08-01-2016 13:54 - last edited on 08-20-2020 16:59 by MatthewFitbit
I don't think that my steps are being accurately counted when I use a walker and don't swing my arms. Does the fit bit count steps even if your arms are not moving?
06-11-2018 16:37
06-11-2018 16:37
06-13-2018 07:07
06-13-2018 07:07
Hello @Crowfae, thanks for joining the conversation, it's great to see you around. It's nice to see you as well @Siegebert, thanks for your insight about this situation.
@Crowfae, I understand your concern about Fitbit devices not detecting steps correctly when using a walker. Please note that this has been brought up to our development team and at this moment my best recommendation would be voting and comment on the suggested idea by @fudge22, this will let our development team how much this suggestion is being requested, the more votes an idea has, the more attention it gets. Additionally, you could place your device inside your sock or pocket as @Siegebert mentioned.
Thanks for your patience and understanding, if there's anything else I can do for you, please feel free to reply.
08-28-2018 17:14
08-28-2018 17:14
I have a Fitbit flex 2 and purchased a necklace that you can wear the tracker in. It’s a good alternative although this Fitbit does not have display or track heart rate but for tracking steps and activity this works for me
08-28-2018 18:15
08-28-2018 18:15
I used the necklace until upgrading to a Versa.
Awesome fix then.
Still figuring this one out.
08-28-2018 20:24 - last edited on 09-05-2018 12:08 by FerdinandFitbit
He,that sounds great. where did you get it? What does it look like,? Can not for me but still would like to know. Would look silly on me, too old Male and 90. Have a great day.
PS: many people will be thankfully for this information.
Tell me more about the versa.
Siegebert
Moderator edit: Merged replies
08-29-2018 04:16 - last edited on 09-05-2018 12:10 by FerdinandFitbit
The tried-and-true method for May Siebert is to put it in your sack and every step is accounted for. I realize it's not on your wrist but if you have a phone you can check it there or you can check it periodically throughout the day it tracks your pulse the tracks your heart rate especially if you put it across the bridge of your foot. Your pants cover the tracker and no one knows it's there.
All the most reliable way for me to put it in your sock. Your pants covered up if you place the face of it across the InStep of your foot it tracks your pulse your heart rate your phone app will show everything is going on with this you don't have to check it if you don't use the phone app then you can check it periodically throughout the day. I'm not going to put one around my neck just one more piece of jewelry that I don't want around my neck. And I want to track all day. If I'm going somewhere that is not feasible to put it in my sock then I really don't need to track my steps. As I'm a woman if I dress up in the dress those are the times that I don't track my stuff because I put it in my purse. A man can put it in his pocket. You will still have some of your stuff track but it's not important.Gail
08-29-2018 06:45
08-29-2018 06:45
08-29-2018 07:50
08-29-2018 07:50
Yes that is the way to go.
Do take care.
Siegebert
09-05-2018 12:13
09-05-2018 12:13
Hi everyone! Good to see you in the Fitbit Community Forums! 🙂
@Brownie41153, that's a great suggestion! Thanks a lot for sharing this with us!
@Siegebert, if you'd like more information about the Fitbit Versa, click here for more information.
If you guys need anything at all, let me know. I'll be happy to help you out!
09-05-2018 15:23
09-05-2018 15:23
Do you know if they have plans to update algorithm for walkers and strollers.
09-05-2018 15:46
09-05-2018 15:46
Hi, am not aware of any
, but you can ask this question directly to Fitbit using this Community board.
Am still using my sock and have the unit on the inside of my left leg just above my ankle
Greetings, Siegebert
09-06-2018 12:10
09-06-2018 12:10
Which I have mentioned a few times on the thread is not an option for me, but glad it works for you.
09-06-2018 19:56
09-06-2018 19:56
I usually weat crew sock, but I bought a knee brace that is just stretchy elastic. When worn on the calf the fitbit can be held safely in place and you can where whatever you want on your feet.
09-06-2018 20:40
09-06-2018 20:40
Well there you are, an other good suggestion
Thanks, sure someone will use that.
Siegebert
09-09-2018 12:54
09-09-2018 12:54
@Crowfae, thanks for getting back and good to see you all around!
At the moment, I'm not aware on any plans for something like this. If I get to know about anything like this, I'll be sure to let you know!
If you guyd need anything else, I'm always around!
09-09-2018 14:15
09-09-2018 14:15
Thanks for this suggestion. I wear compression hose or compression socks and use a magnetic wrist band for my Alta. The band doesn't come apart like the traditional ones so I can't wrap it around my ankle. Using a sleeve will definitely work. Helps when I'm wearing yoga pants this way!
09-11-2018 09:58
09-11-2018 09:58
Wow, that's a very interesting workaround! Thanks a lot for sharing this with us @OldRingleader! 😄
02-18-2019 09:25
02-18-2019 09:25
I do use a walker, but am in the pool daily so getting another Fitbit is not likely. I will try the sock method and hope it works.
02-18-2019 11:56
02-18-2019 11:56
02-19-2019 09:23
02-19-2019 09:23
Hello @aquanutkkp thanks for joining the Fitbit Community. It's nice to see you too @Brownie41153, thanks for taking the time to reply.
I appreciate you have shared your tips with us, I'm sure they will be very helpful for other members in the Community. In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
