Charge 5 won’t sync
All morning my charge 5 won’t sync to my iPhone 11. I’ve gone through every step including uninstalling the app, turning blue tooth off and on, pairing again, restarting both devices. Only thing I haven’t done is a factory reset which I had to do last month when alarms stopped working and I don’t really want to do again if that’s not the problem.
689 REPLIES 689
I've been having the same issue all morning and literally done everything but still not working. Must be some larger issue. 😭
I’ve been going mad this morning trying all the fix-it steps.  At least now I know I’m not alone.  Come on Fitbit - DO something!
Having the same issue, had my charge 5 for 1 month and 3 days and it’s been nothing but hassle, refusing to sync regularly. Really not impressed with this Fitbit. Thinking I should of got an apple phone instead 🙄
I'm starting to think the same thing. Mine stopped syncing about 4am this morning and apart from hitting it with a hammer out of frustration lol I think it must be a technical issue Fitbit end.
I've tried everything and there's no sync with the server this morning. I know that Fitbit is talking to iPhone because I'm getting HR, step-count, etc, but none of the funky calculations such as Sleepscore are getting done. Looks like the FitBit mothership is down?
I had a Samsung watch 5 it was dreadful. So I went back to Fitbit and it's been fine until today. But their customer service is diabolical.
Had a support call. It looks like it is a problem with the App. It should be fixed till the end of the week.
I have exactly the same issue.  Just started this evening.
Glad I’m not alone. I’ve done all the same things, this morning, with no luck. The issue must be on their end.
charge 5 stopped syncing with iphone today!
Mine has had no change to the app. I'm thinking they have a server problem. I've always hated it that you can't synch locally to the phone.
I've had this once or twice before. It's irritating but give it time. They're not that bad once they get out of bed; it's only 3.30am in Silicon Valley. I think your data will catch up; it always has before.
My Charge 5 won't sync. I've tried restarting everything. Turning the phone and watch off and on but nothing works. Is there a problem with the server or something? It's really frustraring. Won't load workouts.
Hello I’ve started bath is issue too.  I’ve tried all other ideas that you mentioned I even tried separating from the Bluetooth and that didn’t work.
Mine has been the same. Last Synced on Sunday 22:30. Wish I had read this before trying everything under the sun!!
Same as Philip1485 my Fitbit is talking to iPhone because I'm also getting HR, step-count, etc, but none of the other stuff like Sleepscore or Health Metrics etc.
Can Fitbit confirm if there is an issue their end or not?
Same here. Glad it looks like it’s in their end. I can’t even contact help at this point. Too common of an issue.
There was an Android system update yesterday (15th Aug in Australia) that seemed to slip through to some Samsung devices.
Since then my wife and I get the symptoms described in here on both of our phones with the Charge 5. You can see live stats and even update the clockface but you cannot do a full sync and get heart rate data, sleep data etc. It will fail every time.
Interestingly the Charge 4 still works. So good luck figuring this out...
Meanwhile our subscriptions are ticking away (as we know how Fitbits record with quick fixes is NOT good).
Perhaps a savvy user could figure out a workaround.
Good morning, I'm having the same issues since last night and I've done the same things that you did and still without success...ssuccess...smh
Same with mine  it has stopped syncing today, have followed all instructions to restart but no good 😕
I did everything that was stated to do in the forums, help topics, etc.  Still not syncing.
kleblanc
