01-01-2017
07:04
10:13
01-01-2017
07:04
10:13
Hello!
How can I track my Yoga classes? In the menu I dont have this point (Run, Weights, Treadmill, Workout, Elliptical, Bike, Internal Workout, but no Yoga)
01-01-2017 07:11
01-01-2017 07:11
On the dashboard go to settings scroll down to exercise shortcuts and put a check mark in Yoga. It will need to sync before it takes place
Wendy | CA | Moto G6 Android
01-01-2017 07:11
01-01-2017 07:11
01-02-2017 16:47
01-02-2017 16:47
I just got the Charge HR & I'm trying to figure out how to log my yoga. I just tried the steps outlined & it looks like it is grayed out & won't let me click on Yoga in the Exercise Shortcuts. Am I doing something wrong?
01-03-2017 11:51
01-03-2017 11:51
I can't figure out how to track my yoga?? Please help. I also followed the online advice but it won't work.
01-03-2017 12:10
01-03-2017 12:10
@Supermomof3 @Ezrafan1127 Just as WendyB described in her post above, you should be able to add the "Yoga" exercise shortcut to your Charge 2 by following the instructions listed here.
Hope this helps you both out!
Best Answer01-07-2017 13:08
01-07-2017 13:08
I checked Yoga. It is now available on my Charge 2. I did a yoga session this morning. I pressed Yoga in my watch. Press stopwatch - started time - ended time when done.
Went on the computer - refreshed all options (synch). No Yoga - still three hours later.
What am I doing wrong ?
Thank you
Line C. C.
01-07-2017 13:38
01-07-2017 13:38
Forget my comment - I was doing the sequence wrong on my watch.... I got it working now !!!!
Best Answer01-08-2017 01:51
01-08-2017 01:51
Hi all!
I have the same problem, I went on the tracker tile and I can't see Yoga. Do I maybe need to update the app or something similar? Thanks!
Best Answer01-08-2017 08:46
01-08-2017 08:46
Best Answer01-08-2017 08:47
01-08-2017 08:47
Best Answer01-17-2017 01:33
01-17-2017 01:33
Hello Wendy
Thank you for the help!
Happy Fitbit'ing
Best Answer02-04-2017 10:23
02-04-2017 10:23
I did that on my app. And I synced the Fitbit 5 times. It's still only showing run, stopwatch and relax on my options.
Best Answer04-01-2017 19:05
04-01-2017 19:05
Hi, thanks for the instructions, however, my charge 2 (brand new) does not seem to have the options that are listed in the instructions in your link. As instructed I click on my Account button on the bottom right hand side. Then it says "Tap your tracker tile". I only have an option under SETTINGS called Exersice Tracking, but that only deals with music related to my exersice.... I also cannot find anything called exersice shortcuts.
what am I doing wrong?
04-01-2017 19:20
04-01-2017 19:20
I have a Charge 2. I do not see Exercise shortcuts anywhere on the dashboard settings.I have been doing a Jillian Michaels workout, and get no credit for it. The only thing my tracker seems to recognize is walking.
04-01-2017 20:09
04-01-2017 20:09
@Bodilitsa, @JVG9746 - you have to use the Fitbit app, not the Fitbit.com Dashboard. On the Fitbit app, open the Account screen, then tap on the Charge 2 device to open the Settings screen for the Charge 2. Scroll down until you find Exercise Shortcuts, and tap on it. There you can add the Yoga shortcut to the exercises that will be available on the Charge 2 tracker. Sync the tracker. To select the Yoga exercise on the Charge 2, press & release the side button repeatedly until the first exercise shortcut displays, then tap the screen until Yoga appears. Press & Hold the side button until it vibrates to start the exercise.
Best Answer04-01-2017 23:25
04-01-2017 23:25
Best Answer07-15-2017 21:50 - edited 07-15-2017 21:51
For some strange reason, I am not able to locate 'Yoga' under the exercise shortcuts tab. I'm not sure what I'm missing. Tried following all the steps mentioned here and in the 'help' link. I do Yoga regularly, it would be a disappointment if I'm not able to track it .
Also attaching a link of the screen that I see.
Best Answer12-31-2017 13:47
12-31-2017 13:47
Hmm... I don’t have Exercise Shortcuts. Only Exercise Tracking, Heart Rate Zones, and Advanced Settings. Am I in the wrong place?
Best Answer12-31-2017 16:48
12-31-2017 16:48
Click/tap on the Charge 2
This is your settings Click on the red circle
Tap edit again
Check yoga - then save
Now do a sync
Best Answer01-11-2018 11:18
01-11-2018 11:18
Thank you Rich_Laue, that actually helped! I can log yoga in my charge 2 now, I hope someone else sees this (I was looking in the app, not the website...was confused as hell).
