10-03-2017
13:09
14:17
MattFitbit
10-03-2017
13:09
14:17
MattFitbit
Update 04/10/2018 - Chase is now officially supported by Fitbit Pay! So, if you have a Chase Visa card, it can now be added to your Fitbit Wallet.
Update 10/6/2017 - Note that Windows Pay is not yet available via the Windows 10 app, and will be coming soon.
With the availability of Fitbit Ionic, we are excited to announce Fitbit Pay! This feature will allow you to add credit and debit cards to your watch to make contactless payments, wherever you are.
The video below will help you get up and running with Fitbit Pay:
If you have further questions about using Fitbit Pay, check the following help resources:
11-15-2017 00:54
11-15-2017 00:54
I’ve used Fitbit Pay for about a month so far via a NZ bank (ASB Bank). No PIN required at any terminal (even over the $80 threshold usually triggering a PIN). Occasionally the Fitbit does not find the terminal sensor and I can’t pay (awkward) but restarting the Ionic seems to fix it. Also if I notice the Ionic PIN has not been prompted for a while then I restart the Ionic before trying to pay - prevents an embarrassment at the till!
11-15-2017 06:27 - edited 11-15-2017 06:47
I have the same problem. I also don’t see the wallet tile. I reinstalled the wallet also but nothing helps.
I have a samsung s6 edge plus running on android 7.0. This is my main device
I also use a iPad where the app is installed on and I also installed the app in Windows 10. But this I deleted again. On al the devices there are no wallet tiles.
My ionic runs on firmware 27.25.16.7
im living in The Netherland and at this moment there are no supported Dutch banks. Can this be the reason? That wallet is not available in The Netherlands and some other country’s ? Or has it to do with that I installed the windows 10 app in the past?
11-15-2017 08:27
11-15-2017 08:27
Hi, @PatrickNL, Fitbit Wallet will not be available to you as long as there are no supported banks in your country, so that is the reason you are not seeing it.
11-15-2017 08:30 - edited 11-15-2017 08:31
@PatrickNL I don't think it's available yet in NL and with you saying there are no supported banks that would seem to suggest not. As such you won't see the wallet tile
Edit - piped at the post again
11-20-2017 06:56
11-20-2017 06:56
I am in NL as well, but I do see the wallet app. I guess it could be related to your Windows 10 setup.
Not that it matters, since there are no supported NL banks.
11-21-2017 17:06
11-21-2017 17:06
Hi everyone! Just wanted to take this opportunity to welcome the newcomers to the Fitbit community.
@SunsetRunner Great to hear that you have been enjoying Fitbit pay!
@PatrickNL @Tim31415 I can confirm that Fitbit pay is not currently available in The Netherlands. I would recommend periodically checking the list of supported banks, as we update this information when new banks are added.
For anyone else who may have questions about Fitbit Pay, I would definitely recommend checking out this article, which is full of great tips on how the feature works.
@Julia_G @SunsetRunner Thanks for the help!
Want to get more deep sleep? Join the discussion on our Sleep better forum.
11-26-2017 10:59
11-26-2017 10:59
Yes I had similar problems setting up the wallet. I got it to work by setting up a pin on the lock screen of my android phone. Works then. Only problem now there is only one bank in the UK that supports it.
Malcolm.
11-29-2017 23:24
11-29-2017 23:24
Dear MattFitbit,
Here is another user from the Netherlands. It was only when I received my Ionic 3 months ago already that I found out the Wallet-functionality is not (yet) supported in The Netherlands. Quite a disappointment. I'm checking the list of supported banks weekly, but cannot find a single change. Will the Fitbit Wallet ever go live in The Netherlands and do you have any idea about the timeframe?
Thank you,
Maud.
12-05-2017 13:33
12-05-2017 13:33
Please add Halifax bank to the UK group of fitbit pay banks.
12-07-2017 22:53
12-07-2017 22:53
Is Fitbit Pay available in Germany yet? I'm with Commerzbank.
12-10-2017 00:15
12-10-2017 00:15
I am in Australia and there is no wallet tile in my account settings. I am on Samsung galaxy 8 and have the developer firmware. You have banks listed for Australia so it should be available. Is there another way I can configure it to get it working.
12-18-2017 19:36
12-18-2017 19:36
So I'm trying to setup my Ionic using my iPad Pro 9.7 WiFi only since the Windows app don't support Wallet yet.
My bank is OCBC and I'm trying to setup my Yes! Debit card. However, I keep getting "There's a problem verifying your card details with your issuer. Please verify and try again." This is during the preparing Device phase.
I've tried multiple times and called the bank. They say there's nothing wrong on their side and my card is usable for sure.
Anyone has any ideas?
12-18-2017 23:31
12-18-2017 23:31
I'm trying to setup the pay function through the wallet and it searches then stops with "the operation couldn't be completed. (Fitbit.PaymentsError error 0.)" am I doing something wrong? I'm in Australia.
12-19-2017 06:13
12-19-2017 06:13
Did you check the list of banks currently being used by Fitbit Pay? There is only I believe 5 or 6 banks TOTAL in the USA. I didn't know that when I tried setting up my Chase card (because of its size i didn't think it would be a problem) but they are not supported! Unfortunately I really have no other further use for it so I am returning mine. At this point (in my opinion) it's an overpriced Blaze to me.
12-19-2017 12:40
12-19-2017 12:40
I bought mine yesterday at the airport... I don't understand why a product like this is launched without making the features accessible. Pay with the NFC chip with 2 banks I have never even heard of in the UK. I'm going to return mine until Spotify is supported and proper UK banks are supported otherwise it's a glorified Charge 2 with GPS and a colour screen
12-19-2017 22:16
12-19-2017 22:16
My Fitbit ionic keeps wanting me to add a card to my wallet. However i don’t want my card or bank info on my ionic how do i stop the notifications and code from showing up on my watch...
12-19-2017 23:39
12-19-2017 23:39
@Mattiline If the number lock is coming up on your Ionic and you’ve not enabled a card in your wallet then the likely option is that you’ve enabled Device Lock. Go into the Account tab in the app on your phone, click on Ionic to get to the settings page, scroll down to Device Lock, tap on that and then disable it.
If you never want to use Wallet on your Ionic, you can remove it from your apps, again in the app on your phone. Click on the Apps tile, in the Settings page, scroll to Wallet, tap on it and then click remove.
12-20-2017 13:08
12-20-2017 13:08
12-25-2017 11:28
12-25-2017 11:28
Is Chase bank yet supported?
12-27-2017 03:05
12-27-2017 03:05
Please add tsb Bank and Halifax for the UK please
