11-26-2018 21:28 - last edited on 11-17-2020 14:31 by MatthewFitbit
Just bought a charge 3 and in the exercise tracking feature the “interval timer” exercise on the Fitbit tracker stops after 10 minutes. After 10 minutes it goes back to the time/home screen. Can’t figure out how to stop that. I want to stop my interval timing workout manually when I am finished. How do I adjust it?
11-27-2018 11:56
11-27-2018 11:56
Hey there @Jkirby1, it's nice to see you around the forums! Please check that your settings are as desirable.
By default, the interval workout consists of:
To set custom intervals:
Let us know if you need further assistance!
11-27-2018 13:07
11-27-2018 13:07
That doesn’t solve it. On my charge HR, I would hold the side button down and have the tracker track my workout until I held the button down again to end the workout on my Fitbit and see the details on the workout. That’s what I want to do on my charge 3. Yet when I choose the interval setting (even if I set a goal of 20 minutes) the tracker stops at 9 minutes and some odd seconds.
12-06-2018 16:01
12-06-2018 16:01
I would guess that the goal is simply a reference point that Fitbit will then compare to. If you want to change the total workout time to 20 minutes you will have to increase the number of intervals. In this case "Repeat" 30 times with the default interval.
Desired Workout Time (seconds) = Interval (Move + Rest Time) x Repeats
Hope this helps!
12-25-2018 08:53
12-25-2018 08:53
That is not working. I have tried several times and it keeps going back to the default. From what I am reading after a Google search it looks like this is a glitch in the system. Very disappointing as using this feature during my interval training was the main reason for getting the Fitbit Charge 3. I may have to exchange it for the Apple 😞
01-01-2019 11:19
01-01-2019 11:19
Agree with above poster, just want to know how to end the interval timer if I’m finished with a workout and it’s still going
01-06-2019 16:30
01-06-2019 16:30
This is happening to me too. No matter how many times I change the intervals in exercise shortcuts it defaults to my last setup when I sync. Sounds like the default for you, and 20/10s for me x14. The changes don’t stick.
01-07-2019 02:24
01-07-2019 02:24
No matter what, the intervals keep foing back to the prior values. The saves never change. Ideas?
01-14-2019 08:07
01-14-2019 08:07
After I changed my interval setting through the app, I selected "sync now" on my device page (same place where I accessed exercise shortcuts). Now when I use my fitbit, the interval workout has been updated. I tried before, without selecting sync now, and my fitbit was still giving me the default settings.
01-17-2019 04:30
01-17-2019 04:30
I’m having problems with mine saving the times when I adjust them. Even did the sync now in the settings and it keeps goin to default
01-23-2019 13:00
01-23-2019 13:00
I have tried to adjust the interval times both on the app and on the online dashboard and no matter what I do, after I sync my Charge 3 the intervals automatically return to the default setting of :30 and :10. How do I permanently make the change I want.
01-23-2019 14:40
01-23-2019 14:40
01-24-2019 12:19
01-24-2019 12:19
How do u remove the app from the Fitbit?
01-24-2019 14:50
01-24-2019 14:50
Go to exercise shortcuts and at the top right corner you should see edit, tap that and you will see the red minus button appear next to each activity, click on that and it’ll remove it. Go back and sync device then go back into exercise shortcut and add activity which is at the bottom +exercise shortcut 👍
02-06-2019 06:35
02-06-2019 06:35
I have a Charge 3, and when I sync it after changing interval times, it sets back the times it had before. It drives me completely nuts and that was happening on my charge 2 as well. For example if i set a 30/30, and I change it to a 30/25. After I sync it it goes back to 30/30. 😞
02-08-2019 01:18
02-08-2019 01:18
I set my phone on airplane mode, made the changes to the interval timer, waited for it to update on the Charge 3 and then turned off airplane mode. This worked for me
04-23-2019 18:58
04-23-2019 18:58
Thank you so much. Your solution worked for me!
04-24-2019 10:29
04-24-2019 10:29
Can not change interval training. I want for 1 minute rest 30 seconds for 40 minutes. How do I change the Charge 3 to this?
04-24-2019 11:14
04-24-2019 11:14
Tried this last night and it worked. You have to delete the current interval workout and add a new one with the time you want.
06-17-2019 14:51
06-17-2019 14:51
Thank you, finally a solution that actually worked! It's ridiculous that it is this hard to change the interval time!
