11-06-2025
13:40
- last edited
yesterday
JuanFitbit
11-06-2025
13:40
- last edited
yesterday
JuanFitbit
I was trying to log my food today and it will not show any food when I put an item in. It will also not show anything in the database when I scan and I know those items are in there. Please help. I have a sense 2 and an apple
yesterday
yesterday
I was able to log my breakfast on Thursday 4 December, but any further attempts to add items resulted in only the last item entered showing. This was mainly from the "food" section in the app rather than the general + button; items from Frequent and Custom lists, also an item from the data base later in the day. Basically, everything, everywhere! Also problems synching on my phone. My Android phone had an update this week, but the problem with the Fitbit app began a day or two later. I have restarted my phone, uninstalled the reinstalled the app, turned Bluetooth off and on again, unlinked and linked my Sense to the app - nothing has helped.
This morning, nothing is saving into the "food" section. This is clearly an app problem, as all the other elements of my Sense appear to be working fine (sleep, steps, etc). I hope you can sort it out soon!
Best Answeryesterday
yesterday
I'm using a Samsung mobile.
Food/calories input disappears almost immediately, still happening.
Effects all input from the app I usually use the + sign
yesterday
Hi, This is happening to me as well.
I use a Google Pixel 9, happens when I try to log food using the + symbol; haven't tried any other way. Also happens with every meal, coming from the database. The food appears there for a second and then I receive the "unknown error detected" message. And the log disappears.
yesterday
Same here on Android. I hit the + on dashboard opens food database to add but nothing shows up when I tap log this and add more
yesterday
yesterday
This problem started for me yesterday too, each new food entry overwrites the previous one, rendering a large part of why I use Fitbit useless!
yesterday
Via app on android, all items/food disappears after entering no mather which way of trying to enter. Own registered food, from the DB, fast calories.
yesterday
yesterday
"Versa 4 Not Logging Calories After Update"
Software Failure Analysis (The issue)
Initial Bug (Data Corruption): New meal entries override the previous ones.
New Bug (Input Lock): Cannot comment; button click yields no result On the nutrition post.
This is a Catastrophic Regression (a bug in a new release that breaks old, vital functionality). It shows a failure in feature flagging or a complete lack of adequate regression testing before deployment.
yesterday
yesterday
yesterday
You know what. I had just updated the app and this happened: all my entries from 12/4 disappeared. I think the update had an issue.
yesterday
yesterday
yesterday
This all happened after the most recent app update. Just a hint.
yesterday
yesterday
It’s seems like this started yesterday in which I have an inspire 3 and I’m the same I have deleted the app and reconnected through Google in which I have had to reset metrics and preferences of data and logging food also is the same it disappears and only logs 1 item.. it’s lost two years of data but if we can fix it I’m happy to log from today.
yesterday
yesterday
I did not mark this as "Best Answer" as this is not an answer.
yesterday
I am using the app on an android phone. It happens whether I use the barcode to scan & look up an item on the food database or whether I use the + and try adding an item from the frequently or recently used items list. One thing of note is that If i click on the entry i have just made in an attempt to see if the nutrition details have been stored i get "An unkown error occurred".
yesterday
Experiencing the same issue for the second day in a row. Very frustrating!!
yesterday
yesterday
Same here to many problems since Google took over updates
yesterday
yesterday
It’s still not working. I just tried to log a cup of coffee at it disappeared. I am an iOS user. It doesn’t matter what time of day food, custom, or not. Even if I try to add anything to breakfast yesterday which was unaffected, the entry is deleted. These types of issues are happening too often. Do better Google/Fitbit.
