All morning my charge 5 won’t sync to my iPhone 11. I’ve gone through every step including uninstalling the app, turning blue tooth off and on, pairing again, restarting both devices. Only thing I haven’t done is a factory reset which I had to do last month when alarms stopped working and I don’t really want to do again if that’s not the problem.
09:42
11:41
LizzyFitbit
08-17-2022
09:42
11:41
LizzyFitbit
Yes.
So I deleted device from Bluetooth and paired again.
That’s when it started working
Moderator Edit: Personal info removed
Best AnswerI thought this issue was resolved too, just came back from a long walk/jog and it does seem to be syncing but it's stuck on updating the exercise screen??? I hope they are working on this issue to get it resolved. I just purchased this Charge 5 on August 4, so it's brand new. Never had these issues with the 3 prior Fitbit Charges I've had.
Best AnswerI can pair and sync with my old Pixel 3 XL, but my new Nothing Phone wont do any if it... Both use the same App version.. WTH
Best AnswerNo it says it’s synching, but when it’s done nothing has synched.
The screen of the watch is still not responding.
what do i do?
Do i return it for warranty?
The calorycount is automatic, even if you do nothing.
it only increases the basic number when you exercise… do you have steps?
Hi everyone. Welcome to all new members.
Thanks for sharing your comments about this. If you're still experiencing syncing issues with your Charge 5, please confirm that you've followed the suggested steps here: Why won't my Fitbit device sync?
It'd be really helpful to confirm the model and OS/software version of your phone.
Hope this helps.
Best AnswerI'm having the same problem. My Charge 5 Will not sync and is stuck on logo screen. I've done all recommended procedures and will not restart or turn off until battery runs low.
