08-21-2018 07:14 - last edited on 08-21-2018 11:54 by SantiR
Can someone please tell me how to increase the brightness on my ionic I can hardly see it during the daytime, it was fine but seems to have adjusted itself. Many thanks. Mark
Moderator Edit: Updated Subject for Clarity
07-15-2020 10:06 - last edited on 07-16-2020 20:25 by LiliyaFitbit
Thank you. I reset the Fitbit and all is fine.
Thank you
Sent from my iPhone
07-15-2020 10:53
07-15-2020 10:53
Excellent!
07-15-2020 13:45
07-15-2020 13:45
07-24-2020 14:31 - last edited on 06-02-2021 06:24 by JuanJoFitbit
I've been to setting saw that the first selection is Brightness, BUT, no matter how often or hard I "tap" the watch face, nothing changes. Its still set on DIM. Any suggestions would be GREAT. Thanks.
That is exactly how mine is working not working too.
GREAT ANSWER. THANK YOU. You fixed my Ionic and now I can read the face. Spectacular. Thanks again.
Moderator edit: merged replies
07-24-2020 16:03
07-24-2020 16:03
08-22-2020 10:23
08-22-2020 10:23
Thanks. Mine was also set on sleep mode. I thought there was something wrong with it as my brightness option was not adjustable. All fixed now and on auto.
09-12-2020 10:49
09-12-2020 10:49
Thank you so much, I put it to auto and the brightness is perfect
09-17-2020 12:54
09-17-2020 12:54
10-04-2020 09:16
10-04-2020 09:16
On my Ionic, the brightness feature is softened and seems to be locked on dim. it doesn't open up to change when tapped on. How can it be unlocked? It's difficult to see the screen in the daylight
10-04-2020 10:35 - last edited on 10-06-2020 16:56 by SilviaFitbit
Do complete reset and it will return to normal.
I had that experience and it worked for me.
Sent from my iPhone
Moderator Edit: Personal info removed
10-04-2020 11:04
10-04-2020 11:04
10-04-2020 13:18
10-04-2020 13:18
10-04-2020 13:36
10-04-2020 13:36
10-04-2020 13:49 - last edited on 06-02-2021 06:26 by JuanJoFitbit
The version I have is 71.6.19. Do you know is this is the current one.
I can’t figure out which screen view you’re talking about. I don’t see two buttons at the top on any of mine.
It used to be on auto. Changed somehow to dim. And I can’t change it back on the watch or app
Sent from my iPad
Moderator edit: merged reply
11-13-2020 20:03
11-13-2020 20:03
No screen in my Fitbit is so faint I can’t tell if I am I’m in brightness setting.
11-14-2020 03:39 - last edited on 01-24-2021 17:52 by LiliyaFitbit
I worked out how to fix it thanks. If you’re asking me, I’m unsure from your message, message me back and I I’ll let you know. I have another issue now which Fitbit are addressing 😩
Sent from my iPhone
11-14-2020 08:40 - last edited on 11-14-2020 15:35 by SilviaFitbit
The only way I managed was to fully reset my Fitbit, following the instructions from the support website.
Sent from my iPhone
01-19-2021 08:08
01-19-2021 08:08
finally something useful!!! I was in sleep mode also and could not adjust the brightness.
05-11-2021 08:10
05-11-2021 08:10
It's because it's in sleep mode. Hold down left button for several seconds to bring up menu. Use the moon button to toggle sleep mode on and off. I don't know why someone from fitbit didn't answer this question.
06-01-2021 02:35
06-01-2021 02:35
I can't even adjust the Sleep Mode ???
