Charge 6 cannot pair with phone
I got my Charge 6 today, charged it, and upgraded the Fitbit app, the device shows in the app but cannot pair. Turned off/on the Bluetooth and retried no difference. On Charge 6 nothing changes and displays download the Fitbit app. I reconnected my Charge 4 and it is working fine. Any pointers on what else I can try?
92 REPLIES 92
Yes this is what I'm experiencing and I'm beyond frustrated as I just
bought this charge 6 3 months ago and now can't get it to work all because
I have an android phone.... doesn't make sense. Please fix this issue asap
or refund my money
Identical issue. Iphone sync'd fine with Charge 6; Ipad was another story! After trying everything imaginable for more than an hour among the devices, I shut off Iphone's BlueTooth and the Charge 6 miraculously uploaded to my Ipad. Nice if the instructions indicated that BlueTooth on other devices had to be off in order to get a pairing code for an additional device!
I am on android 10 and have been having intermittent sync issues with my Charge 6....  I disconnected the Charge 6 from my tablet, and deleted the tablet app version and the phone sync issues disappeared.   Maybe the Charge 6 gets confused if more than one device is paired.....very strange.
JimC_99,
I finally got the Charge 6 to pair with Iphone 14. Seems Bluetooth has to be off on other devices in order for pairing to occur. Thanks for your input! Might be nice if FitBit put this info in their Instructions.
BBinAZ
Sent from my iPad
I have a Fitbit charge6. It was paired yesterday with my phone, Samsung S21 FE5G running Android 14 and tablet, Galaxy tab A7lite also running Android 14. Today I am unable to pair it. Perhaps I am not recognizing how it appears in the scan list. I'm trying to connect a device called PR BT 0889. When I try pairing it I get a number I am supposed to confirm on my Fitbit but It doesn't appear on my Fitbit.
I have read, tried, reread tried reread.... every one of these entries. I can't find the devices option in the app. I apparently don't know how to find any other items in Bluetooth to "forget." The app says it's version 4.30.fitbit-mobile-1101469 and I'm told by Google that that it doesn't need to be updated.
I'm at a complete loss. I only have until December 16th to return the Fitbit.
I need help!
Hello @Catches72
Sorry to see you're having issues with your Charge 6 & pairing it to your phone & tablet.
Out of curiosity, what happened that your Fitbit was no longer paired with your phone & tablet? It should have still been paired if you had them connected yesterday.
To access the device option in the Fitbit app, tap on the device icon in the upper right of the Today page. That will open a different page where you should see the connected devices. Do you see the Charge 6 listed as a connected device?
What problem are you having with your Bluetooth settings that you can't find the connected devices?
The details you provide will help us guide you so that you can connect your Charge 6 to your phone & tablet.
Can’t get it to reliably pair and only a limited amount of time to get it to work.
Sounds like you have already answered the question as to what you need to do.
If you really want to stay with Fitbit / Google / meta, return it and then go get another one and start your return clock over again.
Maybe you just have a defective one.
There is no device icon on Today in the app.
I didn't do anything. It worked last night when I went to bed and for a
little while this am. It recorded my sleep, 15 Zone minutes, and 1,799
steps. On my wrist I continued to accumulate Zone minutes and steps but the
app never updated with the new numbers.
TAKE IT TO BEST BUY, OR STAPLES, THEY WILL HELP YOU OUT.
I have Geek squad support. I'll call them and, if need be return it
there,where I got it.
Just take it in with your phone so they set it up for u. Remember, Google
bought fit bit, so most of the stuff no longer works without a
subscription. Which is a costly pain!!:(
Hello @Catches72
There should be an icon to the left of the battery level percentage in the upper left at the top of Today page in the Fitbit app,. That's what you can tap on to open the Connected devices page.
Thank you for letting us know that it seems that your Charge 6 is back to tracking. Have you tried doing a manual sync from the Fitbit app? Put your finger on the Today page, pull down, and let go. This will trigger a manual sync. Let us know if the manual sync worked.
You might find this page helpful: How to get started with the Charge 6 (<-- click link). There's also a link to the Charge 6 User manual which has a lot of helpful information.
So agree! I too have tried everything that I possibly can, but my iPhone doesn’t pick up my charge 6 through a Bluetooth search, and the Fitbit (fully charged and connected to charging device) keeps showing the same message: “download Fitbit app “.
I feel really frustrated and sad about it all! Also, my fitbit account isn’t a Google account, and it’s force g me to log in with my Google account, but when I try to do that, it tells be my account isn’t already being used! Already being used by who?!
I finally gave up on the Fitbit Charge 6 and went to a competitive device that seems to be better Forerunner.
This decision was based on not being able to link the Fitbit Charge 6 to the Fitbit app, being locked out of my Google account, and all the problems with the Fitbit app.
Actually, I gave up trying and prayed thinking I probably needed a break
from tech again, the next day, my phone started asking me if I wanted to
link my fitbit. I responded yes and have had no trouble since.
This has happened before during times of stress. I'm learning to trust My
nKing, Jesus Christ, more and more in these times knowing he's sovereign
over everything in the universe(s)!
can_whiting,
I'm stumped! What Iphone version do you have?
Try restarting both phone and FBT 6.
Check for current versions of IOS APP and FTB 6 APP; update if needed.
If that doesn't work, go to Bluetooth/ Forget This Device to remove FBT 6 and reinstall.
Re-pair FTB 6: Open the FBT APP and follow the pairing process to reconnect the FBT 6 to Iphone!
If that fails, I can send you my Bourbon Milkshake Recipe!
Sent from my iPad
So a tip. Drkeyr any other fitbit on the account. Turn off wifi and delete
fitbit app. Then re-download fitbit app and then your watch with wifi. This
should elicite problems . It does not like to load a new fitbit until old
in is gone. You can have 2 or more fut bits but the each need tgier in
accounts.
All has failed...
I think I need your bourbon milkshake recipe... I am convinced that my Charge 6 will love it too.
Don't give up yet. Did you clear off the fit bit too with reset bugtons
before trying to re load it?? ? Otherwise, take it back yo thd store abd
have them fosoad it fir you, or try another watch. Mine is working fine
now. I still live thd low profile if this watch. Since these are
discontinued I will not get a Google watch!ppk online for suggestions.
It's a good watch...! If you have an apple phone, it does not work then as
it's an android program.
can_whiting,
I can email, text or use FaceBook to send you the Recipe next week. I feel your pain;  I am unable to pair language translation earbuds.
BBinAZ
