02-24-2024
09:34
07:29
LizzyFitbit
02-24-2024
09:34
07:29
LizzyFitbit
I am a premium member and snore report did not come in for last night. I cannot find the toggle to turn on snore report under the sleep tile settings. Does anyone know what is happening?
Moderator Edit: Clarified subject and updated label
Best Answer02-28-2024 17:00 - edited 02-28-2024 17:04
Hi everyone. Thank you for reporting this bug.
We have been informed that this issue is solved and the toggle and reports should be back. Please let us know if you're still experiencing this.
Happy stepping!
02-24-2024 02:05
02-24-2024 02:05
I also have the Versa 3 with Fitbit Premium and I am not getting a snore report. After researching, I found that I do not even have the option anymore to turn on my snore data in the app. Any help would be appreciated! Thank you!
02-24-2024 07:14
02-24-2024 07:14
A few days ago i turned on snore detection on my versa 3. Before, it'd go for more than a week without charging but now it has to be charged every 2-3 days. When trying to turn it off, I found that the option to turn it on and off was not accessible through the app. It seems a lot of people have had the same experience as me before, as in this thread:
Firmware version 36.128.6.17 on Versa 3, app installed on a Galaxy S10+ with up to date software.
Best Answer02-24-2024 09:32 - edited 02-24-2024 09:32
@Nampo Here is a link to Fitbit's Help article with the relevant section on snore detection expanded for you. Your link is a couple years old and my linked Help article uses the updated app. I know I easily turned the snore detection off on my Versa 3 when I wore it. I wear a Sense 2 now and it doesn't have snore detection, so I can't check the steps on my app.
Laurie | Maryland
Best Answer02-24-2024 22:30
02-24-2024 22:30
I can’t find how to turn it back on either.
02-24-2024 22:43
02-24-2024 22:43
Hi @CAF-Yifter @longdog1 - have a look here How to use Fitbit and the Snore Report to manage sleep apnea - it should be in the Sleep tile, Gear icon settings.
Best Answer02-25-2024 03:47
02-25-2024 03:47
My snore report shows on but no score for 2 days?
02-25-2024 04:24
02-25-2024 04:24
HI @Delta63 - the Fitbit App may not be syncing properly - see How to do a quick fix for Fitbit App not syncing it might help.
Best Answer02-25-2024 05:26
02-25-2024 05:26
I had mine turned on but haven't had a report in 2 days. I looked into Today > Sleep > Settings and the toggle option is gone altogether. There was an older community post where this had happened as well. My watch is otherwise syncing just fine but I was advised by chat support to reinstall the app... I have switched sensitivity and ensured the app is charged enough. I'll see if that helps in any way.
I doubt a reinstall is an adequate way to fix this, if several of us have reported the same issue at the same time, if we are using different mobile phones and different OS / OS versions.
It likely is a case that the toggle feature got removed from UI - either accidentally or on purpose (to fix a bug). I wish Fitbit were a bit more forthcoming with technical difficulties.
02-25-2024 06:46
02-25-2024 06:46
Detect snoring is not an option on versa 3. Not showing up when clicking the gear icon under sleep portion. How do I find the snore tracker portion?
Best Answer02-25-2024 06:50 - edited 02-25-2024 06:55
Already looked at these before posting. Best answer is actually from RosalieHealy. Made a mistake choosing Guy_
Best Answer02-25-2024 07:03
02-25-2024 07:03
Best Answer02-25-2024 07:28
02-25-2024 07:28
@CAF-Yifter- thanks for feedback - changed best answer for you.
Best Answer02-25-2024 09:34
02-25-2024 09:34
You're right, the toggle is no longer available in the UI.
I used to switch the Snore-Detection on and off over the past several months, but I generally keep it off - since it uses quite a lot of battery.
However, last week I re-enabled the monitoring (since I wasn't sleeping that well) and I received the report 3 days in a row, until Friday morning. Since I noticed the report wasn't available I also noticed the toggle-button has vanished from Sleep-Settings section, because I wanted to activate it.
I concluded it is surely not a sync issue, because the battery usage overnight is quite small: in my case it is about 10% battery usage with Snore-Detection Off, and around 25% with the feature turned On. For the past two nights when no report was delivered, the battery usage was only 10% - so my tracker behaves as if it has Snore Detection Off.
02-25-2024 09:46
02-25-2024 09:46
Hi @fr_fit - your analysis Indeed points to it being turned off.
Just in case the app has glitched, even if reinstalled, try logout of the Fitbit App, swipe off the active window and in Android clear the storage cache and force stop it, restart the phone for good measure.
Login again, check you are still a premium user and if the switch has returned.
Best Answer02-25-2024 10:09
02-25-2024 10:09
Well that is what I tried before. I have seen screen shots people have shared and some (including me) do not have the option to toggle snore detection off. The feature is not even mentioned in the menu.
02-25-2024 10:52
02-25-2024 10:52
It is not turned off, have done an update, am
a premium user- fix it please Fitbit
02-25-2024 11:05
02-25-2024 11:05
I followed all the steps as you suggested a few minutes ago, the Sleep-Settings section looks the same - there's no switch for the Snore-Detection. I have premium subscription until Oct.'24. I'm puzzled by the missing switch since I had no Fitbit App update (Android user here) over the past few days, and also no SW update for the tracker (Sense). No system update on the phone either - assuming that some strange change on the phone might affect Fitbit App behavior.
I already applied yesterday morning the procedure including "sign-off, App force-stop, phone restart" - when the first Snore report failed to appear - since I'm used to this sequence because of the missing oxygen blood saturation report. Every other week or so, the "Health Metrics" section shows "No data" for Oxygen saturation, and I found (via this Forum) that using this restart procedure will bring the data from the tracker into the App.
02-25-2024 11:34
02-25-2024 13:59
02-25-2024 13:59
Same for me. The snore report has disappeared now for the last 2 nights. Also a premium member. What is going on.
