02-26-2016 20:19 - last edited on 02-27-2016 10:52 by SunsetRunner
I just got my Blaze. The set up was fine until I started charging it. The battery icon never showed on the screen. I also have a Charge and it charged using the same computer an hour before. Anyone have a problem charging the Blaze?
Moderator edit: title for clarity.
02-13-2017 01:21
                              02-13-2017 01:21
Hey @PamS2 what device are you using to charge your Blaze through? I hope it is your phones charger.
 Best Answer02-19-2017 16:41
02-19-2017 16:41
I am so frustrated. I just opened my box an tried to do set up but it says that it needs to be charged first. I put it in the cradle and it wont charge. I have read that you can't charge it without setting it up. So, now what do I do?!!!!!
02-19-2017 16:45
02-19-2017 16:45
So how long should I expect it to charge before I can complete the set up.
 Best Answer02-19-2017 16:59
                              02-19-2017 16:59
About an hour should be enough, or plug it into its charger and set it up while plugged in.
 Best Answer02-19-2017 17:05
02-19-2017 17:05
I plugged it into the wall instead of the laptop and within a few minutes it finished updating. Now, when I press on the home screen, it shows the battery level. Thank you for your help!!!
02-19-2017 17:22
02-19-2017 17:22
02-19-2017 18:11
02-19-2017 18:11
 Best Answer04-01-2017 17:25
04-01-2017 17:25
Such garbage, you cant update your Blaze if the battery is low on a new purchase. No USB receptacle or USB jack on the computer seems to work. I have the USB plugged into my computer for over 4 hours now and still will not get charged... first time buying a fitbit, most likely last time. Being I am so frustrated on spending over 200 dollars on a device that is NOT user friendly! You guys at fitbit should come up with a better system for newly bought devices. Garbage in MY opinion.
 Best Answer04-07-2017 12:54
04-07-2017 12:54
I just purchased the blaze from fitbit.com because my fitbit charge fell apart. I am going overseas on Monday, and I bought it for this trip. I cannot charge it. It clicks into the charger, but I don't see any icons.
Please advise.
Karen Posey
 Best Answer04-18-2017 19:02
04-18-2017 19:02
i opened it and it looked great. it was just bought 5 minutes ago and i tried to charge it, but the icon never popped up. help please
 Best Answer05-22-2017 09:34
05-22-2017 09:34
i just received my 3rd blaze. this one does not accept a charge either. this is clearly a major design flaw when looking at the myriad number of complaints. at least, so far, no issue with fitbit sending a replacement, but this experience is really turning me sour on a company that i have always been very positive about.
 Best Answer05-22-2017 11:40
                              05-22-2017 11:40
What things are you seeing tgst tells you the Blaze isnt charging?
Have you set the Blaze up, and the www.fitbit.com/setup message is no longer on the screen?
What type of device are you using to charge the Blaze, have you tried more than ine device? Especially have you used your phones wall charger?
Have you tried mix and matching the charging cords?
Thank you, it makes no sense that 3 seperate units and 3 seperate cords could be bad.
		12:38
		08:47
			FerdinandFitbit
		05-22-2017
		12:38
		08:47
			FerdinandFitbit
i have used all 3 of the charging cords on each of the units. both connected to my computer and to a wall outlet. virtually none of them show the battery symbol or indicate any charging at all. every attempt to link/set up results in a message that i must first download updates, but i cant do it because the battery is low and needs to be charged. it may be unthinkable that this could happen 3 times in a row, but it certainly has. the blaze i got my wife at the same time as the first one works just fine. none of the other 3 has........
Moderator edit: Removed personal information
 Best Answer05-23-2017 15:25
05-23-2017 15:25
 Best Answer05-24-2017 05:09
05-24-2017 05:09
 Best Answer05-24-2017 07:04
05-24-2017 07:04
I got the setting up message, so plugged USB into my Phone Charger well away from my phone and pc, left for an hour, no indication of it charging (apart from the logo looking like something was happening). When I retrieved it I used my Laptop to Sync then update! Showed at 50% charged! ![]()
05-24-2017 07:23
05-24-2017 07:23
Since this thread is still going on I'll reiterate my results. I left it charging overnight. Even though it wasn't showing me that it was charging, it did. I was then able to do the update.
So, most likely it *is* charging. The design flaw is in the UI itself since it doesn't tell you that it is. They really need to either send them out charged, with the update, or affirmative instructions to update that let you know it is charging. It is even worse that when you contact them, they don't even know their problem. The fact that they would send out replacements really does not indicate they have a grasp on their own technology.
05-25-2017 12:37
05-25-2017 12:37
 Best Answer05-30-2017 14:00
05-30-2017 14:00
I have tried plugging onto USB on 3 different lap tops still not charging. No battery icon either
 Best Answer06-12-2017 13:24
06-12-2017 13:24
yes, I cant seem to get my Fitbit blaze charge in its case whether attached to the laptop or an adaptive fast charger.
