with Fitbit tech support and nothing worked. It was sent back. dead on arrive it was.
03-10-2016 11:13
03-10-2016 11:13
Hey everyone, glad to see a few resolutions and positive experiences with our Support Team here!
A few tips:
03-17-2016 22:13
03-17-2016 22:13
Got my Fitbit blaze today and couldn't get it to charge. After reading this forum plugged it into the wall to charge instead of the computer and I was then able to update and use my fitbit! Held down left button while booted up...but don't know if that did anything. So excited to run with it tomorrow!
03-19-2016 17:29
03-19-2016 17:29
I'm having the same problem, but the issue is that I cannot setup, update and sync the fitbit because it says "battery too low" and cancels the update. But device refuses to charge.......
03-19-2016 19:27
03-19-2016 19:27
As others have mentioned, are you using your phones wall charger, and inserting correctly?
03-23-2016 14:03
03-23-2016 14:03
My fitbit Blaze will not charge. It doesn't even show the screen where you can see the battery. I have tried for two days to get it to charge. Ive read some replies in hope that it will help but nothing yet :(((
Any suggestions?
03-23-2016 14:08
03-23-2016 14:08
My tip would be to scroll up 4 posts from yours and read the tips @EmersonFitbit posted, if none of them work his last tip gives instructions on how to contact firbit
03-26-2016 06:23
03-26-2016 06:23
03-26-2016 18:20
03-26-2016 18:20
I had this issue at first. Make sure it's plugged into a COMPUTER, and that you're on the CLOCK screen before you begin charging. Also make sure everything is facing the correct direction.
@Ladychaos wrote:
Has anyone figured out what is wrong. Mine doesn't charge either.
04-12-2016 09:16
04-12-2016 09:16
The battery is showing for me, but definitely not for 15 seconds. Seems to be a severe bug in the product.
04-30-2016 19:37
04-30-2016 19:37
05-06-2016 08:09
05-06-2016 08:09
I'm having the exact same problem - just got a Blaze yesterday and I can't get it to charge. It doesn't seem to fit right into the charging cradle (and I do have it in there correctly). I've tried every USB port on my computer as well as my iPhone's wall charger with no luck. I just chatted with customer service and they've put another charger in the mail for me. Really disappointing, as I was quite excited to use the Blaze this weekend. I'm a longtime Fitbit user but am just about at the end of my rope with all the product flaws. My last Fitbit was a Charge, and in the past year I've gotten three replacements due to the bands/housing falling apart within a few months. I was offered a discount on another Fitbit after my year warranty ran out and used it on the Blaze, hoping there wouldn't be problems with it too. The customer service is great, but I'd really love to not have to use it so often.
05-06-2016 08:14
05-06-2016 08:14
05-06-2016 08:38
05-06-2016 08:38
I tried a restart - didn't work on mine. I think mine is a cradle problem- a few other people said theirs didn't fit in the cradle securely, and mine wasn't either. It's wobbly even with the lid closed, so it's probably not connecting. And it is turned around the right way.
05-06-2016 08:50
05-06-2016 08:50
05-06-2016 09:01
05-06-2016 09:01
I'm hoping maybe it will work on my laptop - I've tried it with my desktop at work, and it's plugged into the wall with my iPhone charger right now - I was hoping it was actually charging despite the lack of the charging icon, but it doesn't look like it. At least I'm not trying to update the software too! Very annoying - I was really looking forward to using it today and this weekend.
05-06-2016 09:24
05-06-2016 09:24
I've messed around with mine all morning too! Right now I've got a piece of paper between the lid and the Blaze, hoping that will secure it since somebody else said that worked for them. Of course I put the paper over the screen so I can't tell if anything is actually happening!
