03-22-2018 05:15
03-22-2018 05:15
After the new OS update, I am unable to save my custom stats. I like to view particular things when I run, bike, etc. I work out 2-4 times a day, and it is frustrating to have to reset these before every single exercise. Anyone know what is going on with it?
06-18-2018 06:26
06-18-2018 06:26
Thanks you for your help.but it does not work.
ihave already tried that.
All that we need, is a développer to work on. Nothing else.
Thanks
Best Answer06-18-2018 13:42
06-18-2018 13:42
06-20-2018 13:33
06-20-2018 13:33
I tried what you mentioned but, it is not working. This is really annoying and frustrating
06-20-2018 21:26
06-20-2018 21:26
Ok mederator.
It is Time to give us à feedback about the developpers working on this issue.
Prove us that we are not wasting out time here.
It is clear that nothing as change for this issue. No update.
Now we want a solution.
Overwise, i think my next comment will be public un a commercial web site.
The Watch is very expensive and custumers deserve à better service.
06-22-2018 19:59
06-22-2018 19:59
The default Walk settings in the Exercise app for the Ionic can be changed to suit the user needs by tapping the gear wheel. This is a useful feature.
Unfortunately, there is a bug in the software that causes the settings the user chooses to return to default each time the watch syncs with the iPhone app.
I reported this to support and they told me that they were aware of the error and that it would be fixed.
This has not happened after two software updates.
I believe that this error is also affecting other features of the Exercise App.
The only workaround at present is to stop syncing Ionic with the FitBit app which is an inconvenience.
Can FitBit please fix this annoying software glitch.
06-22-2018 20:44
06-22-2018 20:44
A definite must, it took me a while to set it the way I wanted it and then a few minutes later it went back to default which is useless for me.
06-22-2018 20:46
06-22-2018 20:46
I agree it is annoying, they promised me it would be fixed and it is still there.
06-22-2018 20:53
06-22-2018 20:53
Yes please there have been so many updates and the error is still there
06-27-2018 20:26
06-27-2018 20:26
I'm still having the issue. Has anyone found a fix?
06-28-2018
09:10
12:07
06-28-2018
09:10
12:07
Hello everyone! Thanks for your participation on this thread regarding custom stats not saving on your watch.
Our team has received the feedback from everyone in this thread and is working to investigate these reports further. I will share updates from the team when I hear them. Thanks to everyone for your reports and understanding. In the meantime, I recommend restarting your watch and checking if the custom stats will save.
Will keep you posted!
06-28-2018 09:20
06-28-2018 13:30
06-28-2018 13:30
I have restarted the watch, and factory reset the watch, uninstalled/reinstalled the Android app, removed Bluetooth pairing, cleared app data, removed the watch from my account and re-added it — and custom stats still don't save.
Except for one particular activity. Has someone forgotten to iterate over an array?
06-29-2018 07:14 - edited 06-30-2018 06:31
The fact that this thread is over 3 months old without resolution says only one thing; Fitbit thinks it is more important to get new customers than it is to keep existing ones. There can be no other excuse for the lack of urgency they’ve shown in fixing this obvious flaw. Sad.
07-03-2018 09:16
07-03-2018 09:16
Just adding my name to this 3 month old list. Same problem with Fitbit Versa. I was so excited to upgrade from the charge2, now I wish I hadn’t. I have tried rebooting the watch, no luck. Where are the Fitbit moderaters and development on this? I’ll probably be returning it 😞
Best Answer07-10-2018 02:51
07-10-2018 02:51
Is there any news here?
This issue is terribly anoying...
Very bat point if there is no update.😞
For me it is the most important issue i have encountered.
Sooooo, Fitbit?
Best Answer07-10-2018 08:58
07-10-2018 08:58
Another month has gone by with no action on Fitbit's part. It would seem less rude on their part if we had some feedback to let us know that they are alive. Like - sorry guys but we do not have a fix yet because of xyz problem or other (lack of qualified fixer type people on staff ... ?).
07-10-2018 09:16 - edited 07-10-2018 11:33
FYI, another longer thread about this issue here.
https://community.fitbit.com/t5/Ionic/Custom-stats-not-saving/m-p/2611829#M43457
Best Answer07-10-2018 09:49
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
07-10-2018 09:49
Well, I started this thread and in my case this problem is solved. Actually, it was already solved since 32.10.15. It is very strange that it works for some and not for everybody. I wonder if it has something to do with the Fitbit App or IOS and Android. I use an Iphone (6). Everything updated on latest software.
Best Answer07-10-2018 09:59
07-10-2018 09:59
Just adding my post from another thread of the same issue.
This issue is NOT fixed...even with the latest update. Here are the scenarios using Weights as the example.
1. Go into Exercise > Weights config > Customize stats > middle stat. Untick a few things I don't want to show. Go back to weights screen > start workout. Keeps settings during workout. Finish workout and go about my business. The settings will reset at some point.
2. Go into Exercise > Weights config > Customize stats > middle stat. Untick a few things I don't want to show. Exit the exercise screen without doing a workout and go right back to weights screen > start workout. Keeps settings during workout. Finish workout and go about my business. The settings will reset at some point.
3. Go into Exercise > Weights config > Customize stats > middle stat. Untick a few things I don't want to show. Exit the exercise screen without doing a workout and go right back to weights config > Customize stats > middle stat and the settings are kept. Exit the exercise screen and go about my business. The settings will reset at some point.
4. Go into Exercise > Weights config > Customize stats > middle stat. Untick a few things I don't want to show. Exit the exercise screen and go about my business. The settings will reset at some point.
Unfortunately I have gotten into the habit of redoing the config every time I do an exercise. I would really like this to be resolved.
Best Answer07-10-2018 11:18
07-10-2018 11:18
Is there a fitbit moderator for these comments? Over time, there have been some comments that indicate that the problem has been fixed if you are using an iPhone but apparently not for others. I would like to see a fitbit person comment on this.
