02-08-2021 14:16 - edited 02-08-2021 14:16
Welcome to the Fitbit Community Forums.
If you're experiencing any discomfort while wearing your Fitbit device, it’s very important to review and follow our wear and care tips. Most customers are able to wear their device without discomfort when following the wear and care tips.
If you continue to experience discomfort or your device feels hot, contact Customer Support.
11-10-2025 17:54
11-10-2025 17:54
I would like to cancel.my Fit it Premium account. Just like my first Fitbit, my Sense 2 burned my wrist. It burned my wrist so badly, it bled. So, as much as I liked it, I cannot use it. Please help.
Best Answer11-13-2025 11:58
11-13-2025 11:58
Has anyone had a good experience with a replacement wristband that is: — Breathable enough to keep on overnight. — Sturdy enough to stay clipped on to the watch part and wrist during strenuous activity like long-distance running and taking care of a grabby toddler.
I’m two months into owning the Fitbit Charge 6, and the dreaded wristband rash started to appear about 3 weeks ago. The band that comes with the watch in the box is practically unwearable for how much damage it can do to your skin.
Best Answer11-13-2025 13:19
11-13-2025 15:20
11-13-2025 15:20
Welcome to the forums @ronald41.
Thank you for bringing this to my attention, and I apologize for the experience you had with your Charge 6.
As your safety is our priority, I need additional information from you, which is best shared privately. I have sent you a private message; please check your inbox and reply if you have any further questions.
Best Answer11-13-2025 21:53
11-13-2025 21:53
Best Answer11-14-2025 05:57
11-14-2025 05:57
Hi @hanika,
Thanks for bringing this to my attention, and I'm sorry for the experience that you've had with your Charge 6.
Because your safety is our priority, I need additional information from you that would best be shared privately. I've sent you a private message, please check your inbox and reply back if you have any other questions.
Best Answer11-19-2025 18:38
11-19-2025 18:38
Hi @Mo30263, welcome to the Community!
Best Answer11-25-2025 01:12 - edited 11-25-2025 01:13
I've had my sense 2 for about 3 years and have worn it with no issues.
Over the past 2 months I've started to get a reaction to the back of the watch. It gets red and sore then very dry. It takes ages to heal then flares up again within an hour of putting it back on. This has happened on both wrists.
The watch is clean, I take it off regularly, make sure skin is clean/ dry etc
I've noticed others reporting the same issue after several years of use- is there a known problem?
Best Answer11-25-2025 03:11
11-25-2025 03:11
Hi @CymruBelle,
Thanks for bringing this to my attention, and I'm sorry for the experience that you've had with your Sense 2. Because your safety is our priority, I need additional information from you that would best be shared privately. I've sent you a private message, please check your inbox and reply back if you have any other questions.
Best Answer11-28-2025 15:07
11-28-2025 15:07
I have worn my Sense 2 daily for almost three years. About 4 weeks ago I developed a bumpy itchy burning rash under the watch (not the band).
I have:
- cleaned my watch and the charger regularly;
- made sure that my wrist is clean and dry;
- loosening the band and
- changed wrists and position.
Nothing has helped. As soon as the rash clears (after several days) and I start wearing the watch again, the rash comes back.
Is there anything else I could try or should I give up and switch to Garmin?
Best Answer11-28-2025 18:45
11-28-2025 18:45
Hi @Brookekb, welcome to the Community!
